máy hàng campuchia no tiếng việt dùng mx key flash by usb ok
MXKEY Serial: [FT SCR2000 0] - C080AB35
Connection status: #EHCI:HUB::USB 2.00 (High-speed)
Driver: nmwcdnsuc, ver: 7.1.32.62
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Processing MCU file: RM-559_20.0.005_prd.core.C00
[BB5,XSR 1.6] size: 105.81 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 39CDAAEB
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 1DB00102A58E0052B3132A811E51FACE45D73443
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0058 - 0000 0121 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped.
CMT PAPUBKEYS HASH: E00DA77BF32983F864BC7671FE7709A29D8E2C08
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 178.94 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-0B71FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: E00DA77B [RAP Certificate 191 v.1] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 1 min 46.704 s
Processing PPM file: RM-559_20.0.005_prd.rofs2.V20
[BB5,XSR 1.6] size: 17.85 MB
Erase size: 41.87 MB
CMT FLASH,MuxOneNAND area [07920000-0A2FFFFF]
CMT SOS+ROFS2 block sent
Programming completed in 18.531 s
Total time for flashing process(boot+erase+write) was 2 min 19.906 s
Waiting for USB device removal ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia X6-00 USB Phonet, PORT_ID: 83C5523
Verifying communication to device OK.
Phone type: RM-559 (Nokia X6-00)
SW version: V ICPR72_10w04.5 22-03-10 RM-559 (c) Nokia
Imei plain: 35604603708312-1
Product code: 0589424
Battery voltage: 4022 mV, current: 225 mA
ApeCoreSw: V 20.0.005
Language Pack:
- not available.
Detected as PA_SL3 phone.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356046037083121
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
anh em nào biết rồi đừng chém nha,tạo tài liệu cho anh em mới vô nghề
