ban hay noi day lai 3 con loc nua la ok.chuc ban len duong
bạn coi lại trung tần f3 hay f7
chĩ có thễ là chúng thôi.tt lọc
:D
đã câu sw ant,rx filter,thay if ic,chạy lại pm,nạp PM chuẩn vào mà vẫn mất thu.Khi chạy lại pm có báo lội như sau:
Getting MCU ID
MCU ID: 0x1120
FLASH ID0: F222EC00 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 06.01
22-11-04
NPL-2
(c) Nokia.
HW version: 4835
PCI version: 0
UEM version: 8
UPP version: 4384
RFIC version: 03122
DSP version: M8.00-4.60
LCD version: X4
PPM version: V 06.01
22-11-04
NPL-2
(c) Nok
V
Production serial number: DCE278280
Product code: 0516553
Module code: 0202205
Basic production code: 0513172
Flash code: 0
Order number: 0
Product specific data: 0
Long production SN: 0
ATO: h?????????????????????????????????????????????????
Default SN type: h?????????????????????????????????????????????????
IMEI plain: 350604300435042
IMEI spare to net: 3A 05 06 34 00 34 05 04
IMEI SV to net: 33 05 06 34 00 34 05 24 F6
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 5220443635
Phone type: NPL-2, Software version: 06.01 , Language Pack: V
User code: 12345
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_NPL-2.ini
Checking path: C:\Program Files\Nokia\Phoenix\Products\\
Checking path: \Products\\
No ini files found...
Done!
Unlocking...
IMEI: 350604300435042
ASIC: 2
SW version: 06.01
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
DCT4 unlock counter: 0
Unlocking...
ASIC: 2
SW version: 06.01
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
DCT4 unlock counter: 1
lac trung tan, lac nguon la` ok thui ban
thya công suất là ok chúc bạn thành công
em can so do cau mach song 3120
