nếu cable này bạn vẫn chạy những con khác ok thì bạn cứ để đó chạy . báo failed nhưng imei vẫn còn . bạn tick bỏ 308 rùi flas lại . nếu flas lại mà không hết hạn chế điện thoại mà không co mxkey repai thị bạn dùng bb5 king repai nếu không được thì fải nhờ đến mxkey ruiđây là log khi mình chạy lại ver 7.21 mấy pro xem giùm mình nó bị gì với
Detected PKEY: 9002E224
Card life counter: 85.33%
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\
Checking path: \Products\RM-237\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_c
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_c_fr
Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__05.50.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__05.50.ppm_v
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__05.50.image_v
Languages in ppm: English,Chinese T,Vietnamese
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_v
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_v
Backing up CRT data...
Setting FLASH MODE
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 89810089 <=> INTEL -> Type not in database
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
VARIANT CRT empty, skip save...
Reading CMT CCC certificate...
Reading CMT HWC certificate...
Saved to C:\Program Files\ODEON\JAF\ProgData\35685202967974_CRT_backup _355255.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Setting local mode...
Failed! Aborting!
Failed to backup LCK...
