USB BOOT : 60,07 [Rm-625] [2.2.0.0]
CMT ASICID: 000000010000022600010006400C192101051105
EM 1 ID : 00000296
EM 2 ID : 00000B22
CMT PUBID : 13E0000B00B200527F2BEC90BFA8B34380FB9ED0
CMT MODE : 00
CMT HASH : B8C3ADECFC997FCD8081D3DEAF870B8C
CMT ROMID : 4B9B75103E691FF8
CMT 2ND Bt: RAPIDOv11_2nd.fg, Ver: 11.16.0
CMT 2ND Bt: SILO OK
CMT RMID0 : 00000000-00000000
CMT MCID0 : FFFF0000-00000000
CMT FLID0 : 00EC0040-00000231, Sam OneNAND-2G
CMT RQALG : XSR 1.5
CMT 2ND Boot OK
CMT ALGO : RAPIDOv11_XSR15_alg.fg, Ver: 11.16.0
CMT KSIG0 : 7DC72D3FDC552426A4479BC820097D304CFB6C15
CMT ALG Boot OK
IMAGE : RM-625_40.9.003_prd.core.C00
CMT NAND Erase Area: 0x00040000-00082FFF
CMT NAND Erase Area: 0x00083400-003FFFFF
CMT NAND Erase Area: 0x00400000-007FFFFF
CMT NAND Erase Area: 0x00800000-00D5FFFF
CMT NAND Erase Area: 0x00D60000-09E5FFFF
CMT NAND Partition Format
CMT FLASH ERASE OK, Time: 00:01
Written: 12 Certificate(s)
CMT FLASH WRITE OK, Time: 01:31
IMAGE : RM625_40.1.003_001_003_U002.uda.fpsx
CMT NAND Erase Area: 0x09E60000-0F47FFFF
CNT FLASH ERASE OK, Time: 00:00
CNT FLASH WRITE OK, Time: 00:12
IMAGE : RM-625_40.9.003_prd.rofs2.V25
CMT NAND Erase Area: 0x06CE0000-0915FFFF
PPM FLASH ERASE OK, Time: 00:00
Written: 1 Certificate(s)
PPM FLASH WRITE OK, Time: 00:26
IMAGE : RM-625_40.9.003.548.02.rofs3.fpsx
CMT NAND Erase Area: 0x09160000-09E5FFFF
CUS FLASH ERASE OK, Time: 00:00
CUS FLASH WRITE OK, Time: 00:06
Flashing Completed, Rebooting Mobile
đây là log hwk
DƯỚI ĐÂY LÀ MXBOX
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0820790
Using device: USB ROM and HTI, FW ver: 00.50, SN: 000107A0
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
Processing MCU file: RM-625_40.9.003_prd.core.C00
[BB5,XSR 1.6] size: 92.37 MB
Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 13E0000B00B200527F2BEC90BFA8B34380FB9ED0
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped.
CMT PAPUBKEYS is blank/erased.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 158.19 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent
CMT SOS*UPDAPP block sent
CMT SOS*ENO block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 1 min 28.640 s
Processing PPM file: RM-625_40.9.003_prd.rofs2.V25
[BB5,XSR 1.6] size: 26.32 MB
Erase size: 36.50 MB
CMT FLASH,MuxOneNAND area [06CE0000-0915FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 25.765 s
Processing CNT file: RM-625_40.9.003.548.02.rofs3.fpsx
[BB5,XSR 1.6] size: 6.38 MB
Erase size: 13 MB
CMT FLASH,MuxOneNAND area [09160000-09E5FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 6.546 s
Total time for flashing process(boot+erase+write) was 2 min 10.046 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal
lấy máy tính khác cài phoenix chiến cũng không lên luôn.ae cho em xin thêm ý kiến.thanks
