Kết quả 11 tới 18 của 18
    Thành viên tích cực tuananh65's Avatar
    Feb 2008
    Hà nội
    Mặc định Xin giúp 6300 chay sw ok nhưng không UI setting được
    em có con 6300 chay bằng hwk thi chek được nạp sw ok nhưng không UI setting được.bật nguồn vẫn lên nhưng một lúc là tắt nguồn. máy chỉ chek được nhưng không info được mong ae giúp đỡ.thanks
    Thành viên tích cực phuc_gsm07's Avatar
    Jun 2008
    Trích Được post bởi TUANSY Xem bài viết
    JAF version 1.98.62
    Detected PKEY: 9002DC3D
    Card life counter: 90.40%
    FBUS INTERFACE NOT CONNECTED!!!
    USB Cable Driver version: 6.84.4.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\
    Checking path: \Products\RM-217\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.ppm_a
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.image_a
    Languages in ppm: English,German,Finish,Swedish,Danish,Norwegian,Ice landic
    Backing up CRT...
    Detected P-KEY: 9002DC3D
    Init usb communication...
    Reading IMEI...
    Failed! Aborting!
    Failed to backup CRT...
    PRESS POWER ON NOW!
    Searching for phone...Found
    Sending RAW loader...
    Using 06.02.002
    Elf2flash 02.33.000 RAW loader...
    Patching RAW boot step1...
    Patching RAW boot step3...
    Sending RAW Loader...
    ...................Loader Sent!
    Stage 2 starting.......................................... ....................Loader Sent!
    Stage 3 starting..................Phone prepared OK!
    Waiting for the phone to boot...
    Status byte: 0400
    Selecting CMT flash...
    Result: 0000
    Phone is in flash mode...
    CMT blocks: 1408, APE blocks: 0
    Erasing cmt...
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.mcusw...
    Erasing cmt zone 00000000 - 000006BF ... Erase result: 0000
    Erasing cmt zone 000006C0 - 0001FFFF ... Erase result: 0000
    Erasing cmt zone 00020000 - 0007FFFF ... Erase result: 0000
    Erasing cmt zone 00080000 - 000DFFFF ... Erase result: 0000
    Erasing cmt zone 00100000 - 001FFFFF ... Erase result: 0000
    Erasing cmt zone 00200000 - 0031FFFF ... Erase result: 0000
    Erasing cmt zone 00320000 - 0105FFFF ... Erase result: 0000
    Erasing cmt zone 01060000 - 01067FFF ... Erase result: 0000
    Erasing cmt zone 01068000 - 0107FFFF ... Erase result: 0000
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.ppm_a...
    Erasing cmt zone 01080000 - 015FFFFF ... Erase result: 0000
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.image_a...
    Erasing cmt zone 01600000 - 01FDFFFF ... Erase result: 0000
    Send CMT CFG...
    Writing cmt...
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PASUBTOC
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for DSP0
    Sending CMT HASH for MCUSW
    Sending CMT HASH for PMM_CONF
    Sending CMT HASH for SBIF_CONF
    Rebooting...
    Restarting CMT...
    Pooling phone...
    Phone not found...
    Second try...
    Phone not found...
    Done!.
    máy có nguồn chạy thử mất nguồn.xin anh em chi giúp với
    Lấy ver cao nhất của nó mà chạy là ok thôi, bg ver cao nhất của nó là 7.21 đấy. Chạy lại phần mềm dòng BB5 ít nhất cũng phải chạy lại ver bằng ver cũ của nó không thì cao hơn hẳn ko đc thấp hơn không là máy ngủ đấy.
    Y!M: Votinh_votinh_02@yahoo.com
    ĐT : 0916.031.444 - 0303.644.616
    Thành viên tích cực binhdtdd's Avatar
    Sep 2008
    Trích Được post bởi phuc_gsm07 Xem bài viết
    từ từ cái gì cũng nhừ ,theo đường của AE m2 đi theo ,coi chừng lạc đường đấy nhé
    0933.379.527
    Thành viên tích cực v&tmobile's Avatar
    Oct 2008
    Ctythegioididong
    kiếm cọng cáp đa năng mà chạy bảo dảm á !
    Thành viên mới lamlaicuocdoi792's Avatar
    a chạy hwk thì bỏ thêm dualline là lên liền à, nhưng phải lấy v7.21 nhe chúc a thành công nhe
    Thành viên chính thức truongchinhmobile's Avatar
    Mấy cái con 3110c này thì cứ lấy cáp USB ra mà múc cho nó ngọt,nhớ cài thêm PC suite nữa nha
    Yahoo&Skype:truongchinhmobile
    Thành viên chính thức TUANSY's Avatar
    Oct 2007
    chạy được rồi cảm on các bạn nha.nhung lên được la do mình sài bản jaf rack
    V.I.P Hoàng Thiên™'s Avatar
    http://gsmtaynguyen.com
    Mình chạy lại giùm mà không thanks, chơi xấu quá
    Trần Hoàng Thiên
  1. Trả lời: 1
    Bài viết cuối: 02-06-2014, 11:07
  2. Trả lời: 5
    Bài viết cuối: 04-03-2010, 14:20
