MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C084B4A8
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 00010AA4
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: nmwcdnsuc, ver: 7.1.32.84
Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.53
EBL version: Quantum_Bootloader_10.53_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI: 35413605049200
RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35413605049200_ back.RPL)
Processing file: rm907__04.10.mcusw
Downloading item CODE:rm907__04.10.mcusw_ebl_psi.fls, num block: 4, size: 26 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.375 s
Erasing area 0x40040000-0x4005FFFE ...OK
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 2.329 s
Erasing area 0x40280000-0x41B3FFFE ...OK
Programming completed in 36.172 s
Checksum verified (0x5C1B)
Processing file: rm907__04.10.ppm_s3
Downloading item CUST
ackage_s3.ppm_ebl_psi.fls, num block: 1, size: 4.45 MB
Erasing area 0x41BC0000-0x4203137E ...OK
Programming completed in 6.672 s
Checksum verified (0xE247)
Processing file: rm907__04.10.image_s3_059Q8S5
ackage_s3_059Q8S5.image.fls, num block: 1, size: 15.75 MB
Erasing area 0x421C0000-0x43E1FFFE ...OK
Programming completed in 23.140 s
Checksum verified (0x3A03)
Total time for flashing process(boot+erase+write) was 8 min 0.578 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C2-00 USB Phonet, PORT_ID: 39B859DA
Verifying communication to device OK.
