Đây ạ:
MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0880234
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0101040E
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: nmwcdc, ver: 7.1.32.84
Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Processing MCU file: rm645_071.005_prd.core.fpsx
[BB5,XSR 1.6] size: 96.64 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00000C35
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 1FC00201D9940344F2C0B996A0980184D9649C41
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 312BF85E
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35375704455380_CE RT.rpl).
CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 170.06 MB
CMT FLASH,MuxOneNAND area [00020000-0003FFFF]
CMT FLASH,MuxOneNAND area [00060000-004DFFFF]
CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 18.234 s
Processing PPM file: rm645_071.005_16.01_Vietnam_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 30.75 MB
Erase size: 51 MB
CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 5.719 s
Processing PPM file: rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 8.01 KB
Erase size: 14 MB
CMT FLASH,MuxOneNAND area [0A040000-0AE3FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 0.031 s
Processing CNT file: RM645_ENO_10wk48v0.001.fpsx
[BB5,XSR 1.6] size: 2.25 MB
Erase size: 4 MB
CMT FLASH,MuxOneNAND area [004E0000-008DFFFF]
CMT SOS*ENO block sent
Programming completed in 0.437 s
Processing CNT file: rm645_071.005_U000.000_prd.uda.fpsx
[BB5,XSR 1.6] size: 1.32 MB
Erase size: 72 MB
CMT FLASH,MuxOneNAND area [0AE40000-0F63FFFF]
Programming completed in 0.704 s
Total time for flashing process(boot+erase+write) was 55.797 s
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
bật nguồn thì rung một cái nhưng không lên nguồn xin gia đình giúp đỡ em với ạ em xin cảm ơn nhiều
