Kết quả 1 tới 8 của 8
    Thành viên chính thức tin_vinaphone's Avatar
    Aug 2008
    Mặc định all samsung unlock code,here!!!
    *2767*688# = Unlocking Code
    *#8999*8378# = All in one Code
    *#4777*8665# = GPSR Tool
    *#8999*523# = LCD Brightness
    *#8999*3825523# = External Display
    *#8999*377# = Errors
    #*5737425# = JAVA Something{I choose 2 and it chrashed}
    *#2255# = Call List
    #*536961# = Java Status Code
    #*536962# = Java Status Code
    #*536963# = Java Status Code
    #*53696# = Java Status Code
    #*1200# = AFC DAC Val
    #*1300# = IMEI
    #*1400# = IMSI
    #*2562# = ??? White for 15 secs than restarts.
    #*2565# = Check Blocking
    #*3353# = Check Code
    #*3837# = ??? White for 15 secs than restarts.
    #*3849# = ??? White for 15 secs than restarts.
    #*3851# = ??? White for 15 secs than restarts.
    #*3876# = ??? White for 15 secs than restarts.
    #*7222# = Operation Typ (Class C GSM)
    #*7224# = I Got !! ERROR !!
    #*7252# = Oparation Typ (Class B GPRS)
    #*7271# = Multi Slot (Class 1 GPRS)
    #*7274# = Multi Slot (Class 4 GPRS)
    #*7276# = Dunno
    #*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
    #*2787# = CRTP ON/OFF
    #*3737# = L1 Dbg data
    #*5133# = L1 Dbg data
    #*7288# = GPRS Attached
    #*7287# = GPRS Detached
    #*7666# = SrCell Data
    #*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
    #*7284# = Class : B,C or GPRS
    #*2256# = Calibration Info
    #*2286# = Battery Data
    #*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
    #*2679# = Copycat feature (Activate or Deactivate)
    #*3940# = External loop test 9600 bps
    #*4263# = Handsfree mode (Activate or Deactivate)
    #*4700# = Half Rate (Activate or Deactivate)
    #*7352# = BVMC Reg value
    #*8462# = Sleeptime
    #*2558# = Time ON
    #*3370# = EFR (Activate or Deactivate)
    #*3941# = External looptest 115200 bps
    #*5176# = L1 Sleep
    #*7462# = SIM phase
    #*7983# = Voltage/Frequenci (Activate or Deactivate)
    #*7986# = Voltage (Activate or Deactivate)
    #*8466# = Old time
    #*2255# = Call ???
    #*5187# = L1C2G trace (Activate or Deactivate)
    #*5376# = ??? White for 15 secs than restarts.
    #*6837# = Official Software Version
    #*7524# = KCGPRS
    #*7562# = LOCI GPRS
    #*7638# = RLC allways open ended TBF (Activate or Deactivate)
    #*7632# = Sleep mode Debug
    #*7673# = Sleep mode RESET
    #*2337# = Permanent Registration Beep
    #*2474# = ???
    #*2834# = Audio Path
    #*3270# = DCS support (Activate or Deactivate)
    #*3282# = Data (Activate or Deactivate)
    #*3476# = EGSM (Activate or Deactivate)
    #*3676# = Flash volume formated
    #*4760# = GSM (Activate or Deactivate)
    #*4864# = Dunno doesn't work on newer versions
    #*5171# = L1P1
    #*5172# = L1P2
    #*5173# = L1P3
    #*7326# = Accessory (I got Vibrator)
    #*7683# = Sleep variable (8)
    #*7762# = SMS Brearer CS (Activate or Deactivate)
    #*8465# = Time in L1
    #*9795# = wtls key
    #*2252# = Current CAL
    #*2836# = AVDDSS Management (Activate or Deactivate)
    #*3877# = Dump of SPY trace
    #*7728# = RSAV done# (Everything went to standart but nothing was deleted)
    #*2677# = ARM State (None or Full Rate)
    *#8999*636# = Have no clue what it is, i see 20 lines
    *#9999# = Software version
    *#8999*8376263# = HW ver, SW ver and Build Date
    *#8888# = HW version
    *#8377466# = Same HW/SW version thing
    *#7465625# = Check the locks
    *7465625*638*Code# = Enables Network lock
    #7465625*638*Code# = Disables Network lock
    *7465625*782*Code# = Enables Subset lock
    #7465625*782*Code# = Disables Subset lock
    *7465625*77*Code# = Enables SP lock
    #7465625*77*Code# = Disables SP lock
    *7465625*27*Code# = Enables CP lock
    #7465625*27*Code# = Disables CP lock
    *7465625*746*Code# = Enables SIM lock
    #7465625*746*Code# = Disables SIM lock
    *7465625*228# = Activa lock ON
    #7465625*228# = Activa lock OFF
    *7465625*28638# = Auto Network lock ON
    #7465625*28638# = Auto Network lock OFF
    *7465625*28782# = Auto subset lock ON
    #7465625*28782# = Auto subset lock OFF
    *7465625*2877# = Auto SP lock ON
    #7465625*2877# = Auto SP lock OFF
    *7465625*2827# = Auto CP lock ON
    #7465625*2827# = Auto CP lock OFF
    *7465625*28746# = Auto SIM lock ON
    #7465625*28746# = Auto SIM lock OFF
    *2767*3855# = E2P Full Reset
    *2767*2878# = E2P Custom Reset
    *2767*927# = E2P Wap Reset
    *2767*226372# = E2P Camera Reset
    #*6420# = MIC Off
    #*6421# = MIC On
    #*6422# = MIC Data
    #*6428# = MIC Measurement
    #*3230# = Trace enable and DCD disable
    #*3231# = Trace disable and DCD enable
    #*3232# = Current Mode
    #7263867# = RAM Dump (On or Off)
    *2767*49927# = Germany WAP Settings
    *2767*44927# = UK WAP Settings
    *2767*31927# = Netherlands WAP Settings
    *2767*420927# = Czech WAP Settings
    *2767*43927# = Austria WAP Settings
    *2767*39927# = Italy WAP Settings
    *2767*33927# = France WAP Settings
    *2767*351927# = Portugal WAP Settings
    *2767*34927# = Spain WAP Settings
    *2767*46927# = Sweden WAP Settings
    *2767*380927# = Ukraine WAP Settings
    *2767*7927# = Russia WAP Settings
    *2767*30927# = GREECE WAP Settings
    *2767*73738927# = WAP Settings Reset
    *2767*49667# = Germany MMS Settings
    *2767*44667# = UK MMS Settings
    *2767*31667# = Netherlands MMS Settings
    *2767*420667# = Czech MMS Settings
    *2767*43667# = Austria MMS Settings
    *2767*39667# = Italy MMS Settings
    *2767*33667# = France MMS Settings
    *2767*351667# = Portugal MMS Settings
    *2767*34667# = Spain MMS Settings
    *2767*46667# = Sweden MMS Settings
    *2767*380667# = Ukraine MMS Settings
    *2767*7667#. = Russia MMS Settings
    *2767*30667# = GREECE MMS Settings
    *335# = Delete all MMS Messages
    *663867# = Dump Mm file
    #*536961# = WAPSAR enable / HTTP disable
    #*536962# = WAPSAR disable / HTTP enable
    #*536963# = Serial eable / Others disable
    #*53696# = Java Download Mode
    #*5663351# = Wap Model ID [Your Model]
    #*5663352# = Wap Model ID [SEC-SGHXXXX/1.0]
    #*566335# = Wap Model ID [SEC-SGHXXXX/1.0]
    *2767*66335# = Check on which model it is
    *2767*7100# = SEC-SGHS100/1.0
    *2767*8200# = SEC-SGHV200/1.0
    *2767*7300# = SEC-SGHS300/1.0
    *2767*7650# = Nokia7650/1.0
    *2767*2877368# = Reset WAP Model ID to s
    *7465625*638*00000000*00000000#
    #7465625*638*00000000#
    Super Moderator Tempb's Avatar
    Feb 2008
    TP.HCM
    cái nì work khoảng mấy phần trăm bác, em thấy trên mạng nhiều rồi toàn fail ko hà
    Thành viên mới 321nhattruong's Avatar
    Aug 2008
    Mặc định Cai Do Hay Qua
    nhung ban co the chi ra ro hon duoc khong
    VD:*2767*688# = Unlocking Code la mokhoa gi???...
    minh moi vo nghe chua ro cho may
    Aug 2008
    bạn có thể chỉ rỏ hơn về từng phần được không cám ơn bạn nhiều mình mới vô nghề chưa rỏ cho máy
    Ví Dụ:*#8999*377# = Errors ???... làm gì bạn
    Aug 2008
    Trích Được post bởi 321nhattruong Xem bài viết
    VD:bạn muốn unlock mật mã này?*2767*688#lúc đó bạn nhập tiếp code mặt định máy sam sung là 00000000 la ok,thì lấy 120k
    Aug 2008
    bạn tham khảo thêm ở đây nha,đây là tiếng việt
    [1] Mật mã Reset nhạc chuông và hình ảnh
    Đây là mật mã xóa mọi hình ảnh và nhạc chuông được tải về điện thoại thông qua Hồng ngoại, Bluetooh, hoặc cáp
    * 2767 * 63342 # ( * 2767 * MIDIA # )
    [2] Mật mã Reset E2P Full Reset
    Đây là mật mã xóa sạch nhật ký điện thoại, tin nhắn trong hộp thư đi, mở khóa điện thoại mở khóa riêng tư khi truy cập vào hình ảnh nhạc chuông, tin nhắn MMS mà máy hỏi Password, đối với trường hợp bỏ Simcard vào điện thoại mà máy hỏi Password mở máy thì chúng ta hãy tháo Simcard ra và bấm mật mã này, sau đó bỏ Simcard vào máy lại. Mật mã này cũng xóa 1 số lỗi của EPROM
    * 2767 * 3855 # ( * 2767 * Full # )
    [3] Mật mã Reset E2P Custom
    Đây là mật mã Reset nhỏ
    * 2767 * 2878 # ( * 2767 * Cust # )
    [4] Mật mã Reset các trò chơi
    * 2767 * 5282 # ( * 2767 * Java # )
    [5] Mật mã Reset về phần mềm
    * 2767 * 7822573738 #
    [6] Mật mã Reset về lỗi của Flash
    * 2767 * 25573738 #
    [7] Mật mã Reset về WAP
    Mọi cài đặt về kết nối GPRS bị lỗi sẽ bị xóa sạch
    * 2767 * 927 # ( *2767 * Wap # )
    [8] Mật mã Reset một số lỗi về cài đặt
    Cách 1
    * 2767 * 688 #
    Cách 2
    * 2767 * 637 #
    [9] Mật mã Reset xóa Simcard vào máy
    Mật mã này có tác dụng Reset EEPROM và mở khóa Simcard vaop1 máy cho một số loại máy thích hợp
    # * 7337 #
    [10] Mật mã reset cấp độ cao
    Đây là mật mã xóa sạch tất cả những gì chúng ta đã cài đặt, bởi vì có rất nhiếu mật mã sau khi chúng ta đã cài đặt thì có dùng máy tính chạy lại chương trình cũng không xóa được những gì chúng ta đã cài, do vậy đây là mật mã Reset cấp độ cao.
    Cách 1
    * 2767 * 73738927 #
    Cách 2
    * 2767 * 737383855 #
    Cách 3
    * 2767 * 737382878 #
    CÁC MẬT MÃ KIỂM TRA ĐIỆN THOẠI
    [1] Mật mã kiểm tra các khóa
    * # 7465625 #
    Chúng ta sẽ thấy xuất hiện một Menu trong đó có chứa các dữ liệu sau:
    1/ Network Lock
    2/ Subset Lock
    3/ Sp Lock
    4/ Cp Lock
    5/ Sim Lock
    6/ Multiple Lock
    7/ Active Lock
    8/ Auto Network Lock
    9/ Auto Subset Lock
    10/ Auto Cp Lock
    11/ Auto Sim Lock
    12/ Auto Multiple Lock
    [2] Mật mã kiểm tra S/W
    * # 9999 #
    [3] Mật mã kiểm tra H/W
    * # 8888 #
    [4] Mật mã kiểm tra S/W
    Cách 1
    * # 8999 * 8376263 #
    Cách 2
    * # 8999 * 8377466 #
    [5] Mật mã kiểm tra Rung
    Cách 1
    * # 0842 #
    Cách 2
    * # 9998 * 842 #
    Cách 3
    * # 8999 * 842 #
    [6] Mật mã kiểm tra Chuông
    Cách 1
    * # 02890#
    Cách 2
    * # 9998 * 289 #
    Cách 3
    * # 8999 * 289 #
    [7] Mật mã kiểm tra Pin
    Cách 1
    * # 0228 #
    Cách 2
    * # 9998 * 228 #
    Cách 3
    * # 8999 * 228 #
    [8] Mật mã kiểm tra đồng hồ đo đếm thời gian
    Cách 1
    * # 0782 #
    Cách 2
    * # 9998 * 782 #
    Cách 3
    * # 8999 * 782 #
    [9] Mật mã kiểm tra thông tin về mạng
    Cách 1
    * # 0638 #
    Cách 2
    * # 9998 * 638 #
    Cách 3
    * # 8999 * 638 #
    [10] Mật mã kiểm tra bộ nhớ của điện thoại
    Cách 1
    * # 0636 #
    Cách 2
    * # 9998 * 636 #
    Cách 3
    * # 8999 * 636 #
    [11] Mật mã kiểm tra phầm cứng và âm thanh phát ra loa
    * # 3243948 #
    [12] Mật mã kiểm tra phần cứng và sóng
    * # 3243948 #
    [13] Mật mã kiểm tra phần cứng
    Những lỗi về phần cứng gồm: lỗi hở chân IC, chết 1 pần IC, đứt mạch.. nếu phần cứng có lỗi thì các thông số hiện ra trên màng hình sẽ thay đổi rất nhanh, và nếu phần cứng
    không có lỗi thì các thông số hiện ra trên màng hình sẽ thay đổi rất chậm và rất đều.
    Cách 1
    * # 9324 #
    Cách 2
    * # 9998 #
    Cách 3
    * # 8999 #
    [14] Mật mã kiểm tra lỗi của EEPROM
    Cách 1
    * # 9998 * 377 #
    Cách 2
    * # 8999 * 377 #
    [15] Mật mã hiển thị các File của Simcard
    Cách 1
    * # 0778 #
    Cách 2
    * # 9888 * 778 #
    Cách 3
    * # 8999 * 778 #
    [16] Mật mã kiểm tra khả năng bắt sóng của điện thoại.
    Cách 1
    * # 0968 #
    Cách 2
    * # 9998 * 968 #
    Cách 3
    * # 8999 * 968 #
    [17] ] Mật mã kiểm tra bộ nhớ của điện thoại
    Chúng ta xem bộ nhớ của điện thoại hoạt động ở chế độ nào.
    * # 7263867 #
    [18] Mật mã kiểm tra chế độ bảo vệ của điện thoại
    Cách 1
    * # 0364 #
    Cách 2
    1* # 9998 * 364 #
    Cách 3
    * # 8999 * 364 #
    [19] Mật mã kiểm tra các lỗi của Simcard
    Cách 1
    * # 2576 #
    Cách 2
    * # 9998 * 2567 #
    Cách 3
    * # 8999 * 2567 #
    [20] Mật mã kiểm tra bộ giải mã của điện thoại
    Cách 1
    * # 0862 #
    Cách 2
    * # 9998 * 862 #
    Cách 3
    * # 8999 * 862 #
    [21] Mật mã phát hiện các virut
    Cách 1
    * # 9998 * 544 #
    Cách 2
    * # 8999 * 544 #
    [22] Mật mã bật nhiễu sóng âm thanh số
    * # 23436837 #
    [23] Mật mã tắt nhiễu sóng âm thanh số
    * # 2343498 #
    [24] Mật mã hiển thị trạng thái của bộ nhớ không ổn định
    Cách 1
    * # 9998 * 585 #
    Cách 2
    * # 8999 * 585 #
    [25] Mật mã kiểm tra nhạc điệu báo thức
    Cách 1
    * # 9998 * 968 #
    Cách 2
    * # 8999 * 968 #
    [26] Mật mã hiển thị Menu cài đặt JAVA
    Cách 1
    * # 9998 * 5282 #
    Cách 2
    * # 8999 * 5282 #
    [27] Mật mã hiển thị các thông tin báo lỗi
    Cách 1
    * # 9998 * 786 #
    Cách 2
    * # 8999 * 786 #
    [28] Mật mã hiển thị trạng thái chương trình của điện thoại và khả năng bộ nhớ
    Cách 1
    * # 9998 * 246 #
    Cách 2
    * # 8999 * 246 #
    [29] Mật mã hiển thị số kênh và cường độ sóng mà kênh nhận được
    Cách 1
    * # 9266 #
    Cách 2
    * # 9998 * 9266 #
    Cách 3
    * # 8999 * 9266 #
    [30] Mật mã hiển thị các tín hiệu bảo vệ điện thoại
    Cách 1
    * # 9998 * 427 #
    Cách 2
    * # 8999 * 427 #
    [31] Mật mã khởi động lại điện thoại khi gặp các lỗi nghiêm trọng
    Cách 1
    * # 9998 * 947 #
    Cách 2
    * # 8999 * 947 #
    [32] Mật mã phân tích chẩn đoán lỗi
    Cách 1
    * # 9998 * 872 #
    Cách 2
    * # 8999 * 872 #
    [33] Mật mã kiểm tra chức năng ghi âm
    Cách 1
    * # 9998 * 862 #
    Cách 2
    * # 8999 * 862 #
    [34] Mật mã phát hiện lỗi thực thi hệ điều hành RTK
    Chúng ta sẽ chọn và Ok, lỗi thực thi hệ điều hành sẽ chuyển thành lỗi bộ nhớ
    Cách 1
    * # 9998 * 785 #
    Cách 2
    * # 8999 * 785 #
    [35] Mật mã hiển thị các thông số kiểm soát của nhà sản xuất
    Cách 1
    * # 9125 #
    Cách 2
    * # 9998 * 9125 #
    Cách 3
    * # 8999 * 9125 #
    [36] Mật mã hiển thị Menu ẩn
    Menu này phục vụ mục đích mở khóa Simcard vào máy
    Cách 1
    * # 9998 * 737 #
    Cách 2
    * # 8999 * 737 #
    Cách 3
    * # 627837793 #
    Cách 4
    * # 9998 * 627837793 #
    Cách 5
    * # 8999 * 627837793 #
    DtruG
    20-02-2008, 07:19 PM
    Các cách mở mạng
    Đối với điện thoại SAMSUNG hầu như mọi trường hợp mở mạng để sử dụng với tất cả mọi loại Simcard khác nhau đều phải thông qua phần mềm mở mạng kết nối với cáp qua vi tính, nhưng sẽ có những trường hợp có những máy quá mới mà ở Việt Nam chưa có phần mềm mở mạng, do vậy chúng ta phải tìm cách chửa cháy mở mang để điện thoại của chúng ta sẽ sử dụng trên 1 Simcard cố định, Simcard này là Simcard chúng ta bỏ vào máy lúc phần mềm mở khóa thì chúng ta mở khóa cho điện thoại một chách hoàn toàn sau đây là cách để bẻ khóa tạn:
    PHẨN CHUNG
    Phần chung là phần mà bất cứ chúng ta sử dụng cách nào cũng phải thực hiện phần chung này đầu tiên, phần chung là phần chúng ta sẽ bấm 1 loạt các mật mã Reset điện thoại, các mật mã Reset giúp chúng ta loại bỏ 1 số khóa nhỏ mà chúng ta cần phải mở.
    Sau đây là các mật mã Resst :
    Cách 1
    * 2767 * 2878 #
    Cách 2
    * 2767 * 3855 #
    Cách 3
    * 2767 * 5282 #
    Cách 4
    * 2767 * 927 #
    Cách 5
    * 2767 * 63342 #
    Cách 6
    * 2767 * 255573738 #
    Cách 7
    Cách 8
    * 2767 * 637 #
    Cách 9
    * 2767 * 688 #
    Cách 10
    Cách 11
    Cách 12
    * 2767 * 737385282 #
    Cách 13
    * 2767 * 73738927 #
    Cách 14
    * 2767 * 7373863342 #
    Cách 15
    # 7465625 * 287820#
    Cách 16
    # 7465625 * 28638 #
    Cách 17
    # 7465625 * 2877 #
    Cách 18
    # 7465625 * 2827 #
    Cách 19
    # 7465625 * 228 #
    Cách 20
    # 7465625 * 28746 #
    Sau khi thực hiện 1 loạt các mật mã Reset ở trên, có mật mã sẽ có tác dụng, có mật mã sẽ không có tác dụng, chúng ta hãy thử tất c ả các mật mã không bỏ sót mật mã nào.
    CÁCH MỞ KHÓA MANG 1
    Chúng ta lắp Simcard vào máy vá bấm mật mã sau: * # 9998 * 3323 #
    Lúc này trên màng hình xuất hiện dòng chữ “Please press Exit ” chúng ta hãy bấm nút thoát màu đỏ ( nút nguồn ) sau khi bấm nút thoát màng hình sẽ hiển thị 1 Menu ẩn, chúng ta sẽ thấy Menu ẩn có chứa các dữ liệu sau:
    1/ Task loop
    2/ Pull ptr write
    3/ System reset
    4/ Enable Sleep
    5/ Prohibit Sleep
    6/ Malloc Fail
    7/ Jump to null
    8/ DSP Crash
    9/ Data A bort
    10/ TBP
    Chúng ta sẽ chọn mục số 3 và Ok, sau đó lặp lại quá trình này và chọn mục số 6 và Ok
    Chờ máy khởi động lại sau đó chúng ta bấm mật mã sau: * 0141 # và Ok, chờ cho máy thực hiện sau chúng ta sẽ tắt máy chờ khoản 30 phút, sau đó bật nguồn lên lại, lúc đó máy hỏi Password, chúng ta nhập code là 00000000 và Ok, quá trình bẻ khóa cách 1 đã hoàn thành.
    CÁCH MỞ KHÓA MẠNG 2:
    Cách mở khóa mạng 2 là cách khá đơn giản vì cách 2 gần như lặp lại cách 1, ở cách 1 thay vì chúng ta vào mục số 6 thì cách 2 chúng ta sẽ chọn mục số 7, và cách làm hoàn toàn tương tự cách 1. Chúc bạn thành công.
    CÁCH MỞ KHÓA MẠNG 3
    Chúng ta hãy bấm mật mã sau: * # 1111 * 94288837 # lúc này máy sẽ hỏi Password, chúng ta nhập code là: 00000000 và Ok, sau đó máy tắt và tự động khởi động lại nguồn, chúng ta bấm mật mã sau: * 0141 # và Ok, sau đó chúng ta tắt nguồn và chờ khoảng 30phút sau bật nguồn lên lại, sau khi bật nguồn máy sẽ hỏi Password, chúng ta nhập code là: 00000000 và Ok, như vậy quá trình mở mạng theo cách 3 đã hoàn thành.
    CÁCH MỞ KHÓA MẠNG 4
    Chúng ta bấm mật mã sau: # 0111 * 00000000 #, chờ 1 lúc sau khi máy khởi động lại nguồn chúng ta bấm mật mã sau: * 0141 # và ok sau đó chúng ta tắt nguồn và chờ khoản 30 phút sau bật nguồn lên lại, khi đó máy hỏi Password, chúng ta nhập code là: 00000000 và Ok, như vậy quá trình mở mạng theo cách 4đã hoàn thành
    CÁCH MỞ KHÓA MẠNG 5
    Chúng ta bấm * # 060# và ghi lại số IMEI, sau đó chúng ta bấm các mật mã:
    Cách 1
    * 2767 * 688IMEI #
    Cách 2
    * 2767 * 3855IMEI #
    Cách 3
    * 2767 * 2878IMEI #
    Cách 4
    * 2767 * 637IMEI #
    Cách 5
    * 2767 * 73738IMEI #
    CÁCH MỞ KHÓA MẠNG 6
    Chúng ta bấm tất cả các mật mã sau:
    <1> # 7465625 * 638 * 00000000 #
    <2> # 7465625 * 746 * 00000000 #
    <3> # 7465625 * 77 * 00000000 #
    <4> # 7465625 * 27 * 00000000 #
    <5> # 7465625 * 782 * 00000000 #
    tất cả các mật mã để mở mạng cho sam sung,
    {chúc các ae thành công}
  7. ( tin_vinaphone ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    khanhhaifpt (26-08-2008)
  8. #7
    Thành viên mới dongnh's Avatar
    Jul 2008
    Trích Được post bởi tin_vinaphone Xem bài viết
    nhưng bấm *2767*688# lúc này không còn nhập được mã mặc định nữa rồi.
  9. #8
    Jul 2008
    tình trạng máy của em là con samsung E730 bị vọc nên cho ở chế độ khóa máy vào sim, hiện tại bây giờ khi mà bỏ sim vào nó đòi code, nó không nhận bất kỳ sim nào bỏ vào đã reset lại toàn bộ máy nhưng vẫn không được, bác làm ơn chỉ giúp em cách unlock khóa máy vào sim đi bác, cảm ơn bác nhiều
  1. Samsung note unlock code
    By chidinh in forum Samsung Android
    Bài viết cuối: 19-09-2015, 14:29
  2. Trả lời: 2
    Bài viết cuối: 24-05-2014, 19:31
  3. Unlock user code cho samsung Bằng Jaf
    By trongtan8909 in forum Tool - Soft và phần mềm free!
    Bài viết cuối: 31-08-2012, 22:01
  4. Samsung E250 unlock code 11 feb 2008
    By BlachThon in forum Agere System
    Bài viết cuối: 12-02-2008, 17:14
  5. Unlock Samsung V804, Z540 only by code
    By DNA in forum SAMSUNG
    Trả lời: 26
    Bài viết cuối: 01-08-2006, 10:10
