What's new:
- Added support for unlock W200 CID 52 by test point
- Added backup eeprom data, all files will be saved to DB2020 inside/backup folder
New files in installer:
- Test point picture for w200 (C:\Program Files\GriffinTeam\MT SonyEricsson\DB2020 inside\Test Points\)
- Test point cable scheme (C:\Program Files\GriffinTeam\MT SonyEricsson\DB2020 inside\Documents\)
- Test, Install and unlock files for W200 CID 52 (C:\Program Files\GriffinTeam\MT SonyEricsson\DB2020 inside\TP Unlock\)
- User manual updated
Short manual how to unlock W200 CID 52 via Test Point
- Start DB2020 inside v4.3 or higher
- Select W200 from phone model list
- Add to software “Test GT Boot-w200.plugin” (found in DB2020 inside/TP Unlock folder ) to check it is GT boot already installed or not,
if boot is already installed you does no need for a test point.
- If GT boot does is not installed to the phone please add to software “ Install GT Boot-w200.plugin ” (found in DB2020 inside/TP Unlock folder)
- Prepare phone for Test Point and connect it to box cable without battery
- For this operation you need to have special cable (can bay it or modify your existing K750 cable)
- The cable scheme you can find in DB2020 inside/Documents folder
- Test Point picture are available in DB2020 inside/Test Points folder
- On some phones CPU you will find GLUE, please scratch it very carefully only from 27 pin
- Press Do It button and connect Test point when software tells you to CPU pin 27
- Disconnect Test Point when software tells you to
- Please wait to software finish and The End message appears
- Now you can assembly your phone and proceed to unlock process
- Add to sofware “Unlock DB2012-W200.plugin” file (found in DB2020 inside/TP Unlock folder)
- Wait to software finish
- The phone will be unlocked and all codes will be set to 0000 0000
- Your phone eeprom backup will be saved to DB2020/backup folder
Users who have installed DB2020 inside v4.2 can download and install "DB2020inside_v4.3_for_v4.2_users_only.exe"
New users need to download full installation "DB2020 inside v4.3.exe"
The software can be used also with ALL upgraded MT box Siemens and MT box Nokia to MT box SonyEricsson
