con e1050 z3 chọn e1130b unlock fail
log
hìnhHTML Code:Selected model: E1130B Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: E1050DXKE2 Phone CSC: E1050OLAKE2 Phone BT ADDR: 0000-00-000000 Phone IMEI: 35465604174288 Deactivated MSL - FAIL Elapsed time: 40 second, sw ver: 3.5.0029
bỏ vào hwk chọn unlcok báo done nhưng vẩn ko bay mã
log
bấm vào unlock E2p sau đó nó sẽ đọc master codeHTML Code:Connect Cable to Switched Off Mobile (with battery) Software: E1050DXKE2 Hardware: MP 0.600 Regions : Indonesia,Java,Malaysia,Singapore,Thailand,Vietnam Language: en,id,jv,ms,th,vi,zh(ta) Release : 2011 May Rev: 2 CSC Vers: E1050OLAKE2 XXV Customer: Vietnam Use [Patch MSL] to bypass MSL S/N : RFJB848972 IMEI: 354656-04-174288-4 Use [Patch MSL] to bypass MSL Use [Patch MSL] to bypass MSL Use [Patch MSL] to bypass MSL Unlock failed Connect Cable to Switched Off Mobile (with battery) Use [Patch MSL] to bypass MSL Use [Patch MSL] to bypass MSL Use [Patch MSL] to bypass MSL Unlock Done
nhập vào bay ngay
