e cứ chạy tới đây thì nó báo thế này ae giứp e cái nha
Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010)
Processing MCU file: rm561__09.95.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1030020B81CB89566B4CEB3469ADC70E091758AF
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
CMT PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase skipped.
Flash programming ...
CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100303130 (RAP Certificate 202 v.1) written.
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x01380400, Result: 0010
Flashing terminated with error(s) in 32.672 s
RX Buffer: C7012D0103CD000010000000F172
tới đây là dừng ko chạy típ dc
