Trang 9 của 13 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 10 11 12 13 CuốiCuối
Kết quả 81 tới 90 của 129
  1. #81
    Jan 2007
    Octoplus Box JTAG PRO Software v.1.1.2 is out
    [/URL]
    Octoplus JTAG PRO Software v.1.1.2 is out!
    We have added support for LG G3, Samsung Galaxy Note 10.1, Samsung Galaxy Mega 6.3 and Samsung Galaxy Ace 4!
    Octoplus Box JTAG PRO Software v.1.1.2 Release Notes:
    🐙 Added support for the following models via eMMC:
    • LG F460K - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung GT-N8000 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SGH-I527M - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files.
    • Samsung GT-I9205 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SM-G357FZ - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    🐙 All pinouts and repair procedures described in the manual ("Help" button in the Software)
    Download Octoplus JTAG PRO Software v.1.1.2
  2. #82
    Jan 2007
    Octoplus JTAG PRO Software v.1.1.4. LG Factory Repair feature has been released!
    [INDENT]Octoplus JTAG PRO Software v.1.1.4 is out!
    Octoplus Box JTAG PRO Software v.1.1.4 Release Notes:
    🐙 Added LG Factory Repair feature!
    ....You can try to repair LG devices via eMMC by using original LG firmware * («*.tot", "*.kdz" and "*.dz" versions of firmware are supported!).
    ....This feature can be useful in case, if you haven’t got the working device to prepare Repair file or haven’t got a chance to read out Full flash; or device you want to repair currently is not supported.
    🐙 Fixed and improved Content Extractor.
    ....- Fixed GUI delay while analyzing contacts, SMS and pictures.
    ....- Fixed issue with contacts’ export to VCF file.
    ....- Increased stability of FS analysis.
    ....- Increased speed of FS reading and parsing directly from the device.
    🐙 Added Win XP SP3 support (in test mode).
    🐙 Made some GUI changes.
    🐙 Updated repair file for LG LS991 (please re-download SRF file).
    * NOTE: not all versions of firmware contain necessary partitions for repairing! Try to write different firmware.
    https://www.youtube.com/watch?v=pGvVjqx_G0o
    [INDENT]
    Download Octoplus JTAG PRO Software v.1.1.4
  3. #83
    Jan 2007
    Octoplus JTAG PRO Software v.1.1.5. New Samsung phones have been added [HR][/HR]
    [INDENT]Octoplus JTAG PRO Software v.1.1.5 is out!
    We have added support for Samsung Galaxy Core Prime, Samsung Galaxy J1, Samsung Galaxy J1 Mini, Samsung Z1, Samsung Z3 Tizen and Samsung Galaxy Tab 4 8.0!
    Octoplus Box JTAG PRO Software v.1.1.5 Release Notes:
    • Samsung SM-G360T1 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SM-J100H - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SM-J105H - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SM-Z130H - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SM-Z300H - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SM-T337T - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    Added LG Factory Repair via USB and JTAG interfaces ("*.tot", "*.kdz" and "*.dz" firmware versions are supported)
    Added support for new type of KDZ firmware with "*.dz" files inside
    [INDENT]
    Download Octoplus JTAG PRO Software v.1.1.5
  4. #84
    Jan 2007
    Octoplus JTAG PRO v.1.1.6 is out!
    [INDENT]
    Octoplus JTAG PRO Software v.1.1.6 is out!
    Samsung Factory Repair feature has been released!
    Octoplus Box JTAG PRO Software v.1.1.6 Release Notes:
    🐙 Added Samsung Factory Repair feature!
    You can try to repair Samsung devices via eMMC by using original Samsung firmware * ("*.tar", "*.md5" versions of firmware are supported!).
    🐙 Improved Content Extractor:
    - Increased speed of FS analysis, reading and parsing data from device
    - Fixed issue with pictures preview
    🐙 Box firmware has been updated! To update firmware, it is necessary to connect the Box and only then run the Software.
    🐙 All pinouts and repair procedures described in the manual ("Help" button in the software)
    [INDENT]
    Download Octoplus JTAG PRO Software v.1.1.6
  5. #85
    Jan 2007
    Octoplus JTAG PRO v.1.1.7 - introducing resize/repartition!
    [INDENT]Octoplus JTAG PRO Software v.1.1.7 is out!
    Resize/Repartition feature and ADB tool have been released!
    Octoplus Box JTAG PRO Software v.1.1.7 Release Notes:
    • Released Resize/Repartition feature - possibility to resize/repartition eMMC flash with EFI partition table! One button click only!
      This new feature is important and should be used when you decide to replace your flash memory, use another chip with bigger or less flash memory size.
      Also, Resize/Repartition feature will come handy when you performed recovery operation and want the device to recognize the amount of available memory correctly.
      For example, you have a device with 16GB flash chip and corresponding restore file, created with the same device, with the same amount of memory – also 16GB.
      You changed the original flash chip on another flash chip with bigger capacity – 32GB and performed the restore operation, using recovery file (Repair File), which has been created on a similar device with 16GB flash memory size.
      As a result, after recovery operation, device will recognize 16GB only of new flash memory chip. To be able to access all 32GB on your new chip you have to perform Resize/Repartition operation!
      Note: Not all versions of firmware support repartition/resize operation.
      To perform Resize/Repartition do the following:
      - Connect device via eMMC
      - Go to «eMMC service» tab
      - Press «Resize/Repartition» button
      - Press «Autorepartition» button - software will perform Resize/Repartition operation with the real (maximum available) flash size
      - Or press «Set size» button - software will perform Resize/Repartition operation with custom size, which you have set in bytes
      - After «Resize/Repartition» ends make Factory Data reset from phone Settings.
    • Released ADB tool - possibility to read flash via ADB interface!
      To work with ABD complete the following steps:
      - Root device
      - Turn on USB Debugging Mode in the menu of the device
      - Install necessary ADB drivers
      - Select «ABD» interface in the software
      - Press «Connect» button in the software to connect device via ADB and read device info
      After successfully connection you will able to:
      - Read necessary device partitions (software will automatically detect the device partitions, if they are not damaged or partition table is present).
      You can read selected partitions into «*.mpt» file or into separate binary («*.bin») files (just select «Read each partition into separate binary («*.bin») file» option in the software before read).
      - Read Full Flash.
      - Read custom flash (with size that you required).
    • Improved Content Extractor:
      - Fixed contacts search operation for old Android versions (for old Android versions it is necessary to uncheck «Parse user data only» option in the software).
      - Fixed the incorrect showing process progress of software Progress Bar for some operations.
      - Fixed «Cancel» button operation problem in some cases.
      - Increased parsing data speed.
    • All pinouts and repair procedures described in the manual ("Help" button in the software)
    [spoiler="Reading via ADB"]
    [/spoiler]
    [spoiler="Resizing"]
    [/spoiler][INDENT]
    Download Octoplus JTAG PRO Software v.1.1.7
  6. #86
    Jan 2007
    Octoplus JTAG PRO v.1.1.8 - LG G3, Samsung Galaxy Grand, Galaxy Note and more!
    [/URL][INDENT]
    Octoplus JTAG PRO Software v.1.1.8 is out!
    We have added support for LG G3, Samsung Galaxy Grand, Samsung Galaxy Note, Samsung Galaxy S III.
    Octoplus Box JTAG PRO Software v.1.1.8 Release Notes:
    ������ Added support for the following models via eMMC:
    • LG D855 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung GT-I9082 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung GT-I9228 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung GT-N7000 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SCH-I535 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    ������ Added UFS support via ADB interface (Read necessary device partitions, Read Full Flash, Read Custom Flash (with the required size))
    ������ All pinouts and repair procedures described in the manual ("Help" button in the Software)
    [INDENT][INDENT]Download Octoplus JTAG PRO Software v.1.1.8
  7. #87
    Jan 2007
    Octoplus JTAG PRO v.1.1.9 - Galaxy S5, J3, Grand Prime and more!
    [/URL]
    Octoplus JTAG PRO Software v.1.1.9 is out!
    We have added support for Samsung Galaxy Grand Prime, GT-I8258, some models of Galaxy S5 and Galaxy J3!
    Octoplus Box JTAG PRO Software v.1.1.9 Release Notes:
    • Samsung SM-G531F - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SM-G900J - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SM-G900H - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SM-J320P - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung GT-I8258 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SCL23 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    🐙 Fixed parsing of some TOT files (*.tot)
    Download Octoplus JTAG PRO Software v.1.1.9
  8. #88
    Jan 2007
    Octoplus JTAG PRO v.1.2.0 - check this out!
    [/URL][INDENT]
    Octoplus JTAG PRO Software v.1.2.0 is out!
    We have added support for LG G5 SE, LG G Slylo, LG Transpyre and Samsung Galaxy Grand Prime!
    Also, we have uploaded new SRF (Smart Repair File) for LG LS996, based on ZV7 firmware version.
    Octoplus Box JTAG PRO Software v.1.2.0 Release Notes:
    • LG H845 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • LG LS770 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • LG VS810PP - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SM-G530H - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    🐙 Uploaded new SRF for LG LS996 «LG_LS996_EMMC_BGND3R_ZV7_5.1.1.SRF»
    🐙 Updated pinouts in old SRF for LG LS996 - please uninstall old SRF («Uninstall custom model file(s)» button at «Welcome» tab in the software) and download new «G_LS996_EMMC_BGND3R_ZV4.SRF» («Download *.srf» button)
    Please pay attention! As you may have noticed, there is a minor issue with early Medusa PRO boxes firmware update. For those who have troubles with updating their box firmware version to 1.11 we introduce the so called "compatibility mode" - possibility to use all the latest software versions with old box firmware, but sacrificing some firmware-based improvements.
    When you run software 1.2.0 for the first time it will attempt to update your box firmware to 1.11 if needed. If it fails to do so you will see "box status: not found" message.
    To switch the software to "compatibility mode" do the following:
    1. Close Medusa PRO software
    2. Reconnect the box
    3. Launch 1.2.0 software again
    Also, keep in mind that non-updatable boxes are covered with warranty and entitled for replacement by authorized resellers.
    Download Octoplus JTAG PRO Software v.1.2.0
  9. #89
    Jan 2007
    Octoplus JTAG PRO v.1.2.1 - MTK repair, deleted data recovery and many more!!
    Octoplus JTAG PRO Software v.1.2.1 is out!
    With this Software update we are glad to present new advanced features and support of new devices.
    On your numerous requests, we have released feature of repairing devices, which are based on MediaTek CPUs using scatter!
    Also added new eMMC functionality - «Boot partition enable» and for Samsung eMMC flash chips - «Remove write protect» and «eMMC geometry edit».
    In addition, added support for new Samsung, LG, Lenovo, Alcatel and Oppo devices.
    Octoplus Box JTAG PRO Software v.1.2.1 Release Notes:
    🐙 Added «Repair devices based on MediaTek CPU's using scatter» feature!
    With this feature you can repair different devices via eMMC, which are based on MediaTek CPUs.
    Old and new scatter formats are supported.
    To repair such devices, you should perform the next steps:
    I. If device eMMC is not damaged
    1. Solder the necessary eMMC wires
    2. Connect the device
    3. Go to «Factory Repair» tab in the Software
    4. Press «Repair devices based on MediaTek CPU's using scatter» button
    5. Select proper scatter and necessary files
    6. Press «Write partitions» button
    7. Device repair is done
    II. If device eMMC is damaged
    If eMMC chip is damaged, you can replace it to similar Samsung eMMC chip.
    You should have CID and know properties (Boot1, Boot2, RPMB partitions’ sizes) of eMMC, which you want to replace.
    1. Connect Samsung eMMC to Box (via soldering eMMC wires or via eMMC adapter)
    2. Press «eMMC geometry edit» button, enter necessary Boot1, Boot2, RPMB partitions’ sizes and set them
    3. Write proper CID of eMMC, which you want to replace
    4. Go to «Factory Repair» tab in the Software
    5. Press «Repair devices based on MediaTek CPU's using scatter» button
    6. Select proper scatter and necessary files
    7. Press «Write partitions» button
    8. After writing will be complete, replace device’s eMMC chip to programmed Samsung eMMC
    9. Assemble the device and power it on. Device repair is done
    🐙 Added «Remove write protect» feature for Samsung eMMC flash chips
    🐙 Added «eMMC geometry edit» feature for Samsung eMMC. With this option you can set Boot1, Boot2, RPMB partitions’ size for Samsung eMMC
    🐙 Added «Boot partition enable» - you can set, whether the device is not boot enabled or select partition, that will be enabled for boot (partition1, partition2 or User area)
    • Samsung GT-I9060I - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SM-G531H - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • LG F460K, F460L, F460S - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (Thanks to Mr. Hoayeu105 aka AquaSta)
    • Alcatel One Touch 4030 - Read/Write/Erase, Easy Repair, Constructor for Repair Files
    • Lenovo P780 - Read/Write/Erase, Easy Repair, Constructor for Repair Files
    • Lenovo A390 - Read/Write/Erase, Easy Repair, Constructor for Repair Files
    • Lenovo S820 - Read/Write/Erase, Easy Repair, Constructor for Repair Files
    • Lenovo A1000F - Read/Write/Erase, Easy Repair, Constructor for Repair Files
    • Oppo T29 - Read/Write/Erase, Easy Repair, Constructor for Repair Files
    🐙 Added support for the following models via USB
    (note: these devices are already supported via USB in old Medusa Software, they are just revised and added to Medusa Pro Software):
    • LG D160 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • LG D280N - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • LG D320N - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • LG D410 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    🐙 Improved erase operation (now it is up to 200 times faster)
    🐙 Fixed some issues with CID edit
    🐙 New features and improvements in "Content Extractor":
    • added possibility of restoration of deleted data (files, folders)! To find deleted data, select «Show deleted data» option in «Content Extractor» window and parse (read) data from device or file. Note: unfortunately, not all deleted data can be undeleted.
    • fixed errors with searching and displaying data
    • improved cashing process for video-files (in «Search media» window)
    • added more criteria for inner media-files search
    • fixed issue with window's hanging after some device been connected
    • fixed some GUI problems
    Non-updatable boxes are covered with warranty and entitled for replacement by authorized resellers.
    It will be not possible to use new eMMC feature («eMMC geometry edit», «Boot partition enable», «Remove write protect») without updating Box firmware!
    [INDENT][B]🐙 All pinouts and repair procedures described in the manual ("Help" button in the software)
    Download Octoplus JTAG PRO Software v.1.2.1
  10. #90
    Jan 2007
    Octoplus JTAG PRO v.1.2.2 - 'Box not connected' fix and more!
    Octoplus JTAG PRO Software v.1.2.2 is out!
    Dear Medusa Pro users,
    Due to some architecture bug in MCU we use and our firmware particularities many of you may have encountered "Box not connected" issue and total incapability to repair phones via eMMC interface. Today we are glad to announce that the solution has been found. Below you will find a tutorial on how to repair this problem, in somewhat unusual manner though
    Also added support for HTC Desire 601, LG Nexus 5x, Samsung Galaxy J3, Galaxy S3 Progre, Lenovo IdeaTab!
    Octoplus Box JTAG PRO Software v.1.2.2 Release Notes:
    • HTC Desire 601 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • LG H790 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SM-J320H - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Samsung SCL21 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
    • Lenovo A3000F - Read/Write/Erase, Easy Repair, Factory Repair (via scatter), Constructor for Repair Files
    🐙 Updated help and pinouts in Smart Repair File for LG MS345 (please re-download SRF).
    🐙 Improved showing of progress status while writing scatter firmware of MediaTek based devices.
    🐙 Fixed “Cancel” operation for process of writing scatter firmware.
    🐙 Improvements in "Content Extractor":
    • Improved process of searching contacts
    • Improved exporting of contacts - added UTF-8 support while exporting into text formats
    🐙 Some GUI changes.
    🐙 Firmware of Medusa Pro Box has been updated! To update the firmware, please connect the box and only then run the Software. Also you can update box firmware via “Update Box Firmware” button at “Welcome” tab in Software.
    🐙 All pinouts and Repair procedures are described in Software manuals ("Help" button in Software).
    How to Repair box firmware, if box not detected by PC and Box status in Octoplus Pro JTAG Software is “Not connected” after firmware updating.
    To repair box firmware, do the next:
    1. Disconnect all Boxes and other devices from PC.
    2. Run the Octoplus Pro JTAG Software.
    3. Open Control Panel -> Device Manager.
    4. Open (disassemble) Medusa Pro box.
    5. Connect the box to PC via USB cable.
    6. Heat up IC U6 (smaller square MCU) on PCB using hot air gun or soldering iron at 150 °C (300 °F) for a few seconds till “libusb-win32 devices / HSJTAG V0x100” device appears in PC Device Manager and Box status in Octoplus Pro JTAG Software becomes “Connected”. Also LED’s will start blinking at that moment.
    7. Go to “Welcome” tab in Octoplus Pro JTAG Software and press “Update Box Firmware” button.
    8. Box firmware should be updated to version 1.13.
    Note! After repairing box firmware you shouldn’t use previous versions of Octoplus Pro JTAG Software, please always use the latest actual software version.
    Note! Tampering seals to repair box won't void your box warranty.
    Download Octoplus JTAG PRO Software v.1.2.2
  1. Octoplus Box JTAG Updates
    By Lính Khang in forum Octopus/Octoplus Box
    Bài viết cuối: 20-11-2013, 23:34
  2. Octoplus Box JTAG v1.3.5 - going further!
    By toilatoi142001 in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 05-10-2013, 10:12
  3. Octoplus Box JTAG Software v1.3.2 - HTC One S, 8X and more!
    Bài viết cuối: 14-09-2013, 10:07
  4. Octoplus Samsung V1.1.1 and JTAG v1.1.0
    Bài viết cuối: 13-04-2013, 10:08
  5. Octoplus Box JTAG Updates
    By Lính Khang in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 02-02-2013, 08:38
