Kết quả 1 tới 2 của 2
    V.I.P NGA CUN's Avatar
    May 2007
    hà nội city
    Mặc định 22.01.2010 - MT Box Nokia - MTB NK v2.10 - SL20 RPL standalone
    Release note:
    Support for "StandAlone BB5 SL20 RPL" unlock (button SL2 RPL)
    Some bug fixed
    "StandAlone BB5 SL20 RPL" module activation is obtained using MT Tool v3.14 ( button Check Activations)
    Once activated box will not connect to server for generating RPL for SL20 phones (RAP3 and RAPIDO)
    AutoUnlock support for 'SL20 RPL': in griffin.ini in [interface_options] if there is entry 'autostart=1'
    MT Box will enter in auto mode when you click 'sl20 rpl' in this mode,
    MT should detect when phone is connected, unlock it with RPL and then prompt you to disconnect phone.
    All you need to do to unlock another phone is just connect it to MT Box. When you want to terminate "AutoUnlock" mode, click the button on the 'message box' that is shown in MT.
    Supported all models with HASH 9DDBF:
    3600 Slide (RM-352)
    5220 Xpress music (RM-411/410)
    6600 Fold (RM-325)
    6600 Slide (RM-414)
    6600i Slide (RM-570)
    7210 Supernova (RM-436)
    7310 Supernova (RM-379/378)
    7510a Supernova (RM-398/399)
    7610s (RM-354)
    6790s-1c (RM-599)
    6790s-1b (RM-492)
    Accounts which can be used for this activation:
    GT server full access accounts
    MT PRO accounts
    SL20 accounts
    Credits needed for activation:
    If box already activated for BB5+ - 20 credits
    If box has no BB5+ module activated - 80 credits
    How to activate "StandAlone BB5 SL20 RPL" module for MT Box Nokia:
    Visit the link: BB5 SL20 RPL(pin) activations
    Enter your MT Box serial number – SN
    Enter your GT server or MT PRO user name
    Enter your GT server or MT PRO password
    Select – I want to use this server account to enable MT-Box serial number specified above for StandAlone BB5 SL20 RPL Activation!
    Click to Activate BB5 SL20 RPL button
    Download MT Tool
    Connect your MT box to USB
    Run MT Tool.exe from directory where is MTB_NK.EXE (i.e. where is located file griffin.ini in most cases C:\Program Files\GriffinTeam\MT-box) and click button ‘Update’.
    Do not use MT Box update tool v3.13 or older because will not work
    How to activate "StandAlone BB5 SL20 RPL" module for MT Box Nokia using "Box Account" (SL20) credits:
    Download and install MT box update tool
    Start MT box update tool v3.14 (do not use older version because will not work)
    Press INFO button, software will read your MT box information
    Press "Check Activation" button
    Software will connect to GT server and show you all available module activations
    Select desired module activation and press OK button
    If you have enough credits on your "Box Account" (credits info is shown on top of window) activation will be done in just few seconds
    If you does not have enough credits on your "Box Account" need to order it from your reseller
    How to order "Box Account" credits:
    Press GET SN button, box sn is now copied to clipboard
    Paste your MT box serial number to order form, email or IM (depend which way your reseller use for "Box Credits" order)
    Reseller need to inform you when your MT box is recharged with new amount of credits or you can check by your self by pressing Info button in MT tool
    Dowload:
    MTB NK v2.10.exe
    MTB NK setup v2.10
    MT Box update tool v3.14
    HÙNG NGA-MOBILE
    Repair All boot sam sung 3G
    đ/c: 55-trần hưng đạo -thành phố ninh bình
    đt:0984048988-0303899721
  2. ( NGA CUN ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    HongDiep (23-01-2010)
    Technical hungphongmobile™'s Avatar
    Mar 2007
    www.hungphongmobile.vn
    23.01.2010 - MT Box update tool v3.15
    Hi!
    Release notes:
    * Fixed bug with update some MT Box's using MT Box update tool v3.14
    Code:
    Device:
    \\?\usb#vid_a550&pid_f00d#0014b1xxx3#{e6ef 7dcd-1795-4a08-9fbf-aa78423c26f0}>
    SN:0014b1xxx3
    Getting BOX Status...OK
    INIFILE: C:\Program Files\GriffinTeam\MT-Box\griffin.ini
    Getting INI File Update 1...NOT ACTIVATED
    Getting INI File Update 2...NOT ACTIVATED
    Getting INI File Update 3...NOT ACTIVATED
    SN:0014b1xxx3
    Server Login... OK
    Ask...OK
    Server I/O...Server Error 1(a)
    Please update your MT Box using MT Box update tool v3.15
    Download:
    MT Box update tool | Griffin Team
    www.hungphongmobile.com
    www.giaimadienthoai.com
    <marquee ><font size=3 color=cyan><b> HungPhongMobile™ Service Center</b></font></marquee>
    <a href="ymsgr:sendIM?phongnhabr" target="_blank" rel="nofollow"><img src="http://opi.yahoo.com/online?u=phongnhabr&m=g&t=2&l=us border=0" border="0" /></a>
    <a href="ymsgr:sendIM?hp_unlockonline" target="_blank" rel="nofollow"><img src="http://opi.yahoo.com/online?u=hp_unlockonline&m=g&t=2&l=us border=0" border="0" /></a>
  1. MXBOX v3.5 revision 2.3 - STANDALONE (NO NEED INTERNET) Nokia N9-00 (RM-696) by USB
    By ĐẶNG BẢO_GSM™ in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 16-07-2012, 10:46
  2. MXBOX STANDALONE NOKIA BOX - HTI Firmware Updater v3.5 rev 0.3
    By TuệNguyễn in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 18-10-2011, 21:15
  3. Trả lời: 3
    Bài viết cuối: 09-12-2010, 21:01
  4. Trả lời: 0
    Bài viết cuối: 15-04-2010, 20:58
  5. Trả lời: 1
    Bài viết cuối: 15-03-2010, 22:54
