7210 là NHL-4 còn 6260 là RM-25 or RM 29 hai dòng khác nhau chứ sao giống được
Một Nửa Tôi Ơi ....... Đâu Rồi !!!!!!!!!
cho mình hỏi flash 6300 down ở đâu vậy
anh co file 6340i ko vậy, em dang cần gấp, thanks nhìu
NOkia North America:
6340i DP V6.0 Complete
6340i Data Pack V6.0-Flash 8.06.1. Complete install package for High speed or broadband downloads only.
Published 10/23/2007 Size 7.2 MB File type -> Phoenix Flash Files
Support Library -> 6340i
6340i DP V5.0 Zip.zip
6340i Data Pack V5.0 - Flash 8.05.3 (2 of 2). Requires WinZip 8.1.
Published 10/23/2007 Size 2.9 MB File type -> Phoenix Flash Files
6340i DP V5.0 Zip.z01
6340i Data Pack V5.0 - Flash 8.05.3 (1 of 2). For some reason, a .zip extension is being added to the file when it is downloaded. Please remove the .zip from this filename. Then run DP5.0 Zip.zip file to recompile the files. Requires WinZip 8.1.
Published 10/23/2007 Size 5.0 MB File type -> Phoenix Flash Files
6340i DP V5.0 Complete
6340i Data Pack V5.0-Flash 8.05.3. Complete install package for High speed or broadband downloads only.
Published 10/23/2007 Size 8.1 MB File type -> Phoenix Flash Files
6340i DP V4.0 Zip.zip
6340i Data Pack V4.0 - Flash V8.04.1 (2 of 2).
Published 10/23/2007 Size 2.7 MB File type -> Phoenix Flash Files
6340i DP V4.0 Zip.z01
6340i Data Pack V4.0 - Flash V8.04.1 (1 of 2). For some reason, a .zip extension is being added to the file when it is downloaded. Please remove the .zip from this filename. Then run DP4 Zip.zip file to recompile the .z01 file. Requires WinZip 8.1.
bác ơi cho em xin phền mềm 2610b rh87 . thanks
anh chị ơi làm ơn cho mình xin file pm 6300 nhé. cám ơn nhiều
cho em xin file 6270 ver trên 3.90 nhé
ai có file chay 6270 cho minh xin với!(ver4.0)!
cho em xin file pm full của 6020 với
