máy em nhận của khách là bị vào nước . luộc mên sấy khô rùi . em thay mấy cái màn zin nó củng báo contact hết. em chạy phần mền thì nó báo lỗi như sau . anh em xem rùi giúp em với ạk .
MXKEY Serial: [FT SCR2000 0] - C0845DFF
Driver: UFS2XX, ver: 2.0.0.0, NTMP ver: 2.0.0.1
Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
ASIC ID: 0x2201 [UPP_2M ver: 2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
UEM ID: 00452BF4:2984DA60
ASIC type: 2
UEM Imei: 35765601277671
Flash Imei: 35765601277671
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\3576560127767 1_BA CK.rpl"
Processing MCU file: rh93_07.020
[DCT4,DCT4 ALGORITHM] size: 1.89 MB
Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033
Area [01000000-0100FFFF] erased in 0.469 s
Area [01010000-013BFFFF] erasing ...
Error while erasing 0x012F0000-0x0130FFFF, Result: 01000000
flashing terminated !
Task failed at (08000025)!!!
Last RX buffer: 01 00 00 00 00 B1 72
