em chạy nhầm file 3110c . may mà backup rpl ko die con máy . em chạy lại và simlok rùi mà nó báo lỗi như vậy . ae ai đã gặp chỉ em với ạk . em cám ơn trước .
đây là log của em ấy :
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087B3AD
Using device: HTI, FW ver: 00.50, SN: 0100C747
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14213(16-10-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1540020821B87B561528E3E171E3D1871D54E0D0
ASIC MODE ID: 00
ROM ID: 191EC665DFAAF68F
eBB5ProtocolType: OLD
Storage0: 0001 0041 - 0000 6A21 [AMD ] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
TransmissionMode: DDR&TX2
Original Imei: 35677702402076
Original Product code: 0563812
Bluetooth ID: 0022FC1344DC
SIMLOCK PA identifier:
[0] PA_SL
Phone type: RM-217 (Nokia 6300)
SW version: V 07.21 05-11-08 RM-217 (c) Nokia.
Imei plain: 35677702402076-3
Battery voltage: 4654 mV, current: 90 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356777024020763
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
 LinkBack URL About LinkBacks
			 anh em xem giúp em cái log 6300
