Kết quả 11 tới 12 của 12
  1. #11
    Thành viên tích cực ngocminhhungyen's Avatar
    Feb 2009
    jhhj
    đây là log băng jaf
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000030000022600010007600C192102031104
    Asic Mode ID: 00
    Asic EM ID: 00000C30
    Asic Public ID: 04A0010B1A270049C0D489A3C88DA44E266B7E0E
    HASH: 916F75217F32081248B15C38DFC8E81B00000000
    ROM ID: E693EF0DAC22615B
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPUv11_2nd.fg
    Loader version: 09.30.00 -> Revision: 0300
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 00400020 <=> ST -> Type not in database
    CMT Flash Data: NOT AVAILABLE
    C:\Program Files\ODEON\JAF\Flash\RAPUv11_XSR17_alg.fg...
    .........................Sending CMT HASH for PASUBTOC
    .........................Sending CMT HASH for ALG
    .............Done!
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V ICPR82_11w16.4
    02-06-11
    RM-645
    (c) Nokia
    HW version: 6000
    PCI version:
    RFIC version:
    DSP version:
    APE SW Core version: 071.005
    APE Variant version: 071.005071.005.16.01
    APE Test version: rm645_ENO_v_0.ncp71_17_001
    Retu version: 35
    Tahvo version: 00
    APE HW version: 256
    APE ADSP SW version: 256
    Production serial number: CZE689085
    Product code: 0593574
    Module code: 0204492
    Basic production code: 0591907
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 353757041056365
    IMEI spare to net: 3A 35 57 07 14 50 36 06
    IMEI SV to net: 33 35 57 07 14 50 36 16 F5
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 0000000000000000
    Provider: Unknown provider
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-645.ini
    Setting local mode...
    Reading product code...
    Product Code: 0593574
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-645\
    Checking path: \Products\RM-645\
    No ini files found...
    Done!
    Repair - Unlock - Nạp tiếng việt - Chuyển hệ cho tất cả các loại ĐTDĐ
  2. #12
    Feb 2009
    jhhj
    log mxkey
    MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C085315E
    Using device: HTI BOX, FW ver: 00.17
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
    CMT Data :
    SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1]
    EM0 ID: 00000C35
    EM1 ID: 00000C30
    PUBLIC ID: 04A0010B1A270049C0D489A3C88DA44E266B7E0E
    ASIC MODE ID: 00
    ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 9.50.0 revision: 3.0 size: 0x3A40
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
    Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
    Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 9.50.0 revision: 3.0 size: 0x7F29B
    FUR: Adding Asic CMT as client OK
    CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
    Original Imei: 35375704105636
    Original Product code: 0593574
    Bluetooth ID: 6C9B029F73D0
    SIMLOCK PA identifier:
    [0] PA_SIMLOC30
    Phone type: RM-645 (Nokia C5-00)
    SW version: V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia
    Imei plain: 35375704105636-5
    Battery voltage: 4593 mV, current: 79 mA
    ApeCoreSw: 071.005
    Language Pack:
    - not available.
    Detected as PA_SL3 phone.
    - Avoid SW Downgrade & manual erase to this phone !
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 353757041056365
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
