Fixed some android operations bugs
Is highly recommended to use latest NsPro version.
Latest NsPro version is available for download on
And on NsPro support areaDowload
Nspro v6.3.3 released:
-Added support for A157, C3780, E2252, S7530, SC03Dphones.
-Added support for P3100, P5100, P6200, P6800, P7100, P7300, P7500 tablets.
For more info, check the NsPro forum section: NsPro v6.3.3 released:
-Added support for A157, C3780, E2252, S7530, SC03D phones.
etc...
Latest Nspro version is available:
-On NsTeam website: : : NsPro Downloads: :
-On NsPro support area.
NsPro v6.3.4 released:
-Added I9300 IMEI repair.
-Improved I9300 unlocking protocol.
Latest NsPro version is available for download:
NsPro v6.3.5 released:
-Fixed I9300 "No Network" after IMEI repair.
-Added I9210 support
-Added SC-06D support.
No root required for I9210 and SC06D
Small installer available: this will install only the new files.
Latest NsPro version is available on:
-NsTeam website: : : NsPro Downloads: :
-NsPro support area.
NsPro v6.4.0 released: ***MAJOR OVERHAUL!!!***
-Added IMEI Repair for I9100, I9000, I9003, I9010, N7000, P1000, I777, I897, I997, T839, T849, T959, T959V
-Added Flashing support for I9300, I9100, I9210, I9070, I8160, I8530, I9000, I9003, I9010, N7000, B5510,
B5512, B7510, S5300, S5360, S5570i, S5690, S5830i, S5839i, S6102, S6802, I717, I727, I747m, I757m,
I777, I897, I997, T759, T769, T959, T959V, T989, T989D, T999, SC03D, SC06D, P1000
-Added E1200 support
Is highly recommended to use latest NsPro version!
The NsPro support area also contain small installer
-Added IMEI Repair for P5100, P3100, P6200, P6800, P7100, P7300, P7500
-Added Serial Number Repair for I9300, P5100, I9000, I9003, I9010, I9100, N7000, P1000, P3100, P6200, P6800, P7100, P7300, P7500, I777, I897, I997, T839, T849, T959, T959V
-Added Flashing support for P5100, P3100, P6200, P6800, P7100, P7300, P7500
-Improved Android unlocking protocols.
Small installer available on NsPro support area.
If you are updating from NsPro v6.3.x or v6.4.0 you can use small installer that will install only the new files on Nspro package.
Latest NsPro version is available:
-On NsTeam webpage: : : NsPro Downloads: :
-On NsPro Support area.
NsPro v6.4.2 released: ***Note2 and much more***World's First inside***
-Added N7100 Galaxy Note2 Unlocking, Flashing, IMEI Repair(first in the world) support.
-Added N8000, I927 Unlocking, Flashing, IMEI Repair support.
-Added I9250 Galaxy Nexus IMEI Repair support.
For I9250 IMEI Repair, you must modify the NsPro S7070 cable:
replace the 530K rezistor with 560K rezistor.
-Added S3350 new security support.
-Improved several Android operations.
Latest NsPro versions are available:
-Added I9305 support:
NO ROOT REQUIRED!!!
Yes! the fully tested and 100% working solution is here!
-Added Model Search function:
There are sooo many models supported by NsPro....
This function is necessary to find models easier on software list.
-Added PIT file Reading/Writing:
Have you ever needed a PIT file and cant find it anywhere?
Now NsPro offers you the possibility to read PIT file from ANY SAMSUNG ANDROID PHONE, and save it on your PC to use it later on other phones with damaged partition table.
The PIT files readed by NsPro, can be used with NsPro software, or with Odin downloader.
You are welcome to share the PIT files readed by NsPro with other users, on this forum.
-Added EFS Backup/Restore function for Android phones
You can backup EFS from your phone "just-in-case",
Or you can use a backup from a working phone to repair "Unknown Baseband" on phones with damaged EFS partition.
NsPro EFS restore function work ONLY with NsPro EFS backup files.
-Added support for ALL E1200 variants.
Is highly recommended to use latest Nspro version
-Added N7105 Galaxy Note 2 LTE Support:
Direct Unlock (NO ROOT Required), Flashing, Read/Write PIT file, EFS Backup/Restore.
World's First extended support
-Added T889 Galaxy Note 2 Support:
World's First
-Added I317 Galaxy Note 2 Support:
World's First
-Added B5330 Galaxy Ch@t Support:
World's First
-Added EFS backup/restore for I717, I727, I747m, I757m, I9210, I9305, T989, T989D, T999, SC-03D, SC-06D.
-Improved operations for many supported models.
Is HIGHLY RECOMMENDED!!! to use latest NsPro version.
Latest NsPro version can be downloaded:
-From NsTeam website: : : NsPro Downloads: :
-From NsPro support area.
