Trang 6 của 6 Đầu tiênĐầu tiên 1 2 3 4 5 6
Kết quả 51 tới 53 của 53
  1. #51
    Jan 2007
    Octoplus/Octopus Suite v.1.5.5 is out! Added Unlock via server for Galaxy S9/S9+ TMB/MPCS devices!
    Added Factory Unlock (via server) for Samsung TMB/MPCS (with “Device Unlock App") Galaxy S9 and S9+ devices.
    Added Unlock support (via server) for Android 8.0 firmwares for TMB/MPCS S8/S8+/Note 8 devices.
    Some adjustments and improvements were made.[INDENT]Octoplus/Octopus Suite v.1.5.5 Release Notes:
    🐙 Added support for the following models:
    • SM-G960U TMB/MPCS - added Unlock via server (without erasing/wiping data, no root needed, fast factory algo)
    • SM-G960U1 TMB/MPCS - added Unlock via server (without erasing/wiping data, no root needed, fast factory algo)
    • SM-G965U TMB/MPCS - added Unlock via server (without erasing/wiping data, no root needed, fast factory algo)
    • SM-G965U1 TMB/MPCS - added Unlock via server (without erasing/wiping data, no root needed, fast factory algo)
    🐙 Improved "TMB Unlock via server" operation (added support for Android 8.0 firmwares and latest Security patch levels) for the following devices:
    • SM-G950U, SM-G950U1
    • SM-G955U, SM-G955U1
    • SM-N950U, SM-N950U1
    🐙 Some adjustments and improvements were made.
    🐙 All supported operations described in details in the manual ("Cable & Manual" button in the software).
    Note:
    • Price for Octopus/Octoplus Samsung owners - 100 credits
    • Price for Octopus/Octoplus users without Samsung activation - 200 credits
    • Price for users without Octopus box - 300 credits
    Latest information is available Here.
    You can buy Octopus/Octoplus Server Credits from your local reseller or directly HERE
    How to perform "TMB Unlock" operation:
    • Select proper model from the list in the Software
    • Press "TMB Unlock" button
    • Follow Software instructions
    [INDENT][INDENT][INDENT]Download Octoplus/Octopus Suite v.1.5.5
  2. #52
    Jan 2007
    Octoplus/Octopus Suite v.1.5.7 is out! Added Read Codes via server for Galaxy S9/S9+ based on Exynos CPUs and more!
    Added Read Codes (via server) for Samsung Galaxy S9, S9+, A6 2018, J4, J6 2018 series based on Exynos CPUs.
    Added new additional Read Codes (via server) method for latest Exynos CPUs-based devices: S8/S8+, Note 8, A8/A8+ 2018, A3/A5/A7 2017, J7 2017/Nxt/Prime series.
    Octoplus/Octopus Suite v.1.5.7 Release Notes:
    • SM-G960F - added Read Codes (via server)
    • SM-G960N - added Read Codes (via server)
    • SM-G965F - added Read Codes (via server)
    • SM-G965N - added Read Codes (via server)
    • SM-A600F - added Read Codes (via server)
    • SM-A600FN - added Read Codes (via server)
    • SM-A600G - added Read Codes (via server)
    • SM-A600GN - added Read Codes (via server)
    • SM-A600N - added Read Codes (via server)
    • SM-J400F - added Read Codes (via server)
    • SM-J400G - added Read Codes (via server)
    • SM-J400M - added Read Codes (via server)
    • SM-J600F - added Read Codes (via server)
    • SM-J600FN - added Read Codes (via server)
    • SM-J600G - added Read Codes (via server)
    • SM-J600GF - added Read Codes (via server)
    • SM-J600GT - added Read Codes (via server)
    • SM-J600L - added Read Codes (via server)
    • SM-J600N - added Read Codes (via server)
    🐙 Added new additional Read Codes (via server) method for the following Exynos CPU-based devices (all firmwares and KNOX are supported, no root required):
    • SM-A320F, SM-A320FL, SM-A320Y
    • SM-A520F, SM-A520K, SM-A520L, SM-A520S, SM-A520W
    • SM-A530F, SM-A530N, SM-A530W
    • SM-A720F
    • SM-A730F, SM-A730N
    • SM-G950F, SM-G950FD, SM-G950N, SM-G955F, SM-G955FD, SM-G955N
    • SM-J530F, SM-J530FM, SM-J530G, SM-J530GM, SM-J530K, SM-J530L, SM-J530Y, SM-J530YM
    • SM-J730F, SM-J730FM, SM-J730G, SM-J730GM, SM-J730K
    • SM-N950F, SM-N950FD, SM-N950N
    Note: Read Codes (via server) operation for all mentioned above devices works for most available device firmwares (modems). If your device has unsupported modem, just write another available firmware or proper supported modem. Or wait a few hours and try to repeat the operation again - support for unsupported modem firmware will be added to server automatically during a few hours.
    🐙 Added new additional Read Codes method for SM-G950x and SM-G955x, based on Qualcomm CPUs. From now on, two Read Codes methods are supported - Read Codes (Via DIAG port) and Read Codes (Via ADB interface). If Read Codes operation was unsuccessful by using the first method, try to perform it using the second Read Codes method.
    Latest information is available here.
    You can buy Octopus/Octoplus Server Credits from your local reseller or directly HERE.
    How to perform "Read Codes" operation:
    • Install Samsung ADB drivers
    • Connect the device to PC via USB cable
    • Enable ADB
    • Press "Read Codes" button
    Download Octoplus/Octopus Suite v.1.5.7
  3. #53
    Jan 2007
    Octoplus/Octopus Suite v.1.5.8 is out! Added TMB Galaxy Note 9 Unlock, Read Codes for many new devices!
    Octoplus/Octopus Suite v.1.5.8 Release Notes:
    🐙 Added TMB Unlock (via server) for TMB Samsung Galaxy Note 9 SM-N960U and SM-N960U1.
    🐙 Added Read Codes (via server) for the following models:
    • SM-A6050, SM-A605F, SM-A605FN, SM-A605G, SM-A605GN
    • SM-G570F, SM-G570FD, SM-G570M, SM-G570MD, SM-G570Y
    • SM-G8750
    • SM-G8850, SM-G8858, SM-G885F, SM-G885S, SM-G885Y
    • SM-J260F, SM-J260G, SM-J260M, SM-J260Y
    • SM-J330GM, SM-J330L, SM-J330N
    • SM-J336AZ, SM-J337A, SM-J337AZ (read for 16 digits code)
    • SM-J415F, SM-J415FN, SM-J415G
    • SM-J720F, SM-J720M
    • SM-J727A, SM-J727AZ, SM-J727S
    • SM-J737A
    • SM-J810F, SM-J810G, SM-J810M, SM-J810Y
    • SM-N960F, SM-N960FD, SM-N960N
    🐙 Improved Read Codes (via server, via UploadMode) operation (added support for BIT5 firmwares) for the following devices:
    🐙 Improved TMB unlock (via server) operation (for the latest firmware versions: from now on no need to write modem from combination firmware) for the following TMB devices:
    • SM-G960U, SM-G960U1
    • SM-G965U, SM-G965U1
    Note: Please, always use the latest Software version.
    Also note: If you have any problems with Read Codes operation, please contact us on Skype, you can find our contact info in our profile.
    • Enable ADB
    Download Octoplus/Octopus Suite v.1.5.8
    [INDENT][
  1. Octoplus/Octopus Suite v1.1.9 - new devices, new firmwares support added!
    By toilatoi142001 in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 05-10-2013, 10:10
  2. Octoplus/Octopus Suite v1.1.8 - added new firmwares unlock support!
    Bài viết cuối: 28-09-2013, 10:20
  3. Octoplus/Octopus Suite v1.1.7 - added Huawei E3121 support and more!
    Bài viết cuối: 21-09-2013, 09:59
  4. Octoplus/Octopus Suite v1.1.5 - Huawei E3276, K4605, K5005 and more!
    Bài viết cuối: 07-09-2013, 09:45
  5. Octoplus/Octopus LG v1.1.9 & Samsung v1.2.4 & Suite v1.0.7, also JTAG v1.2.3
    Bài viết cuối: 13-07-2013, 10:13
