Kết quả 1 tới 4 của 4
    Thành viên mới Tèo GSM's Avatar
    Nov 2014
    Mặc định Lumia 525h mất boot ATF chưa active jtax repair được ko các bác ?
    Lâu nay ko vọc nokia nên lúng túng mong các bác giúp đở
    Máy mở lên nokia xong vào báo lổi Erro:Unnable to find a bootable option.Press any key to shut dow.Nhà có ATF nhưng active JTAX ,xin hỏi các bác mình repair sủa lổi trên được ko hay pair active lên mới chiến được.
    Bác nào có pinout cho em xin với,Thank.
    Log Flash ATF:
    Nokia Phone Info Mode Initiated...
    Please wait upto 15 Seconds for SW Reset
    1. Press and Hold the VOLUME DOWN and POWER
    2. Wait until the Phone Reboots...
    3. Wait until you see BIG "NOKIA" Logo
    4. Stop Pressing the Buttons...
    IMEI: 356691052389521
    Version: 1.1.1.3
    Product Code: 059T4N6
    Module Code: 0205641
    Continuing Previous Boot...
    Please wait upto 30 Seconds for Boot Re-entry
    Boot Flash Mode Successful...
    Buffers Flushed OK...
    Phone Info Query Start...
    Blocks Returned: 0x07 Blocks
    Block ID 0x01 : 00241000
    Block ID 0x02 : 00240000
    Block ID 0x03 : 00E90000
    Block ID 0x05 : Nokia.MSM8227.P6083.1.2
    Block ID 0x0D : 0001
    Block ID 0x0F : 0301010100000101FF
    Block ID 0x10 : 0100130000
    Checking SD Card Size...
    Card Size: 0x00000000
    Checking Platform Security Status...
    Platform Secure Boot Status: Active
    Secure FFU EFUSE Status: Active
    Debug Status: Active
    RDC Status: Not Active
    Authentication Status: Not Active
    UEFI Secure Boot Status: Active
    Checking Secure FFU Mode...
    Secure FFU Mode :
    Query Flash App Information...
    Flash App Information: 02010F011C00
    UEFI App: FLASH APP
    Flash App Protocol Version: 1.15
    Flash App Implementation Version: 1.28
    Query ROOT KEY HASH...
    ROOT_KEY_HASH: 3676E9A0045A7EF8417B8E0E0677CED5F9DD47799826AEAE75 F7081818DE716E
    Query PUBLIC ID...
    PUBLIC_ID: 47FB6D9B05AB87F1D362B5218169100F575849ED
    Query eMMC Info...
    EMMC Manufacture ID: SAMSUNG
    EMMC Product SN : 95F8616C
    EMMC_SIZE: 8 Gigabytes
    Query Battery Charge Status...
    BATTERY CHARGE_STATUS: 49%
    Sending Image Signatures...
    ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000)
    This Flash File is NOT COMPATIBLE with this Phone.
    ERROR: Flashing Failed!
    Nov 2010
    nếu flash lại không được thì phải làm bằng jtag thôi bạn
    pinout thì nằm trong jtag có
    Thành viên kỳ cựu dungcuongmobile's Avatar
    Aug 2013
    TUYÊNQUANG
    đơn giản nhất là khi bạn mua xe máy muốn nó chạy dc thì phải mua xăng
    DUNGCUONGMOBILE
    DT: 0985139111 - 0978274475
    May 2014
    thái bình-hải dương
    tiện thể active jtag mà chiến dài dài đi bác
    thaibinhgsm@yahoo.com
    call 0976650774
