mính nhận con máy N2626 khách đưa tới . đo dao động thì không có dao động gì cả . dao động đứng im không nhúc nhích gì cả . đưa vào J.A.F chạy thì báo như sau . nhờ anh em coi dùm .
Getting MCU ID
MCU ID: 0x3040
FLASH ID0: 00010000 <=> Flash -> not used Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0
First 16 bytes: 00 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-291\
Checking path: C:\785\Products\RM-291\
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\products\RM-291\rm291__06.80.mcusw
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\products\RM-291\rm291__06.80.image_qc
Languages in ppm: English,Chinese S,Vietnamese
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\products\RM-291\rm291__06.80.image_qc
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\products\RM-291\rm291__06.80.mcusw
Booting phone...
MCU ID: 0x3040
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x01000000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: b2
Loader is ready...
MSID: 84A6D856F9252DFC32278964A2
MSID decoded: 4F16BAE900D83C7FA8000000
FAID: 536FF185F6C54D62F0B94997
Operation took 0 minutes 8 seconds...
Erasing...
Found 3 interval(s) to erase
Erasing area: 01000000 - 0101FFFF...
Erasing area: 01020000 - 018DFFFF...
Erasing area: 01EE0000 - 01FDFFFF...
Writing...
Error cmd: 14!
Addr: 01000000
thank anh em nhiều !\
 LinkBack URL About LinkBacks
			 N2626 chạy J.A.F anh em coi dùm cái log
