Kết quả 11 tới 13 của 13
    Thumbs up Tổng Hợp Clip Nhạc HD Chất Lượng Cao
    [Perf] Bang Kieu ft Lam Anh_Noi Tinh Yeu Bat Dau (720p.BluRayRip.CRF21.x264.AC3.khoianha10)
    Code:
    General
    Complete name                            : Bang Kieu ft Lam Anh_Noi Tinh Yeu Bat Dau (720p.BluRayRip.CRF21.x264.AC3.khoianha10).mkv
    Format                                   : Matroska
    Format version                           : Version 2
    File size                                : 169 MiB
    Duration                                 : 4mn 24s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 5 359 Kbps
    Encoded date                             : UTC 2012-10-04 13:23:27
    Writing application                      : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep  2 2012 15:37:04
    Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
    Video
    Format                                   : AVC
    Format/Info                              : Advanced Video Codec
    Format profile                           : High@L4.1
    Format settings, CABAC                   : Yes
    Format settings, ReFrames                : 3 frames
    Muxing mode                              : Header stripping
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 4mn 24s
    Bit rate mode                            : Variable
    Bit rate                                 : 4 613 Kbps
    Maximum bit rate                         : 14.0 Mbps
    Width                                    : 1 280 pixels
    Height                                   : 720 pixels
    Display aspect ratio                     : 16:9
    Frame rate mode                          : Constant
    Frame rate                               : 29.970 fps
    Color space                              : YUV
    Chroma subsampling                       : 4:2:0
    Bit depth                                : 8 bits
    Scan type                                : Progressive
    Bits/(Pixel*Frame)                       : 0.167
    Stream size                              : 145 MiB (86%)
    Writing library                          : x264 core 125 r2200 999b753
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=1 / weightp=1 / keyint=30 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=crf / mbtree=0 / crf=21.5 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=14000 / vbv_bufsize=14000 / crf_max=0.0 / nal_hrd=vbr / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio
    Format                                   : AC-3
    Format/Info                              : Audio Coding 3
    Mode extension                           : CM (complete main)
    Format settings, Endianness              : Big
    Codec ID                                 : A_AC3
    Duration                                 : 4mn 24s
    Bit rate mode                            : Constant
    Bit rate                                 : 640 Kbps
    Channel(s)                               : 2 channels
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 16 bits
    Compression mode                         : Lossy
    Delay relative to video                  : 8ms
    Stream size                              : 20.2 MiB (12%)
    Default                                  : Yes
    Forced                                   : No
  1. Nhận sửa XTC Clip
    By saigonmobile in forum DỊCH VỤ SỬA CHỮA BOX VÀ THIẾT BỊ
    Bài viết cuối: 11-07-2016, 14:09
  2. Video hướng dẫn Smart Clip cập nhật tại đây.
    By TuấnPhát_GSM in forum Smart Clip
    Bài viết cuối: 22-10-2010, 14:27
  3. box smart clip không nhận được phone.
    By m.phuoc1984 in forum Smart Clip
    Bài viết cuối: 12-12-2008, 19:01
  4. update smat-clip ko nhận box nữa .xin giúp đỡ
    By thu_mobile in forum Smart Clip
    Bài viết cuối: 18-10-2007, 22:29
  5. Trả lời: 2
    Bài viết cuối: 28-08-2006, 23:22
