MT Box Nokia module activation for MT SonyEricsson and MT RED (Siemens)
Any MT Box model can be extended with additional modules, this allows you to use features from other MT Box models.
Example if you have MT Box SonyEricsson or MT Box RED you can activate additional MT Box Nokia module.
In this case you can use all software designed for MT Box Nokia on your existing MT Box SonyEricsson or MT Box RED.
To activate any module in 1 minute you need to have "GT server" , "MT Box PRO" or "MT Box" account with enough credits.
Module activation will be paid with 100 credits from your "GT server" , "MT Box PRO" or "MT Box" account.
After activation from your server or box account WILL BE DEDUCTED 100 credits and selected MT-Box will be ready MT Box Nokia module activation.
Please note:
Module activation process is irreversible, means once activated module cant be deactivated from your box.
Accounts which can be used for this activation:
* GT server full access accounts
* MT PRO accounts
* BOX account
Credits needed for activation:
* 100 credits
How to activate MT Box Nokia module on your MT Box using "GT server" or "MT PRO" account:
* Visit the link: http://www.gtibox.com/support/nokia.php
* Enter your MT Box serial number – SN
* Enter your GT server or MT PRO user name
* Enter your GT server or MT PRO password
* Select – I want to use this server account to enable MT-Box serial number specified above for Nokia Activation!
* Click to Activate Nokia button
* Download MT Box Tool
* Connect your MT box to USB
* Start MT box update tool
* Click to ‘Update’ button
* Do not use MT Box update tool v3.14 or older because will not work
How to activate MT Box Nokia module on your MT Box using "Box Account" credits:
* Download and install MT box update tool
* Start MT box update tool v3.15 (do not use older version because will not work)
* Press INFO button, software will read your MT box information
* Press "Check for Activation" button
* Software will connect to GT server and show you all available module activations for your box
* Select desired module activation and press OK button
* If you have enough credits on your "Box Account" (credits info is shown on top of window) activation will be done in just few seconds
How to order "Box Account" credits:
* Press GET SN button, box sn is now copied to clipboard
* Paste your MT box serial number to order form, email or IM (depend which way your reseller use for "Box Credits" order)
Now you can use all standalone MT Box Nokia features.
Best Regards GSMinfo
