Pegasus Box v1.0.1
04.05.2011 00:00:00
http://www.paklink.org/products/369pegasus_box.jpg
Added safe unlock code reading and direct unlock by original cable for the following models:
A697
B3410W
C3510T
I6220
I6320
M3710
M3710L
S3650
S3650C
S3650L
S3650W
S3653
S3653W
S3850
S5250
S5253
S5260
S5263
S5330
S5330L
S5333
S5750E
S5753E
S7070
S7070C
S7230E
S7233E
S8500
S8500B
S8500L
S8500M
S8500T
S8530
S8530B
S8530L
To work with the mentioned above models perform the following steps:
Connect powered on phone to original USB cable.
Select "PC Suite"/"Samsung Kies" mode.
Install required drivers.
Select modem port in software.
Click "Connect" button in software.
Enter codes manually or use direct unlock button.
Click "Disconnect" button.
Pegasus Box v1.0.2
06.05.2011 00:00:00
Added unlock code reading (world's first), direct unlock, IMEI rebuild for the following models:
I917 (all existing versions are supported)
I917R (all existing versions are supported)
I8700
S5570
S5660
S5670
S5830
B7510
I5500
I5500B
I5500L
I5500M
I5503
I5503T
I5508
I5510
I5510L
I5700L
I5700R
I5800
I5800L
I5801
I7500L
I7500U
I8520
B6520
B6520L
B7300B
B7300C
B7320L
B7330B
B7330C
B7330R (all existing versions are supported)
B7350
I8000H
I8000L
I8000U
Added direct unlock/IMEI rebuild for:
I8330
G810
I7110
I8510H
I8510L
I8910
I8910H
I8910U
I900C
I900L
I900V
I908
