Kết quả 1 tới 4 của 4
    Thành viên mới nguyenduoc84's Avatar
    Mặc định 1209 can giup
    May ae xin cho em hỏi . cái máy 1209 của em bị rớt nước khởi động khoảng 1 phút thì tắt , em chạy lại pm nhưng không hết , Em đã thay CPU và chay lại nhưng lại nhưng báo contrac service . Em moi vao nghe moi mua hop ve chay pm mong ae chi dẩn thêm
    file chay cua em mong ae chi dan . Em cám ơn !
    Getting MCU ID
    MCU ID: 0x2292
    FLASH ID0: 260600EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Backup IMEI zone...
    Setting local mode...
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Getting MCUID...
    MCU ID: 0x2292
    Reading flash chip detailes...
    MCU ID: 0x2292
    Boot is ready...
    Algo is ready...
    Loader is ready...
    Erasing area: 01000000 - 01FFFFFF...
    Done!
    MCU ID: 0x2292
    Boot is ready...
    Algo is ready...
    Loader is ready...
    Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Failed! Aborting!
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    No ini files found...
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
    Checking path: \Products\RH-105\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.910
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.91aa
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.91aa
    Languages in ppm: English,Dannish,Norwegian,Swedish
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.91mr
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.91mr
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.910
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Flash ID is 0x0626EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
    Loader size is 0x7528; Loader chk: 3a
    Loader is ready...
    MSID: 844EDC4A3D2525EF027598593A
    MSID decoded: 3E4EBAE9000265FCA8000000
    FAID: 9C8ADA608B7DD81FD2C0517E
    Operation took 0 minutes 11 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013AFFFF...
    Erasing area: 013B0000 - 013EFFFF...
    Operation took 0 minutes 22 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 14 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.91mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Operation took 0 minutes 6 seconds...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 01240000 - 0124FFFF...
    Erasing area: 01250000 - 0137FFFF...
    Operation took 0 minutes 7 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.91mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 848BF510B7A9AEE97B3F85B09A
    MSID decoded: 3E4EBAE9000265FCAA000000
    FAID: 735695D556F856B04FF2F9A6
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013AFFFF...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 1 minutes 21 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-105, Software version: 5.91
    IMEI: 356927039503531
    Product Code:
    Resetting PPC...
    Done!
    Setting test mode...
    Setting FULL FACTORY...
    Operation took 0 minutes 4 seconds...
    Done!
    Unlocking...
    ASIC: b
    SW version: 5.91
    Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_05.910
    Decrypting flash...
    Encrypting....
    CHK Patch found - Unlock Patch found and are not in same block
    Patch status: 02
    MCU ID: 0x2292
    Algo is ready...
    Erasing area: 01200000 - 0121FFFF...
    Erasing area: 011E0000 - 011FFFFF...
    Unlocking...
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Done!
    DCT4 unlock counter: 1732
    Thành viên mới buiquocthang's Avatar
    Jan 2008
    con này bạn chỉ can chạy pm va unlock lai la ok, lỗi nà la do bạn chạy pm nhưng khong unlock ma khi dó ban chọn unlock tren tool
    tại vì em mới tập chạy nên không hiểu sâu về phần mềm mong ae chỉ rỏ hơn giúp em cách unclock em cám ơn nhiều !em đã plash lại nhiều lân rồi nhưng vẫn thế !
    Moderator thanhphuek's Avatar
    Feb 2010
    Eakar Đến PLeiku
    bạn đang dùng jaf bạn hay flash lai ===>unlock(click unlock đơi chút bạn chọn phiên bản vừa chạy để tiế hành unlock
  1. 1209 thay cpu 2293 can giup
    By nguyenbaokhuyen in forum DCT4 - WD2
    Bài viết cuối: 27-10-2010, 17:29
  2. giup em con 1209
    By duyquang_mobile in forum DCT4 - WD2
    Trả lời: 31
    Bài viết cuối: 11-11-2009, 01:15
  3. xin giup em máy 1209
    By toiyeumobile in forum DCT4 - WD2
    Bài viết cuối: 18-10-2009, 13:27
  4. xin giup phan men may 1209
    By vuonghuy89 in forum BB5
    Bài viết cuối: 25-09-2009, 22:32
