Version from phone: 03.90
Version from file: 03.90
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085886D
Using device: HTI, FW ver: 00.50, SN: 000074D6
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35757900438595_BA CK.rpl).
Processing MCU file: rm56b5003.90.mcusw.bin
[BB5,BB5 ALGORITHM] size: 11.06 MB
Supported Ids: 0103192101001101, 010C192101001101
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
EM0 ID: 00000232
EM1 ID: 00000352
PUBLIC ID: 11800117D5555156895A7E7AC84446938913AB87
ASIC MODE ID: 00
ROM ID: 191EC665DFAAF68F
eBB5ProtocolType: OLD
Storage0: 00EC 22FE - 0000 7921 [Samsung K8S5615ETA,256 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: 543D4EB3D80EB900F842AE957BC9AC364E7E653F
TransmissionMode: DDR&TX2
Erase size: 16.79 MB
CMT FLASH,NOR area [00180000-00B69DB5]
CMT FLASH,NOR area [00000000-000FFFFF]
CMT FLASH,NOR area [00120000-0017FFFF]
CMT FLASH,NOR area [00C00000-0117FFFF]
erased in 1 min 55.547 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 7776EE6A [RAP Certificate 11 v2] sent
CMT DSP0 block sent
CMT PMM_CONF block sent
CMT SBIF_CONF block sent
CMT PASUBTOC block sent
CMT PRIMAPP block sent
CMT UPDAPP block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 10.625 s
Processing PPM file: rm56b5003.90.ppm_v
[BB5,BB5 ALGORITHM] size: 5.15 MB
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000352
ASIC MODE ID: 00
Erase size: 5.50 MB
erased in 1.281 s
NOR: OK
NOR: OK
Programming completed in 33.984 s
Processing CNT file: rm56b5003.90.image_v
[BB5,BB5 ALGORITHM] page size: 64 K size: 5.69 MB
NOR page size in the phone is 64 K.
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000352
ASIC MODE ID: 00
Erase size: 14.37 MB
CMT FLASH,NOR area [01180000-01FDFFFF]
erased in 1 min 41.000 s
NOR: OK
NOR: OK
Programming completed in 37.828 s
Total time for flashing process(boot+erase+write) was 6 min 40.672 s
Phone type: RM-56 (Nokia 6270)
SW version: V 03.90 09-02-07 RM-56 (c) Nokia.
Imei plain: 35757900438595-3
Product code: 0528319
Battery voltage: 4858 mV, current: 62 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 357579004385953
Version: SIMLOCK SERVER VERSION 61
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
máy dang bị contacsevit em chay mãi ko dc
em tim file pm của nó nhưng ko thấy
em mới làm phần mềm mong các cao thủ chỉ giúp
