Kết quả 1 tới 10 của 14
    Thành viên tích cực HOÀNGTRUY_GSM's Avatar
    Jan 2011
    Cần Thơ
    Mặc định AE xem dùm log JAF +pkley>>>>>>>>>>>
    mình thử lôi ra chạy thử 1600,6030,2600c,info thì dc nhưng Flash thì báo lỗi hết,3cay y chang ae xem wa và cho hướng giải quyết.thân
    info
    JAF version 1.98.63
    Detected PKEY: 9002D26F
    Card life counter: 26.48%
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V y3.43
    13-09-05
    RM-74
    (c) Nokia.
    HW version: 0601
    PCI version:
    UEM version: 1314
    UPP version: 8241
    RFIC version: 0500
    DSP version: P05w06.v18
    LCD version: ELBE
    PPM version: V y3.43
    13-09-05
    RM74
    (c) Nokia.
    V
    Production serial number: MYF739743
    Product code: 0525021
    Module code: 0202572
    Basic production code: 0519975
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 357598005071313
    IMEI spare to net: 3A 75 95 08 50 70 31 01
    IMEI SV to net: 33 75 95 08 50 70 31 01 F6
    Master Code: 3375043623
    Phone type: RM-74, Software version: y3.43, Language Pack: V
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-74.ini
    Setting local mode...
    Reading product code...
    Product Code: 0525021
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-74\
    Checking path: \Products\RM-74\
    No ini files found...
    Done!
    Jan 2011
    Cần Thơ
    và đây là log FLash
    Phone Type:
    MCU Flash file: H:\Ph?n m?m\6030_RM-74_5.40\6030 RM-74_5.40\rm74__5.400
    Phone Type:
    PPM Flash file: H:\Ph?n m?m\6030_RM-74_5.40\6030 RM-74_5.40\rm74__5.40v
    Phone Type:
    CNT Flash file: H:\Ph?n m?m\6030_RM-74_5.40\6030 RM-74_5.40\rm74__5.40.image_v
    Reading IMEI...
    Reading IMEI data...
    Building RPL backup file...
    C:\Program Files\ODEON\JAF\ProgData\357598005071313_imei_back up_05011.rpl
    Done!
    Backup imei OK!
    Flashing Done!
    Operation took 0 minutes 2 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    IMEI: 357598005071313
    Resetting PPC...
    Done!
    Jan 2011
    Cần Thơ
    thử lại nhiều lần,remo JAF và setup lại cũng not ok,ko cho flash.mong ae cho ý kiến
    Thành viên tích cực QUỐCTHANG_MOBILE's Avatar
    Apr 2010
    bạn up box lại xem sao, cái này cũng hay bị lỗi lắm.
    Mar 2012
    nam định
    xóa full flash.nạp lại xem sao.k dk thì bác cho thử qua box khác xem có dk k.
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
    Jan 2011
    Cần Thơ
    Trích Được post bởi dongphucthang Xem bài viết
    up lại sao bạn,1.98.63 đã chuẩn chưa?remo và setup lại cũng vẫn thế
    Jan 2011
    Cần Thơ
    Trích Được post bởi khocvole Xem bài viết
    vấn đề ở đây là lỗi box,mà ko bit nguyên nhân chứ mình lấy 3 cây bình thường ra Flash mà
    Mar 2012
    nam định
    sax.bác thử chạy bănngf box khác xem sao đã. ....... xóa full flash. nạp lại.k dk thì rết máy tình lại-cuối cùng lf cài lại win
    Moderator VanTuan-ST's Avatar
    Nov 2007
    Sóc Trăng
    Bản 1.98.63 hay 1.98.62 là chuẩn rồi qua yahoo mình xem cho.
  10. ( VanTuan-ST ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    HOÀNGTRUY_GSM (25-03-2012)
  11. #10
    Jan 2011
    Cần Thơ
    Trích Được post bởi VanTuan-ST Xem bài viết
    đã lên yahoo rồi,nhưng bác ko onl
  1. Anh em xem dùm con 6085 bus check bị lỗi gì dùm em với
    By hunglangtu_qb in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-08-2013, 09:11
  2. Xin a/e check dùm con 3gs và tư vấn dùm e
    By keylove779 in forum iPHONE 3Gs
    Bài viết cuối: 03-08-2013, 11:47
  3. Anh em chỉ dùm hộp mt-box
    By trangvinh in forum MT-Box
    Trả lời: 27
    Bài viết cuối: 26-12-2012, 10:37
  4. xin chỉ dùm em ATF bị làm sao
    By xecgayhiep in forum Advance Turbo Flasher
    Bài viết cuối: 29-03-2012, 20:11
  5. Mấy anh xem dùm log n-gate qd dùm
    By minhkhoa_iphone in forum DCT4 - WD2
    Bài viết cuối: 14-12-2009, 14:42
