MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0874A13
Using device: HTI, FW ver: 00.50, SN: 0100AF22
Connection status: OHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
UEM ID: 0065F694A3BDA66
ASIC type: 11
UEM Imei: 35604503984113
Flash Imei: 35604503984113
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35604503984113_BA CK.rpl"
Processing MCU file: rh105_05.910
[DCT4,DCT4 ALGORITHM] size: 2.28 MB
Supported Ids: 2292
Error sending bootloader !
flashing terminated !
mình bus chek thì báo lỗi mình chọn file chạy thì đến đây là đứng.nhờ ae xem dùm nó bị cái gì vậy
