Trang 5 của 7 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 CuốiCuối
Kết quả 41 tới 50 của 70
  1. #41
    May 2011
    Hà Nội City
    Octopus Box Samsung Software v1.4.6 - public discussion thread
    Added support for the following models:
    • SGH-I957 - added Direct Unlock, Write Firmware, Read/Write/Repair NVM.
    • SGH-I957D - added Direct Unlock, Write Firmware, Read/Write/Repair NVM.
    • SGH-I957M - added Direct Unlock, Write Firmware, Read/Write/Repair NVM.
    • GT-E1050 - added Read Codes, Write Firmware, Repair IMEI, Read/Write Full Flash, Read/Write EEPROM
      (thanks to Mr. Saulcell).
    • GT-E1050I - added Read Codes, Write Firmware, Repair IMEI, Read/Write Full Flash, Read/Write EEPROM
    • Fixed Repair NVM procedure for SHW-M110S.
    • Released some improvements to the main software.
    Octopus Box team is endlessly grateful to customers who were actively involved in improving this software.
    Download Octopus Box Samsung Software v1.4.6
  2. #42
    Thành viên danh dự TuấnPhát_GSM's Avatar
    Jan 2009
    Mặc định Octopus Box Samsung Software v1.4.6 - public discussion thread
  3. ( TuấnPhát_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ĐƠ_NGUYỄN (19-06-2012)
  4. #43
    Jan 2009
    Mặc định Octopus Box Samsung Software v1.4.7 - public discussion thread
    SPH-W7900 - added Direct Unlock, Write Firmware, Read/Write/Repair NVM.
    GT-B3310 - added Read Codes, Read/Write EEPROM, Read/Write Full Flash (thanks to Mr. YASS YASS).
    GT-B3313 - added Read Codes, Read/Write EEPROM, Read/Write Full Flash (thanks to Mr. YASS YASS).
    GT-E1150 - added Read Codes, Write Firmware, Repair IMEI, Read/Write EEPROM, Read/Write Full Flash
    GT-E1150C - added Read Codes, Write Firmware, Repair IMEI, Read/Write EEPROM, Read/Write Full Flash
    GT-E1150I - added Read Codes, Write Firmware, Repair IMEI, Read/Write EEPROM, Read/Write Full Flash
    Added Reset Screen Lock (included Reset Pattern, Pin and Password Lock) for the following models:
    GT-I5500, GT-I5500B, GT-I5500L, GT-I5503, GT-I5503T, GT-I5508,
    GT-S5570, GT-S5570B, GT-S5570L, GT-S5570I, GT-S5578, GT-S5670,
    GT-S5670L, GT-S5830, GT-S5830B, GT-S5830C, GT-S5830D, GT-S5830L,
    GT-S5830T, GT-S5838, GT-I9003, GT-I9003L.
    Note: to perform Reset Screen Lock operation please turn the phone ON, connect it via micro USB cable,
    press "Reset Screen Lock" button and follow the instructions (prompts).
    Download Octopus Box Samsung Software v1.4.7
    ____________________________
    WBR,
    Octopus Box Team
  5. ( TuấnPhát_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ĐẶNG BẢO_GSM™ (22-06-2012)
  6. #44
    Jan 2007
    Octopus Box Samsung Software v1.4.8 - public discussion thread
    GT-B7510 - added Direct Unlock, Read Codes, Write Firmware, Repair IMEI,
    Read/Write/Repair NVM (thanks to Mr. YASS YASS).
    GT-I7500 - added Direct Unlock, Read Codes, Repair IMEI (thanks to Mr. YASS YASS).
    GT-I7500L - added Direct Unlock, Read Codes, Repair IMEI (thanks to Mr. YASS YASS).
    GT-E1080 - added Read Codes, Write Firmware, Repair IMEI, Read/Write Full Flash,
    Read/Write EEPROM (thanks to Mr. YASS YASS).
    GT-E1080F - added Read Codes, Write Firmware, Repair IMEI, Read/Write Full Flash,
    SCH-W860 - added Read User (Phone) Code (thanks to Mr. Code:L.A 22 for test).
    GT-I9100, GT-I9100G, GT-I9100M, GT-I9100P, GT-I9100T, GT-I9103, GT-S5690, GT-S6102,
    GT-S6102E, GT-S5360, GT-S5360B, GT-S5360L, GT-S5360T, GT-S5363, GT-S5367, GT-S5369,
    GT-B5510, GT-B5510L, GT-B5510B, GT-B5512, GT-B5512B.
    Download Octopus Box Samsung Software v1.4.8
  7. #45
    Jan 2007
  8. #46
    May 2011
    Hà Nội City
    • GT-B7510 - added Direct Unlock, Read Codes, Write Firmware, Repair IMEI,
    • GT-I7500 - added Direct Unlock, Read Codes, Repair IMEI (thanks to Mr. YASS YASS).
    • GT-I7500L - added Direct Unlock, Read Codes, Repair IMEI (thanks to Mr. YASS YASS).
    • GT-E1080 - added Read Codes, Write Firmware, Repair IMEI, Read/Write Full Flash,
    • GT-E1080F - added Read Codes, Write Firmware, Repair IMEI, Read/Write Full Flash,
    • SCH-W860 - added Read User (Phone) Code (thanks to Mr. Code:L.A 22 for test).
    • Added Reset Screen Lock (included Reset Pattern, Pin and Password Lock) for the following models:
  9. #47
    May 2011
    Hà Nội City
    Octopus Box Samsung Software v1.4.9 - public discussion thread
    • GT-I9300 - added world's first Repair IMEI, Write Firmware.
    • SGH-T999 - added Unlock, Write Firmware, Read/Write/Repair NVM (thanks to Mr. vikas kumar).
    Note! To make Repair IMEI of GT-I9300 You have to perform the following steps:
    1. Write "GT-I9300_for_Repair_IMEI.oct" firmware from the support area
    2. Write "GT-I9300_Root" firmware from the support area to root the phone
    3. Connect phone to PC via Micro USB cable
    4. Install required driver
    5. Type correct IMEI
    6. Click "IMEI fix" button
    7. Follow software instructions (prompts)
    Note! During Repair IMEI procedure you'll have to reconect phone to USB and UART ports (follow software instructions). Thus you'll need to have both Micro USB and Samsung Micro UART cables.
    Also note: after repair IMEI procedure, you have to wait 2-3 minutes for network signal to appear. Also, network signal will be available only with this fimware (phone will have no network after reflash with other firmwares)!
    Download Octopus Box Samsung Software v1.4.9
  10. #48
    Jan 2007
    Octopus Box Samsung Software v1.5.0 - public discussion thread
    GT-I9300 - improved Repair IMEI procedure - no need to write special firmware.
    GT-I9300T - added Repair IMEI - no need to write special firmware.
    GT-C6712 - added Direct Unlock, Read Codes, Write Firmware (thanks to Mr. YASS YASS).
    Note! To Repair IMEI of GT-I9300 or GT-I9300T you'll have to perform following procedure:
    Write "GT-I9300_Root" firmware from the support area in order to root the phone.
    Connect the phone to PC via Micro USB cable.
    Install required driver.
    Enter correct IMEI.
    Click "IMEI fix" button.
    Follow software instructions (prompts).
    Important! During Repair IMEI procedure you'll have to reconnect the phone to USB and UART ports
    aka Samsung C3300k with 525k resistor. You'll find cable schematics in the software manual
    (just press "Help" button).
    Please be aware that after Repair IMEI procedure you'll have to wait 2-3 minutes for network signal to appear.
    Download Octopus Box Samsung Software v1.5.0
  11. #49
    May 2011
    Hà Nội City
    Octopus Box Samsung Software v1.5.1 - I747M, S5300, E2210L and more!
    • SGH-I747M - added Direct Unlock, Write Firmware (thanks to Mr. Maazi and wait for NVM).
    • GT-S5300 - added Direct Unlock, Write Firmware, Repair IMEI, Reset Screen Lock
      (included Reset Pattern, Pin and Password Locks).
    • GT-E1130B - added Read Codes, Write Firmware, Repair IMEI, Read/Write Full Flash
    • GT-E2210L - added Read Codes, Write Firmware, Repair IMEI, Read/Write Full Flash
    • YP-G70 - added Write Firmware (thanks to Mr. YASS YASS).
    Download Octopus Box Samsung Software v1.5.1
  12. #50
    May 2011
    Hà Nội City
    Octopus Box Samsung Software v1.5.2 - SC-05D, I8160, T589 and more!
    • SC-05D - added Direct Unlock, Write Firmware, Read/Write/Repair NVM.
    • GT-I8160 - added Direct Unlock, Write Firmware, Repair IMEI.
    • SGH-I747D - added Direct Unlock, Write Firmware, Read/Write/Repair NVM.
    • SGH-T999V - added Direct Unlock, Write Firmware, Read/Write/Repair NVM.
    • SGH-T589 - added Direct Unlock, Repair IMEI.
    • SGH-T589R - added Direct Unlock, Repair IMEI.
    • SGH-I747M - added Repair NVM.
    • SGH-T589R - fixed Read Codes procedure.
    Note: in order to unlock GT-I8160 you have to root the phone first
    (please refer to the software manual for instructions).
    Download Octopus Box Samsung Software v1.5.2
  13. ( ĐẶNG BẢO_GSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Tempb (20-07-2012)
  1. Octoplus/Octopus Box Samsung v1.7.2 - added Samsung factory unlock
    By toilatoi142001 in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 24-10-2014, 14:04
  2. Octoplus/Octopus Box Samsung v1.3.5 - world's fist support for Samsung SGH-I257!
    Bài viết cuối: 28-09-2013, 10:18
  3. Octopus Box LG v2.4.0 & Octopus Box Samsung v1.7.8
    By Lính Khang in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 01-02-2013, 22:21
  4. Octopus Box Samsung Software v1.6.7 – added a wide range of Samsung mobile phones!
    Bài viết cuối: 02-11-2012, 22:31
  5. RIFF JTAG - Samsung S3370, Samsung C5510 updates
    By TuấnPhát_GSM in forum RIFFBOX
    Bài viết cuối: 15-09-2010, 17:56
