nhận flash 1 em e71,
đầu tiên flash bằng usb không đc lấy
hwk ra quất fbus ok nhưng ==> khởi động rung 1 cái rồi thôi
lấy mx box ra flash cũng vậy
log bằng mx
Version from phone: 510.21.009
Version from file: 500.21.009
MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C087AD51
Using device: HTI, FW ver: 00.50, SN: 010094BE
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Reading RPL backup ...
Reading Phone IDs ...
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1E60010CDF418B52D6FF7E5B2D02144AE69FE9F9
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 52570A2086C79E6965175815B5388535CDD5C6F7
PRIVATE ID: 2088763588ABE9DAFF77FA8F77FF94089F62ECEF
E-FUSE: 0AC8CFBF
SEC ROM CRC: 3E691FF8
productData saved.
Restarting phone ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B49D
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Flash Imei: 35605903882924
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35605903882924_BA CK.rpl"
Processing MCU file: rm346_500.21.009_prd.c00
[BB5,XSR 1.5] size: 67.82 MB
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 122.56 MB
CMT FLASH,MuxOneNAND area [00040000-007FFFFF]
CMT FLASH,MuxOneNAND area [00A00000-0759FFFF]
CMT FLASH,MuxOneNAND area [0F1C0000-0F8BFFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: OK
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 52570A20 [RAP Certificate 101 v1] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS*CORE block sent
CMT SOS+ROFS block sent
NAND: OK
Programming completed in 2 min 19.829 s
Processing PPM file: rm346_500.21.009_prd.v29
[BB5,XSR 1.5] size: 22.55 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 33.56 MB
CMT FLASH,MuxOneNAND area [05420000-0759FFFF]
NAND: OK
CMT SOS+ROFX block sent
NAND: OK
Programming completed in 48.154 s
Processing CNT file: rm346_500.21.009.07U
[BB5,XSR 1.5] size: 21.06 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 64 KB
NAND: OK
NAND: OK
Programming completed in 46.111 s
Total time for flashing process(boot+erase+write) was 5 min 6.287 s
