Kết quả 11 tới 19 của 19
    Thành viên kỳ cựu vvaodoi1980's Avatar
    Oct 2007
    Version from phone: 10.47
    Version from file: 10.47
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0859116
    Using device: HTI, FW ver: 00.50, SN: 0000D102
    Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
    Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35626104639358_BA CK.rpl).
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006030C192101023000 [RAP3G ver: PA 3.0]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 19B0010A4FA904564AEA32312390018BAAC2A913
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1
    TransmissionMode: DDR&TX2
    Processing MCU file: rm578__10.47.mcusw
    [BB5,BB5 ALGORITHM] size: 21.65 MB
    Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
    Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
    Erase size: 23.25 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00040000-000BFFFF]
    CMT FLASH,NOR area [000C0000-0013FFFF]
    CMT FLASH,NOR area [00140000-0155FFFF]
    CMT FLASH,NOR area [01560000-0175FFFF]
    erased in 1 min 42.984 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 8669C775 [RAP Certificate 215 v1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    NOR: OK
    Programming completed in 1 min 40.152 s
    Processing PPM file: rm578__10.47.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.78 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01760000-01FFFFFF]
    erased in 32.597 s
    NOR: OK
    NOR: OK
    Programming completed in 28.768 s
    Processing CNT file: rm578__10.47.image_v_black_v2
    [BB5,BB5 ALGORITHM] page size: 128 K size: 15.64 MB
    Erase size: 31.75 MB
    CMT FLASH,NOR area [02000000-0245FFFF]
    CMT FLASH,NOR area [02460000-03FBFFFF]
    erased in 1 min 51.134 s
    NOR: OK
    NOR: OK
    Programming completed in 1 min 10.302 s
    Total time for flashing process(boot+erase+write) was 7 min 34.005 s
    Phone type: RM-578 (Nokia 2730 classic)
    SW version: V 10.47 27-08-10 RM-578 (c) Nokia
    Imei plain: 35626104639358-1
    Product code: 059C0H6
    Battery voltage: 4831 mV, current: 43 mA
    Language Pack:
    - not available.
    SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
    warning: avoid SW Downgrade & manual erase to this phone !
    Camera config: NI00IIIIRR030102F201, ver: 006.006
    SIMLOCK seems to be valid
    SUPERDONGLE_KEY[MX] seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 356261046393581
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    long infor
    atf .nbox flash đụng nót củng không lên
    ĐẾN TỪ QUÊU HƯƠNG : ANH DŨNG KIÊN CƯỜNG ĐI ĐẦU DIỆT MĨ
    Thành viên chính thức dinhtrung832009's Avatar
    Oct 2009
    Trích Được post bởi vvaodoi1980 Xem bài viết
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    NOR: OK
    CMT NOLO block sent
    CMT KEYS block sent
    CMT DSP0 block sent
    NOR: OK
    Erase size: 8.62 MB
    erased in 32.597 s
    NOR: OK
    NOR: OK
    NOR: OK
    NOR: OK
    Language Pack:
    - not available.
    SIMLOCK_TEST passed
    Counter: 0/3, 0/10
    long infor
    con này flast ver chuẩn vào ko dc lag flast thôi
    yahoo:dinhtrung832012@yahoo.com
    Oct 2007
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    NOR: OK
    CMT NOLO block sent
    CMT KEYS block sent
    CMT DSP0 block sent
    NOR: OK
    Erase size: 8.62 MB
    erased in 32.597 s
    NOR: OK
    NOR: OK
    NOR: OK
    NOR: OK
    Language Pack:
    - not available.
    SIMLOCK_TEST passed
    Counter: 0/3, 0/10
    day là long flash
    Thành viên danh dự phithanhmobile's Avatar
    Nov 2012
    ĐỒNG THÁP
    khò con flash cái thử log đẹp mà ta
    Thành viên chính thức banhkeohaiha's Avatar
    Language Pack:
    - not available.
    mang qua bestool hoặc phonix đảm bảo ok ! thàng Mx yếu nắm !
    Thành viên mới xuandieu_68's Avatar
    Feb 2013
    Chào Anh Chị và các bạn. Mình có một máy điện thoại Sam sung MODEL:E1100T Hiện tượng bật nguồn lên vào đến màn hình một lúc rồi tự tắt nguồn?. Có Anh chị nào biết về căn bệnh này xin chỉ giáo hộ.Mình xin chân trọng cảm ơn rất nhiều.
    Nov 2012
    ĐỒNG THÁP
    Trích Được post bởi xuandieu_68 Xem bài viết
    lập thớt khác hỏi nha bạn
    Feb 2013
    Mặc định Máy khởi động lên mât nguồn
    Xin chào Các Anh Chị và các bạn .Hiện mình đang gặp một ĐT Alatca MODEL:S77 . Hiện tượng bật nguồn lên màn hình sáng trắng có một đường kẻ thẳng đứng nằm phía bên trái màn hình khoảng một phần ba màn hình, không có hiển thị gì cả. Mình mới vào nghề chưa có kinh nghiệm .Các Anh Chị Và các bạn ai gặp hiện tượng này xin chi giáo. Xin chân thành cảm ơn nhiều.
    Thành viên kỳ cựu thuanwhisky90's Avatar
    Feb 2012
    tây ninh
    chủ xị tháo bỏ em ic USB ra thử nha.đã gặp 1 em như vậy đó.
    thuan4ever2010@yahoo.com.0988756233:-----yêu thương chưa đủ---thì đừng đòi ngủ với anh---
  1. 2730c Rớt Nước MẤt Nguồn.......
    By quythongay in forum BB5
    Bài viết cuối: 07-11-2014, 16:19
  2. Trả lời: 14
    Bài viết cuối: 05-09-2013, 18:28
  3. Trả lời: 9
    Bài viết cuối: 31-05-2012, 12:21
  4. 2730c rớt nc mất nguồn
    By qkmobile_kcr in forum BB5
    Bài viết cuối: 07-11-2011, 18:02
  5. 2730c nạp đứng mất nguồn
    By nguyendong_mobi in forum BB5
    Bài viết cuối: 05-10-2011, 12:24
