ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: 35422303804144
Original Product code: 0571958
Bluetooth ID: 0025CF07FE41
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.90 23-09-09 RM-495 (c) Nokia
Imei plain: 35422303804144-8
Product Code: 0571958
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
ai co phan mem mxkey hok cho e voi e bi mat rui huhu
Đính chính lại cho bạn phimdanxanh,manhcom và fonemart39.
Hiện tại chưa có 1 Box nào Support SL3.
Trong 3 bạn,nếu bạn nào Repairt đc SIMLOCK SL3,tui đảm bảo sẽ có rất nhiều thợ tìm đến 3 bạn.
P/S : bạn manhcom : Đây là nguyên lý cách sửa của SL1,SL2
Chắc 3 bạn chưa gặp SL3 bao giờ nhỉ
Anh Minh Mobile
32-Hoàng Diệu-Eakar-Dak Lak
SL3 hiện tại các nhà support của box đang bận uống nước chè. Chưa có thiết bị nào chơi ok con này cả. Ai nói test ok. tui gửi cho vài em mà thử, được thì trả thêm 1 cái, ko được, đền thêm 1 cái cục gạch 8800 đê
ok.nếu làm đuoc , còn kg thì phại hoàn lại cho tôi cây máy khác nha. có gì liên hệ 0907133670. găp Thanh
yahoo: hoangthanhmobilee
DT : 0909168878
ấy áy các bác làm gì khích nhau ghê thế nếu người ta làm được thì 2 bên thỏa thuận giá cả vui vẻ 2 bên trời nóng mà còn xung đột không khéo "phù boar"![]()
