Driver: nmwcdc, ver: 7.1.32.75
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
RPL backup already exist (C:\mobileEx\3.5\data\backup\BB5_35518005397282_BA CK.rpl).
Processing MCU file: rm781__07.57.mcusw
[BB5,XSR 1.6] size: 28.66 MB
Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108
NOR pagesize not defined, no changes will be made to CNT.
Battery voltage: 3930 mV
Phone type: RM-781 (Nokia 300)
Product code: 059J8F9
SW version: V 07.57 - 24-08-12 - RM-781 - (c) Nokia
LanguagePkg version: 7 - 24-08-12 - RM-781 - (c) Nokia - C
Version from phone: 07.57
Version from file: 07.57
Waiting for USB device removal ...
CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x]
CMT EM0 ID: 00001051
CMT EM1 ID: 00001060
CMT PUBLIC ID: CA120000FFFB7C400A0E4BE8097CD449E283EE12
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706
CMT ROM ID: 2CAC45E23BC33C8B
Loading CMT secondary boot code
SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0241 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5
Update server code loaded.
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1BF6FC6A
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: 9C9241FD29D3EDB35B15180A7DD9692987B4EE7C
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 44.56 MB
CMT FLASH,MuxOneNAND area [00040000-000403FF]
CMT FLASH,MuxOneNAND area [000C0000-0013FFFF]
CMT FLASH,MuxOneNAND area [00140000-004BFFFF]
CMT FLASH,MuxOneNAND area [004C0000-0073FFFF]
CMT FLASH,MuxOneNAND area [00740000-012BFFFF]
CMT FLASH,MuxOneNAND area [00160000-0017FFFF]
CMT FLASH,MuxOneNAND area [02D00000-032FFFFF]
CMT FLASH,MuxOneNAND area [0F080000-0F67FFFF]
CMT FLASH,MuxOneNAND area [012C0000-020FFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT PRIMAPP block sent
CMT KEYS block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 9C9241FD [] sent
CMT RAP3NAND block sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 8.969 s
Processing PPM file: rm781__07.57.ppm_v
[BB5,XSR 1.6] size: 8.83 MB
Erase size: 12 MB
CMT FLASH,MuxOneNAND area [02100000-02CFFFFF]
Programming completed in 2.516 s
Processing CNT file: rm781__07.57.image_v_059J8L5
[BB5,XSR 1.6] size: 47.21 MB
Erase size: 189.56 MB
CMT FLASH,MuxOneNAND area [03300000-0F07FFFF]
Programming completed in 10.547 s
Total time for flashing process(boot+erase+write) was 34.234 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 1141361E
Verifying communication to device OK.
SW version: V 07.57 24-08-12 RM-781 (c) Nokia
Imei plain: 35518005397282-5
Battery voltage: 3925 mV, current: 199 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: 0103B904008008, ver:
SIMLOCK seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355180053972825
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN![]()
