Kết quả 1 tới 7 của 7
    Thành viên chính thức transinco1_5's Avatar
    May 2007
    Mặc định c3-00 cần giúp
    Em có con c3-00 bị trắng màn hình treo máy (bât máy lên trắng màn hình chơp chơp) em flash lại nó thế này
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C08749C4
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100C8F1
    Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.75
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
    Processing MCU file: rm614__08.71.mcusw
    [BB5,XSR 1.6] size: 27.92 MB
    Supported Ids: 2200050920030000, 22000509200C0000
    CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
    CMT EM0 ID: 00005361
    CMT PUBLIC ID: 0000000000F8F1E428E4D1D76D32B77DC4742C8F
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
    CMT ROM ID: DE56D582BDDE7A3A
    Loading CMT secondary boot code
    SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
    Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
    Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Loading CMT update server data
    Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
    Update server code loaded.
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2861447B
    FUR: Adding Asic CMT as client OK.
    Reading CMT NPC (0x190 bytes).
    Reading CMT VARIANT (0x0 bytes).
    Reading CMT CCC (0x178 bytes).
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Reading CMT MDM_KEYS (0x0 bytes).
    Reading CMT PARTNERC (0x0 bytes).
    Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35624704682708_CE RT.rpl).
    CMT PAPUBKEYS HASH: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
    Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 33.88 MB
    CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
    CMT FLASH,MuxOneNAND area [00020000-000203FF]
    CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
    CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
    CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
    Formating partition ...
    Flash programming ...
    CMT KEYS block sent
    CMT ADA block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 697F7477 [RAP Certificate v1 232] sent
    CMT UPDAPP block sent
    CMT MCUSW block sent
    CMT MCUSW1 block sent
    CMT GENIO_INIT block sent
    CMT ISA+DYNSW block sent
    Programming completed in 40.016 s
    Processing PPM file: rm614__08.71.ppm_v
    [BB5,XSR 1.6] size: 6.80 MB
    Erase size: 8 MB
    CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
    Programming completed in 10.515 s
    Processing CNT file: rm614__08.71.image_v_0598884
    [BB5,XSR 1.6] size: 13.01 MB
    Erase size: 75.31 MB
    CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
    Programming completed in 18.328 s
    Total time for flashing process(boot+erase+write) was 1 min 26.250 s
    Waiting for device boot up ...
    Warning: Phone did not reboot to normal mode.
    [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
    Market items is empty, please select the correct products path !
    May 2007
    bus check thì nó báo thé này
    Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100C8F1
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Original Imei: 35624704682708
    Original Product code: 0598884
    Bluetooth ID: AC932F6FFCB9
    SIMLOCK PA identifier:
    [0] PA_SIMLOC30
    Thành viên tích cực NT.mobile's Avatar
    xem lại vệ sinh kỉ socket màng hình đi bạn.
    làm cả đời !! hết một giờ
    Thành viên chính thức BENH VIEN DT NGUYEN CHINH's Avatar
    vệ sinh sạch sẻ,kiểm tra sóc két,thay màn hình thử.thân!
    Thành viên tích cực Phúc_Cần Thơ's Avatar
    Dec 2008
    Miền GạoTrắng,Nước Trong.
    Coi cái log của người ta kìa bạn ơi,màn hình tính sau đi
    Sữa Chữa_Unlock_Tiếng Việt => Nạp Phần Mềm All Mobile
    Thành viên tích cực hieungau1983's Avatar
    Dec 2008
    cpu thẳng tiến đi anh zai
    không đâm không chém đời không nể không tiền không bạc không có chi
    May 2007
    socket rất đẹp , màn hình em thay trước khi flash rồi , nói chung mên còn rất đẹp .cpu thì em chưa muốn đụng vào , các bác có ai có giải pháp gì khác không giúp em với
