Mình flash máy 1100i thấy báo thế này ,các bác xem log rùi giúp mình 1 tay .Thanks .
Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 7.02
10-12-07
RH-93
(c) NMP
HW version: 0526
PCI version:
UEM version: 1328
UPP version: 8705
RFIC version: 0500
DSP version: P05w06.v34
LCD version: UNKWN: IDs:
00:ff:00
PPM version: BB^µƒãŸV
¹£ï¿
ADSP SW version: no NAI version
Production serial number: IBH052276
Product code: 0537102
Module code: 0203169
Basic production code: 0536354
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 358655015068306
IMEI spare to net: 3A 85 56 05 51 60 38 00
IMEI SV to net: 33 85 56 05 51 60 38 40 F5
Master Code: 4147570343
Phone type: RH-93, Software version: 7.02, Language Pack: ¹£ï¿
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-93.ini
Setting local mode...
Reading product code...
Product Code: 0537102
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Checking path: \Products\RH-93\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02md
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02md
Languages in ppm: English,Filipino,Vietnamase
Done!
Changing flashing settings...
Reading...
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
Booting phone...
MCU ID: 0x2201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x72888900
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
Loader size is 0x5538; Loader chk: bb
Loader is ready...
Error Auth!
