    Jun 2008
    Hà Nội & Sài Gòn
    Mặc định samsung all sevice code
    ai chua có hoặc chua biết thì tham khảo , có lẽ đã cũ nhưng phục vụ anh em mới vào nghề
    *2767*688# = Unlocking Code
    *#8999*8378# = All in one Code
    *#4777*8665# = GPSR Tool
    *#8999*523# = LCD Brightness
    *#8999*3825523# = External Display
    *#8999*377# = Errors
    #*5737425# = JAVA Something{I choose 2 and it chrashed}
    *#2255# = Call List
    #*536961# = Java Status Code
    #*536962# = Java Status Code
    #*536963# = Java Status Code
    #*53696# = Java Status Code
    #*1200# = AFC DAC Val
    #*1300# = IMEI
    #*1400# = IMSI
    #*2562# = ??? White for 15 secs than restarts.
    #*2565# = Check Blocking
    #*3353# = Check Code
    #*3837# = ??? White for 15 secs than restarts.
    #*3849# = ??? White for 15 secs than restarts.
    #*3851# = ??? White for 15 secs than restarts.
    #*3876# = ??? White for 15 secs than restarts.
    #*7222# = Operation Typ (Class C GSM)
    #*7224# = I Got !! ERROR !!
    #*7252# = Oparation Typ (Class B GPRS)
    #*7271# = Multi Slot (Class 1 GPRS)
    #*7274# = Multi Slot (Class 4 GPRS)
    #*7276# = Dunno
    #*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
    #*2787# = CRTP ON/OFF
    #*3737# = L1 Dbg data
    #*5133# = L1 Dbg data
    #*7288# = GPRS Attached
    #*7287# = GPRS Detached
    #*7666# = SrCell Data
    #*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
    #*7284# = Class : B,C or GPRS
    #*2256# = Calibration Info
    #*2286# = Battery Data
    #*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
    #*2679# = Copycat feature (Activate or Deactivate)
    #*3940# = External loop test 9600 bps
    #*4263# = Handsfree mode (Activate or Deactivate)
    #*4700# = Half Rate (Activate or Deactivate)
    #*7352# = BVMC Reg value
    #*8462# = Sleeptime
    #*2558# = Time ON
    #*3370# = EFR (Activate or Deactivate)
    #*3941# = External looptest 115200 bps
    #*5176# = L1 Sleep
    #*7462# = SIM phase
    #*7983# = Voltage/Frequenci (Activate or Deactivate)
    #*7986# = Voltage (Activate or Deactivate)
    #*8466# = Old time
    #*2255# = Call ???
    #*5187# = L1C2G trace (Activate or Deactivate)
    #*5376# = ??? White for 15 secs than restarts.
    #*6837# = Official Software Version
    #*7524# = KCGPRS
    #*7562# = LOCI GPRS
    #*7638# = RLC allways open ended TBF (Activate or Deactivate)
    #*7632# = Sleep mode Debug
    #*7673# = Sleep mode RESET
    #*2337# = Permanent Registration Beep
    #*2474# = ???
    #*2834# = Audio Path
    #*3270# = DCS support (Activate or Deactivate)
    #*3282# = Data (Activate or Deactivate)
    #*3476# = EGSM (Activate or Deactivate)
    #*3676# = Flash volume formated
    #*4760# = GSM (Activate or Deactivate)
    #*4864# = Dunno doesn't work on newer versions
    #*5171# = L1P1
    #*5172# = L1P2
    #*5173# = L1P3
    #*7326# = Accessory (I got Vibrator)
    #*7683# = Sleep variable (
    #*7762# = SMS Brearer CS (Activate or Deactivate)
    #*8465# = Time in L1
    #*9795# = wtls key
    #*2252# = Current CAL
    #*2836# = AVDDSS Management (Activate or Deactivate)
    #*3877# = Dump of SPY trace
    #*7728# = RSAV done# (Everything went to standart but nothing was deleted)
    #*2677# = ARM State (None or Full Rate)
    *#8999*636# = Have no clue what it is, i see 20 lines
    *#9999# = Software version
    *#8999*8376263# = HW ver, SW ver and Build Date
    *#8888# = HW version
    *#8377466# = Same HW/SW version thing
    *#7465625# = Check the locks
    *7465625*638*Code# = Enables Network lock
    #7465625*638*Code# = Disables Network lock
    *7465625*782*Code# = Enables Subset lock
    #7465625*782*Code# = Disables Subset lock
    *7465625*77*Code# = Enables SP lock
    #7465625*77*Code# = Disables SP lock
    *7465625*27*Code# = Enables CP lock
    #7465625*27*Code# = Disables CP lock
    *7465625*746*Code# = Enables SIM lock
    #7465625*746*Code# = Disables SIM lock
    *7465625*228# = Activa lock ON
    #7465625*228# = Activa lock OFF
    *7465625*28638# = Auto Network lock ON
    #7465625*28638# = Auto Network lock OFF
    *7465625*28782# = Auto subset lock ON
    #7465625*28782# = Auto subset lock OFF
    *7465625*2877# = Auto SP lock ON
    #7465625*2877# = Auto SP lock OFF
    *7465625*2827# = Auto CP lock ON
    #7465625*2827# = Auto CP lock OFF
    *7465625*28746# = Auto SIM lock ON
    #7465625*28746# = Auto SIM lock OFF
    *2767*3855# = E2P Full Reset
    *2767*2878# = E2P Custom Reset
    *2767*927# = E2P Wap Reset
    *2767*226372# = E2P Camera Reset
    #*6420# = MIC Off
    #*6421# = MIC On
    #*6422# = MIC Data
    #*6428# = MIC Measurement
    #*3230# = Trace enable and DCD disable
    #*3231# = Trace disable and DCD enable
    #*3232# = Current Mode
    #7263867# = RAM Dump (On or Off)
    *2767*49927# = Germany WAP Settings
    *2767*44927# = UK WAP Settings
    *2767*31927# = Netherlands WAP Settings
    *2767*420927# = Czech WAP Settings
    *2767*43927# = Austria WAP Settings
    *2767*39927# = Italy WAP Settings
    *2767*33927# = France WAP Settings
    *2767*351927# = Portugal WAP Settings
    *2767*34927# = Spain WAP Settings
    *2767*46927# = Sweden WAP Settings
    *2767*380927# = Ukraine WAP Settings
    *2767*7927# = Russia WAP Settings
    *2767*30927# = GREECE WAP Settings
    *2767*73738927# = WAP Settings Reset
    *2767*49667# = Germany MMS Settings
    *2767*44667# = UK MMS Settings
    *2767*31667# = Netherlands MMS Settings
    *2767*420667# = Czech MMS Settings
    *2767*43667# = Austria MMS Settings
    *2767*39667# = Italy MMS Settings
    *2767*33667# = France MMS Settings
    *2767*351667# = Portugal MMS Settings
    *2767*34667# = Spain MMS Settings
    *2767*46667# = Sweden MMS Settings
    *2767*380667# = Ukraine MMS Settings
    *2767*7667#. = Russia MMS Settings
    *2767*30667# = GREECE MMS Settings
    *335# = Delete all MMS Messages
    *663867# = Dump Mm file
    #*536961# = WAPSAR enable / HTTP disable
    #*536962# = WAPSAR disable / HTTP enable
    #*536963# = Serial eable / Others disable
    #*53696# = Java Download Mode
    #*5663351# = Wap Model ID [Your Model]
    #*5663352# = Wap Model ID [SEC-SGHXXXX/1.0]
    #*566335# = Wap Model ID [SEC-SGHXXXX/1.0]
    *2767*66335# = Check on which model it is
    *2767*7100# = SEC-SGHS100/1.0
    *2767*8200# = SEC-SGHV200/1.0
    *2767*7300# = SEC-SGHS300/1.0
    *2767*7650# = Nokia7650/1.0
    *2767*2877368# = Reset WAP Model ID to standart
  2. ( Hai_GSM_Pro ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    GSM_Body (04-10-2012)
  1. FuriousGold Samsung Code Reader V1.0.3.9 + MTK Code Reader V1.0.0.599
    By toilatoi142001 in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 08-07-2015, 13:58
  2. Trả lời: 2
    Bài viết cuối: 24-10-2014, 13:04
  3. code mới cho samsung
    By quanghf1 in forum Phần mềm Samsung
    Bài viết cuối: 12-06-2009, 08:16
  4. all samsung unlock code,here!!!
    By tin_vinaphone in forum Phần mềm Samsung
    Bài viết cuối: 28-08-2008, 14:33
  5. All code Samsung
    By BlachThon in forum SAMSUNG
    Trả lời: 14
    Bài viết cuối: 27-02-2007, 11:41
