Kết quả 1 tới 8 của 8
    Thành viên tích cực bomnokia's Avatar
    Aug 2010
    Mặc định xem giúp em cái log 2700c
    em nhận máy trong tình trạng chết nguồn . kẹp kim dồng hồ dòng bật nguồn nhích treo . em bỏ vào hộp chạy ko được . em đóng lại nhà lầu và 2 con vetu rùi . ko bong mạch in . em chạy lại thì nó báo thế này .
    MXKEY Serial: [FT SCR2000 0] - C0845DFF
    Driver: UFS2XX, ver: 2.0.0.0, NTMP ver: 2.0.0.1
    Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011)
    Processing MCU file: rm561__09.98.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 1C200015648800563A40A91511C925C15114476D
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
    FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,CMT
    ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
    TransmissionMode: 16Bit
    Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
    CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
    Erase size: 21 MB
    CMT NOR area [00000000-000006BF] erased in 0.625 s
    CMT NOR area [000006C0-0001FFFF] erased in 0.156 s
    CMT NOR area [00040000-000BFFFF] erased in 2.313 s
    CMT NOR area [000C0000-0013FFFF] erased in 0.219 s
    CMT NOR area [00140000-0137FFFF] erased in 1 min 13.828 s
    CMT NOR area [01380000-0151FFFF] erased in 7.297 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100303130 (RAP Certificate 202 v.1) sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Programming completed in 12 min 56.843 s
    Processing PPM file: rm561__09.98.ppm_t
    [BB5,BB5 ALGORITHM] size: 6.62 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 8.62 MB
    CMT NOR area [01520000-01DBFFFF] erased in 28.812 s
    Programming completed in 4 min 43.829 s
    Processing CNT file: rm561__09.98.image_t_ph_gray
    [BB5,BB5 ALGORITHM] page size: 128 K size: 10.89 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 34 MB
    CMT NOR area [01DC0000-0215FFFF] erased in 0.906 s
    CMT NOR area [02160000-03FBFFFF] erased in 51.828 s
    Programming completed in 7 min 15.063 s
    Total time for flashing process(boot+erase+write) was 28 min 31.188 s
    Phone not responding !
    XEM RÙI GIU'P EM CÁI . THANK
    Thành viên chính thức binhminhmobile1's Avatar
    Jul 2011
    chuyển sang hwk hoặc JAF Flash lại đi anh
    V.I.P thanhtunggialai™'s Avatar
    Nam Định
    flash bằng USB đi bạn .không được đóng lại nhà lầu chuẩn vào .không được thì thay luôn nhà lầu đi .
    Thanh Tùng Mobile
    Địa chỉ : Chợ gạo - Thành Lợi - Vụ Bản - Nam Định
    Phone : 0905022590
    Thành viên tích cực liencuongmobile's Avatar
    Oct 2009
    Usa
    đưa qua box khác chạy lại hok dc chỉ còn đường thay cặp
    Aug 2010
    em đang chạy bằng usb . hwk của em bị hỏng rùi . nếu ko được thì em xây nhà lầu mới cho sang . ở cho sạch .
    Aug 2010
    ko được các bác ơi . h tìm đâu ra nhà 2 tầng để xây vào đây . có cách nào nữa ko các bác ơi . em làm lại chân mà chạy được như thế là chuẩn rùi . mà lai ko bong mạch in . sao lại ko dược nhỉ . em làm lại cả 4 em rùi mà ko được . có khi nào nó bị lỗi trung tần ko các huynh .
    May 2011
    Hà Nội City
    đóng lại nhà lầu xem ok không đã
    rùi hãy tính đến thay bạn à
    Thành viên chính thức baoduc_ayunpa's Avatar
    Mar 2011
    xây nhà mới cho e nó đi anh ơi....mấy dòng này chạy đến xì nó vẫn vậy....
  1. 2700c xin giúp.
    By hoanganht in forum BB5
    Trả lời: 15
    Bài viết cuối: 22-12-2012, 09:23
  2. Trả lời: 4
    Bài viết cuối: 20-06-2012, 18:25
  3. 2700c cần giúp
    By mrtuong1987 in forum BB5
    Bài viết cuối: 15-08-2011, 19:48
  4. Trả lời: 15
    Bài viết cuối: 01-06-2011, 12:30
  5. xin giúp em ic 2700c
    By minhhung780 in forum BB5
    Trả lời: 36
    Bài viết cuối: 28-05-2011, 21:17
