If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!".
This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...).
Solution 1 (easy way, maybe not work all time, depends how phone was damaged):
- write full PM from SAME phone model (product number) WITHOUT fields 1, 308, 309 (and WITHOUT field 120 for SL20 based phones)
- unplug/replug phone from JAF/UFS box
- make Simlock RPL repair
- make SD RPL repair
- make SUPER SX4 Auth then write PM1 and PM309
if still have problems, use Solution 2:
- backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL
- backup RPL from another working phone (same model) with SAME product code
- edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL
- backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM
- full erase flash chip (use erase file regarding flash chip size)
- flash phone (CMT, APE, ...)
- upload CLONE RPL
- upload ORIGINAL RPL
- write full CLONE PM without fields 1,120,308,309
Manole
