Trang 16 của 19 Đầu tiênĐầu tiên ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 CuốiCuối
Kết quả 151 tới 160 của 186
    Jan 2007
    Octoplus/Octopus Box LG v.2.7.9 is out! New models and improvements added!
    Octoplus/Octopus Box LG Software v.2.7.9 Release Notes:
    Added support for the following models:
    - M322 - added Direct Unlock, Repair IMEI, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Write/Reset Security, Repair BT/Wi-Fi MAC Address, Read Full Flash (thanks to Mr. etor)
    - M703 - added Direct Unlock, Repair IMEI, Write Firmware, Read/Write QCN, Read/Write NVM, Read/Write/Reset Security, Repair BT/Wi-Fi MAC Address, Read Full Flash
    - M703PR - added Direct Unlock, Repair IMEI, Write Firmware, Read/Write QCN, Read/Write NVM, Read/Write/Reset Security, Repair BT/Wi-Fi MAC Address, Read Full Flash (thanks to Mr. Truenogts)
    - H970 - added Direct Unlock (test), Repair IMEI (test), Read/Reset Security, Read/Write QCN, Read/Write NVM, Repair BT/Wi-Fi MAC Address, Read Full Flash, Reset FRP (tested on V10B-EUR-XX-OCT-20-2017+0 firmware) (thanks to Mr. YASS YASS)
    - V33 - added Direct Unlock, Repair IMEI, Write Firmware, Read/Write QCN, Read/Write NVM, Read/Write/Reset Security, Repair BT/Wi-Fi MAC Address, Read Full Flash (thanks to Mr. GSM::Boiragi:)
    - MS428 - added Write Firmware
    - M430 - added Write Firmware
    - M470, M470F - added Write Firmware
    - M700, M700A, M700AN, M700AR, M700B, M700DSK, M700DSN, M700F, M700H, M700N, M700TV, M700Y, M700Z - added Write Firmware
    - H870, H870DS, H870DSU, H870K, H870S, H870U, H870V - added Reset FRP via TestPoint Method
    - VS500, VS500PP - added Reset Screen Lock (tested on Android 6.0.1 firmware) (thanks to Mr. chipscell25)
    Improved Unlock operation for LS775 (thanks to Mr. D. Dragon)
    All supported operations are described in details in Software manual ("Cable & Manual" button in Software)
    [INDENT]
    Download Octoplus/Octopus Box LG v.2.7.9
    Jan 2007
    Octoplus/Octopus Box LG v.2.8.0 is out!
    Added Unlock via server for LG TMB (with “Device Unlock App") devices and more!
    Octoplus/Octopus Box LG Software v.2.8.0 Release Notes:
    - H345 - added Unlock via server (without erasing/wiping data, need root)
    - MS345 - added Unlock via server (without erasing/wiping data, need root)
    - H631 - added Unlock via server (without erasing/wiping data, need root)
    - MS631 - added Unlock via server (without erasing/wiping data, need root)
    - H811, H811VK - added Unlock via server (without erasing/wiping data, need root)
    - K330 - added Unlock via server (without erasing/wiping data, need root)
    - MS330 - added Unlock via server (without erasing/wiping data, need root)
    - K428 - added Unlock via server (without erasing/wiping data, need root)
    - MS428 - added Unlock via server (without erasing/wiping data, need root)
    - K550, K550BN, K550BNGO1 - added Unlock via server (without erasing/wiping data, need root)
    - MS550 - added Unlock via server (without erasing/wiping data, need root)
    - M210 - added Unlock via server (without erasing/wiping data, need root)
    - MS210 - added Unlock via server (without erasing/wiping data, need root)
    - MP260 - added Unlock via server (without erasing/wiping data, need root)
    - TP260 - added Unlock via server (without erasing/wiping data, need root)
    - MP450 - added Unlock via server (without erasing/wiping data, need root)
    - TP450 - added Unlock via server (without erasing/wiping data, need root)
    - X210MA - added Unlock via server (without erasing/wiping data, need root, in test mode)
    - H901 - added Unlock via server (without erasing/wiping data, need root, in test mode)
    - H918 - added Unlock via server (without erasing/wiping data, need root, in test mode)
    - H932, H932U - added Unlock via server (without erasing/wiping data, need root, in test mode)
    - H830 - added Unlock via server (without erasing/wiping data, need root, in test mode)
    - H872 - added Unlock via server (without erasing/wiping data, need root, in test mode)
    - H870AR, H870I - added world's first Direct Unlock, Repair IMEI A, Reset FRP, Write Firmware, Read/Write NVM, Read/Write QCN, Read/Reset Security, Repair BT/W-Fi MAC Address, Read Full Flash
    - US610 - added Repair IMEI, Write Firmware, Read/Write NVM, Read/Write QCN, Read/Write/Reset Security, Reset FRP, Reset Screen Lock, Read Full Flash, Repair MEID, Read/Write PRL, Repair AKEY/SSD_A/SSD_B/OTKSL/SPC (thanks to Mr. himig_natin)
    - X220DSH - added Direct Unlock, Repair IMEI A/B, Read Codes, Write Firmware, Reset FRP, Read/Write Full Flash, Read Info (thanks to Mr. leandro_grilo)
    - F720K, F720L, F720S - added Reset FRP (thanks to Mr. saeedullah_khan)
    - M700TV - added Repair IMEI B
    Improved Read Codes and Direct Unlock operations for LG X240 (thanks to Mr. kent99)
    Promo period:
    from 22.02.2018 till 31.03.2018 – LG TMB “Unlock” operation will take only 115 Octopus/Octoplus credits.
    Postpromo period:
    from 01.04.2018 – LG TMB “Unlock” operation will take 185 Octopus/Octoplus credits.
    You can buy Octopus/Octoplus Server Credits from your local reseller or directly HERE.[INDENT]
    Download Octoplus/Octopus Box LG v.2.8.0
    Jan 2007
    Octoplus/Octopus Box LG v.2.8.1 is out! Added world's first support for the latest firmwares for LG K10 2017, X Power 2, Stylus 3 and more!
    As you know, Octoplus Team developed most of main unique Reset FRP solutions for Samsung (UART methods) and LG devices. We continue to work hard to provide Octoplus users with the best experience and solutions for mobile phones servicing. In this update, we are proud to present a new world's first Reset FRP, Repair IMEI and Direct Unlock solution for MediaTek CPU-based devices for the latest firmware versions! From now on, mentioned operations are supported for all available firmware versions and for all security patch levels! There is no need in risky firmware downgrade - all operations can be performed directly!
    Octoplus/Octopus Box LG Software v.2.8.1 Release Notes:
    🐙 Released new world's first Reset FRP, Repair IMEI and Unlock solutions (from now on, these operations work for all firmware versions and latest security patch levels) for the next MediaTek CPU-based devices:
    - M250, M250AR, M250E, M250F, M250H, M250N, M250Y, M250YK
    - M250DS, M250DSN, M250I, M250K, M250M
    - M320AR, M320F, M320N, M320H, M320K
    - M320, M320DSN, M320TV
    - M400AR, M400F, M400MT, M400Y
    - M400DF, M400DK, M400DY, M400N
    🐙 Added support for the following models:
    - K121K - added Unlock, Read Codes, Repair IMEI, Repair BT/Wi-Fi MAC Address, Write Firmware, Read/Write EEPROM, Reset FRP, Read Full Flash, Read Info, Factory Reset (for Factory Reset Status 2)
    - K121L - added Unlock, Read Codes, Repair IMEI, Repair BT/Wi-Fi MAC Address, Write Firmware, Read/Write EEPROM, Reset FRP, Read Full Flash, Read Info, Factory Reset (for Factory Reset Status 2)
    - K121S - added Unlock, Read Codes, Repair IMEI, Repair BT/Wi-Fi MAC Address, Write Firmware, Read/Write EEPROM, Reset FRP, Read Full Flash, Read Info, Factory Reset (for Factory Reset Status 2)
    - X210MA - added Repair IMEI, Write Firmware, Read/Write NVM, Read/Write QCN, Read Security, Read Full Flash (thanks to Mr. mysty619)
    - X230DSV - Direct Unlock (in a test mode), Read Codes, Repair IMEI (A/B), Write Firmware, Reset FRP, Read / Write Full Flash
    - DM-02H (DS1604) - added Repair IMEI, Read/Write/Reset Security, Read/Write NVM, Read/Write QCN, Repair BT / Wi-Fi MAC Address, Reset FRP, Read Full Flash (thanks to Mr. mimarijaz71)
    🐙 Some adjustments and improvements were made.
    🐙All supported operations are described in details in Software manual ("Cable & Manual" button in Software)
    Download Octoplus/Octopus Box LG v.2.8.1
    Jan 2007
    Octoplus/Octopus Box LG v.2.8.2 is out! New unique world's first Reset FRP solution for LG V20, G6, G5 and more!
    As you remember, in previous update Octoplus Team released new world's first Reset FRP solution for MediaTek CPU-based LG devices that work for all firmware versions and latest security patch levels. We continue to work hard to provide Octoplus users with the best experience and solutions for mobile phones servicing. In this update, once more we are proud to present a new world's first Reset FRP solution (from Download Mode) for newest LG devices! From now on, “Reset FRP” operation is supported for all available firmware versions and for all security patch levels! There is no need in risky firmware downgrade - all operations can be performed directly!
    Octoplus/Octopus Box LG Software v.2.8.2 Release Notes:
    🐙 Released new unique world's first Reset FRP solution (via Download Mode), that works for all firmware versions and latest security patch levels for the next LG devices:
    LG V20 Series:
    - H910, H910PR
    - H915
    - H918
    - H990, H990DS, H990N, H990T, H990TR
    - LS997
    - VS995
    - US996
    - F800K, F800L, F800S
    LG G6 Series:
    - H871
    - H872, H872PR
    - H873
    - G600K, G600L, G600S, G600KP, G600LP, G600SP
    - LS993
    - VS988
    LG G5 Series:
    - H820, H820PR
    - H830, H830SV
    - H831
    - H850, H850AR, H850K, H850TR
    - H858
    - H860, H860N
    - H868
    - LS992
    - US992
    - VS987
    - RS988
    - F700K, F700L, F700S
    - X320K - added world's first Direct unlock, Read Codes, Repair IMEI, Repair BT/Wi-Fi MAC address, Read/Write EEPROM, Read Full Flash, Reset FRP, Write Firmware, Factory Reset (for Factory Reset Status 2), Read Info
    - X320L - added world's first Direct unlock, Read Codes, Repair IMEI, Repair BT/Wi-Fi MAC address, Read/Write EEPROM, Read Full Flash, Reset FRP, Write Firmware, Factory Reset (for Factory Reset Status 2), Read Info
    - X320S - added world's first Direct unlock, Read Codes, Repair IMEI, Repair BT/Wi-Fi MAC address, Read/Write EEPROM, Read Full Flash, Reset FRP, Write Firmware, Factory Reset (for Factory Reset Status 2), Read Info
    - X600K - added world's first Direct Unlock, Repair IMEI, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash, Repair BT/Wi-Fi MAC Address, Write Firmware, Reset FRP (via Test Point, all firmware versions and latest security patch levels are supported)
    - X600L - added world's first Direct Unlock, Repair IMEI, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash, Repair BT/Wi-Fi MAC Address, Write Firmware, Reset FRP (via Test Point, all firmware versions and latest security patch levels are supported)
    - X600S - added world's first Direct Unlock, Repair IMEI, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash, Repair BT/Wi-Fi MAC Address, Write Firmware, Reset FRP (via Test Point, all firmware versions and latest security patch levels are supported) (thanks to Mr. Denozaur)
    - X600KP - added world's first Direct Unlock, Repair IMEI, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash, Repair BT/Wi-Fi MAC Address, Write Firmware, Reset FRP (via Test Point, all firmware versions and latest security patch levels are supported)
    - X600LP - added world's first Direct Unlock, Repair IMEI, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash, Repair BT/Wi-Fi MAC Address, Write Firmware, Reset FRP (via Test Point, all firmware versions and latest security patch levels are supported)
    - X600SP - added world's first Direct Unlock, Repair IMEI, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash, Repair BT/Wi-Fi MAC Address, Write Firmware, Reset FRP (via Test Point, all firmware versions and latest security patch levels are supported)
    - LS993 - added world's first Reset FRP (via Test Point, all firmware versions and latest security patch levels are supported)
    🐙 All supported operations are described in details in Software manual ("Cable & Manual" button in Software)
    Download Octoplus/Octopus Box LG v.2.8.2
    [INDENT]
    Jan 2007
    Octoplus/Octopus Box LG v.2.8.3 is out! Added world's first support for LG V30+ and V30 Series and more!
    Octoplus/Octopus Box LG Software v.2.8.3 Release Notes:
    - H930 - added world's first Direct unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash
    - H930G - added world's first Direct unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash (thanks to Mr. -=MR_Gsm=-)
    - H930DS - added world's first Direct unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash (thanks to Mr. project-luminol)
    - H930K - added world's first Direct unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash
    - H931 - added world's first Direct unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash
    - H932 - added Repair IMEI, Write Firmware, Reset FRP, Read/Write QCN, Read/Write NVM, Reset Security (thanks to Mr. cafonabob1)
    - H932U - added Repair IMEI, Write Firmware, Reset FRP, Read/Write QCN, Read/Write NVM, Reset Security
    - H932PR - added world's first Repair IMEI, Write Firmware, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash
    - H932SV - added world's first Repair IMEI, Write Firmware, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash
    - H933 - added world's first Direct unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash
    - V300K - added Direct unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash (in a test mode)
    - V300L - added Direct unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash (in a test mode)
    - V300S - added Direct unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash (in a test mode)
    - SP320 - added world's first Repair IMEI, Repair BT/Wi-Fi MAC Address, Write Firmware, Reset FRP, Read/Write EEPROM, Read Full Flash, Read Info
    - VS835 - added Repair IMEI, Repair BT/Wi-Fi MAC Address, Write Firmware, Reset FRP, Read/Write EEPROM, Read Full Flash, Read Info
    Note: Reset FRP operation for the above mentioned V30+ and V30 devices is a unique world's first solution, that works via Download Mode and supports all firmware versions and latest security patch levels!
    Download Octoplus/Octopus Box LG v.2.8.3
    Jan 2007
    Octoplus/Octopus Box LG v.2.8.4 is out! Added world's first Reset FRP solution (from Download Mode) for a wide range of Qualcomm CPUs-based LG devices!
    Octoplus Team continues to work hard to provide Octoplus users with the best experience and solutions for mobile phones servicing. In this update, once more we are proud to present another new unique world's first Reset FRP solution (from Download Mode) for the following series of Qualcomm CPUs-based LG devices! From now on, “Reset FRP” operation is supported for all available firmware versions and for all security patch levels! There is no need in risky firmware downgrade - all operations can be performed directly!
    Octoplus/Octopus Box LG Software v.2.8.4 Release Notes:
    🐙 Released new world's first unique Reset FRP solution (from now on, these operations work for all firmware versions and latest security patch levels) for the wide range of Qualcomm CPUs-based LG devices. This method was tested on the next devices:
    - K120K, K120L, K120S
    - M200E, M200N
    - M255
    - M257, M257PR
    - M320G
    - M322
    - M327
    - M430
    - M470, M470F
    - M210
    - MS210
    - MP260
    - TP260
    - MP450
    - TP450
    - X210MA
    Note: new "Reset FRP" method was added and works for other Qualcomm CPUs-based LG devices not listed above. So, if you own these devices, try to perform “Reset FRP” operation and share the report.
    - X800K - added world's first Direct unlock (test), Repair IMEI, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash
    - X800L - added world's first Direct unlock (test), Repair IMEI, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash (thanks to Mr. pintu_das)
    - X800S - added world's first Direct unlock (test), Repair IMEI, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash
    🐙 Improved “Write security backup” operation for all Qualcomm CPUs-based LG devices.
    [INDENT][INDENT][INDENT][INDENT]Download Octoplus/Octopus Box LG v.2.8.4
    Jan 2007
    Octoplus/Octopus Box LG v.2.8.8 is out! 🐙
    Octoplus/Octopus Box LG Software version 2.8.8 is out! New models added!
    Octoplus/Octopus Box LG Software v.2.8.8 Release Notes:
    - AS992 - added Write Firmware, Repair IMEI, Repair BT/Wi-Fi MAC Address, Repair MEID, Read/Write PRL, Repair AKEY/SSD_A/SSD_B/OTKSL/SPC, Read/Reset Security, Read/Write QCN, Read/Write NVM, Reset FRP, Read Full Flash (thanks to Mr. Ismail khan1978)
    - LMX212TA - added Direct Unlock (via server), Repair IMEI, Reset FRP, Read/Write Security, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash (thanks to Mr. mobilaemmanuel)
    - LMX212TAL - added Direct Unlock (via server), Repair IMEI, Reset FRP, Read/Write Security, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash
    - LMX210YMW - added Unlock, Read/Write/Reset Security, Repair IMEI (A/B), Reset FRP, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash
    - US998U (V30+) - added Repair IMEI/MEID, Repair BT/Wi-Fi Mac Address, Repair AKEY/SSDA/SSDB/OTKSL/SPC, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Write Firmware, Read Full Flash
    - US998R (V30S ThinQ) - added Repair IMEI/MEID, Repair BT/Wi-Fi Mac Address, Repair AKEY/SSDA/SSDB/OTKSL/SPC, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Write Firmware, Read Full Flash
    - V300KR (V30S ThinQ) - added Direct Unlock, Repair IMEI, Reset FRP, Read/Reset Security, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash
    - V300KW (V30S+ ThinQ) - added Direct Unlock, Repair IMEI, Reset FRP, Read/Reset Security, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash
    - V300LW (V30S+ ThinQ) - added Direct Unlock, Repair IMEI, Reset FRP, Read/Reset Security, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash
    - V300SW (V30S+ ThinQ) - added Direct Unlock, Repair IMEI, Reset FRP, Read/Reset Security, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash
    - D850, D850PR - added Factory Reset (for reset status 2, 3)
    - D851, D851TN, D851WH - added Factory Reset (for reset status 2, 3)
    - D852, D852G - added Factory Reset (for reset status 2, 3)
    🐙 Added Reset FRP for Android 8.x firmwares* w/o Test Point for the next devices:
    - H930, H930DS, H930G, H930K
    - AS998
    - LS998 (thanks to Mr. maxpatri9)
    - US998
    - VS996
    - V300K, V300L, V300S
    - H870, H870K, H870S, H870V, H870DS, H870AR, H870I
    - H873
    - G600K, G600L, G600S, G600KP, G600LP, G600SP, G600KR, G600LR, G600SR
    - AS993
    - LS993
    - VS988
    *Note: Operation may not work for some Android 8.x firmwares. In this case you can perform “Reset FRP” operation via Test Point.
    🐙 “Write Firmware” operation improved for most devices - from now on up to 40% faster!
    🐙 Improved “Reset FRP” operation for SP200, SP320, US601, X210ULMA.
    Download Octoplus/Octopus Box LG v.2.8.8
    Jan 2007
    Octoplus/Octopus Box LG Software version 2.8.9 is out! Added world's first support for G7 ThinQ, V35 ThinQ, X2 2018 series and more!
    Octoplus/Octopus Box LG Software v.2.8.9 Release Notes:
    - G710AWMH - added world's first Write Firmware (“*.kdz”, “*.oct”), Reset FRP*, Read/Write QCN, Read/Write NVM, Factory Reset
    - G710EM - added world's first Write Firmware (“*.kdz”, “*.oct”), Reset FRP*, Read/Write QCN, Read/Write NVM, Factory Reset
    - G710EMW - added world's first Write Firmware (“*.kdz”, “*.oct”), Reset FRP*, Read/Write QCN, Read/Write NVM, Factory Reset
    - V350AWM - added world's first Write Firmware (“*.kdz”, “*.oct”), Reset FRP*, Read/Write QCN, Read/Write NVM, Factory Reset
    - V350ULM - added world's first Write Firmware (“*.kdz”, “*.oct”), Reset FRP*, Read/Write QCN, Read/Write NVM, Factory Reset
    - LMX210IMW - added Unlock, Repair IMEI (A/B), Write Firmware, Reset FRP, Read/Write/Reset Security, Read/Write QCN, Read/Write NVM, Read Full Flash
    - X210K - added world's first Unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write/Reset Security, Read/Write QCN, Read/Write NVM, Read Full Flash
    - X210L - added world's first Unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write/Reset Security, Read/Write QCN, Read/Write NVM, Read Full Flash
    - X210S - added world's first Unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write/Reset Security, Read/Write QCN, Read/Write NVM, Read Full Flash
    - VS987 - added Write Firmware
    - VS988 - added Write Firmware
    *: via Test Point, all firmware versions and latest security patch levels are supported, Test Point picture is included in Software manual.
    🐙 Improved Write Firmware for LG Q6 M700 series.
    🐙 Improved Reset FRP for SP200.
    Download Octoplus/Octopus Box LG v.2.8.9
    Jan 2007
    Octoplus/Octopus Box LG Software version 2.9.0 is out!
    Added Unlock operation for M150 V20x, X210CM/APM, Sprint LS992 ZVC/ZVD/ZVE/ZVF, LS993 ZV9/ZVA and more!
    Octoplus/Octopus Box LG Software v.2.9.0 Release Notes:
    🐙 Added "Unlock" (via server, requires 50 credits) for the latest security type/firmware versions for the following devices:
    - M150
    - M151
    - M153
    - M154
    - LMX210APM, LMX210CM
    - LMX410CS
    Added "Unlock"* (via server, requires 50 credits) for the following devices:
    - LS992 (ZVC, ZVE, ZVD, ZVF firmware versions)
    - LS993 (ZV9, ZVA firmware versions)
    *Note: after unlocking you can perform Factory Data Reset operation via phone's menu, or update firmware and the device will remain unlocked.
    If you perform "Wipe" operation via recovery mode, phone's security will be reset and the device will get back to locked state!
    - LMX210FM - added Direct Unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write/Reset Security, Read/Write QCN, Read/Write NVM, Read Full Flash
    - LMX210HM - added Direct Unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write/Reset Security, Read/Write QCN, Read/Write NVM, Read Full Flash
    - LMX210ZM - added Direct Unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write/Reset Security, Read/Write QCN, Read/Write NVM, Read Full Flash
    - DM-02H - added Read/Write Firmware (thanks to Mr. lerner)
    - AS375 - added added Repair IMEI, Write Firmware, Reset FRP, Read/Write/Reset Security, Read/Write QCN, Read/Write NVM, Read Full Flash (thanks to Mr. asadnow2k)
    🐙 Improved "Reset FRP" operation for SP200 and SP320.
    🐙 Improved "Reset FRP" operation via "Qualcomm...9008" Mode for LG G6 and V30 series.
    Download Octoplus/Octopus Box LG v.2.9.0
    [INDENT][INDENT][INDENT][INDENT][INDENT]
    Jan 2007
    Octoplus/Octopus Box LG Software version 2.9.1 is out!
    Added custom flashing and more!
    Octoplus/Octopus Box LG Software v.2.9.1 Release Notes:
    🐙 Released custom flashing possibility for MTK and Qualcomm CPU-based devices (supported "*.dz", "*.kdz", "*.oct" firmwares with LAF partition). From now on, you can select firmware file, select (mark) partitions that you want to write, and write only these selected partitions! Also, added possibility to skip formatting Userdata before flashing firmware.
    The sequence of writing firmware:
    1. Select firmware file.
    2. Press "Write firmware" button.
    3. Connect the device (put it into Download Mode) according to Software instructions (prompts).
    4. In the appearing window select (mark) necessary partitions that you want to write, and press "Write" button.
    5. Skip or allow formatting Userdata and continue the operation.
    - G710PM - added Write Firmware ("*.kdz", "*.oct"), Read/Write QCN, Read/Write NVM, Reset FRP (via TP) (thanks to Mr. ahmertelecom)
    - LMX410EO - added Read Codes (works for Android 7.x firmware only), Write Firmware
    - LMX410EOW - added Read Codes (works for Android 7.x firmware only), Write Firmware
    - LMX410FC - added Read Codes (works for Android 7.x firmware only), Write Firmware (thanks to Mr. maxpatri9)
    - LMX410FO - added Read Codes (works for Android 7.x firmware only), Write Firmware
    - LMX410NCW - added Read Codes (works for Android 7.x firmware only), Write Firmware
    - LMX410YCW - added Read Codes (works for Android 7.x firmware only), Write Firmware
    - F750K - added Factory Reset (thanks to Mr. lerner_)
    🐙 Improved "Unlock" operation for M153.
    🐙 Improved "Write EEPROM" operation for MTK CPUs-based devices.
    [INDENT][INDENT][INDENT][INDENT]Download Octoplus/Octopus Box LG v.2.9.1
  1. Octoplus Box Samsung new update!
    By ThanhHaMobile™ in forum Octopus/Octoplus Box
    Trả lời: 194
    Bài viết cuối: 13-11-2025, 21:55
  2. Octoplus/Octopus Suite new update!
    Trả lời: 52
    Bài viết cuối: 11-10-2018, 23:44
  3. Octoplus/Octopus Box Samsung v1.3.6 - starring Galaxy Tab 3 7.0!
    By toilatoi142001 in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 05-10-2013, 10:08
  4. Octoplus/Octopus Box LG v1.2.2 - LG E981H, and much more...
    By thanhtunggialai™ in forum Octopus/Octoplus Box
    Bài viết cuối: 02-08-2013, 22:21
  5. Octoplus/Octopus Shell Software update!
    Bài viết cuối: 02-07-2013, 16:58
