mobileEx v3.2 revision 1.0, Public-Release
- MAIN
Added, UI Localization
;languages selectable from 'quote' menu
;locale files stored to 'locale\*.xml' directory
;added, Chinese (Simplified) language for test (translated using Google Translate, so am sure its not 100% correct), unicode enabled.
;full localization might be added at the future
Added, balloon Tips stored to locale files
Fixed, Application not opened in some PC caused by not previlege account (specially XP SP3 and Vista SP1)
List of loaded drivers version are now displayed at start up
Server list are now selectable
Added, posibility to play custom sound on error/finish
Added, Card Serial Port drivers
;allow to use serial(comport) based reader for the card
Added, 'Nokia USB ROM' virtual device to be used for BB5 USB DEAD PHONE flashing
Fixed, Connect<->Disconnect bug (appl. crash)
- VCOM
Small change in UI
Changed, PK-83 binary to support new drivers
- CCS
Fixed, nkser(6088,6066,7088) driver handling when flashing stop at the middle of process
- NK
Added, BB5 USB Flashing
; Supported loaders
RAP3Gv2+APE(external loader),
RAP3GV3+APE,
RAP3GV3 NON APE+DEAD FLASH,
RAPIDO NON APE+DEAD FLASH,
RAPIDO +APE,
RAPIDO (RAP3NAND) NON APE+DEAD FLASH.
; Version check mechanism is possible when flashing NON DEAD phone
; LANGUAGE only option also posible for fast and safe phone update
Added, Multiple version of flash update/loaders
; selectable from 'quote' menu 'Config->Directory'
; Newer phones might need newer flash loader, by default is '8.6.1.31560'
Fixed, BB5PLUS RAPIDO SL2 spunlock
Added, Pinout image for UFC based cable (press small button near phone image)
; pinout images are stored at 'data\image\pinout' directory
Multiple Data Package directory are now possible (usefull when working with Multi-OS PC)
Added, 'Force WHOLE flash' on erase(Advance Page) to allow RAP flash full erase (Last chance, if NPC reset still not work to revive DEAD/BLINK Phone)
Added, PP file read
Added, Phonebook/Contacts backup and restore (Phone Settings->Selection:User Settings)
Removed, Host setting (please use 'select server' from Main|Server List page)
- SIEM
Siemens module recompiled for new api compability
Big thanks to MANOLE for great suggestion to this project.
Many thanks to fren who help in borrowing phones and report REAL bug.
- merdekha (MSC)
- donny_wong(Service Point)
BR.
