nokia n6085 cần giúp ,lắp sim vào báo hạn chế điện thoại . .em đã chạy lại phần mềm rồi mà vẫn vậy .anh em nào biết giúp dùm. biết file flash nào úp lên cho em xin luôn . em chạy bằng phonix và jaf
JAF version 1.98.62
Detected PKEY: 9000CBE6
Card life counter: 99.99%
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.78.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-198\
Checking path: \Products\RM-198\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-198\rm198__06.00.mcusw.bin
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-198\rm198__06.00.ppm_v
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-198\rm198__06.00.image_v
Languages in ppm: English,Vietnamese,Chinese S,Chinese T
Detected P-KEY: 9000CBE6
Init usb communication...
Found
Init usb flashing...
Error init usb flashing...
Found
Found
Backing up CRT...
Reading IMEI...
Failed! Aborting!
Failed to backup CRT...
PRESS POWER ON NOW!
Searching for phone...Found
Error reading phone init data...
Backing up CRT...
Reading IMEI...
Failed! Aborting!
PRESS POWER ON NOW!
Backing up CRT...
Reading IMEI...
Failed! Aborting!
PRESS POWER ON NOW!
Sending RAW loader...
Using 06.02.002
Elf2flash 02.33.000 RAW loader...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting.......................................... .......................Loader Sent!
Stage 3 starting................Phone prepared OK!
Waiting for the phone to boot...
Status byte: 0400
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 744, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-198\rm198__06.00.mcusw.bin...
Erasing cmt zone 00000000 - 000DFFFF ... Erase result: 0000
Erasing cmt zone 00100000 - 0110FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-198\rm198__06.00.ppm_v...
Erasing cmt zone 01120000 - 015DFFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-198\rm198__06.00.image_v...
Erasing cmt zone 015E0000 - 01FDFFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for NOLO
Sending CMT HASH for KEYS
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
cmt->PAPUB keys already sent...
Sending CMT HASH for DSP0
Sending CMT HASH for PMM_CONF
Sending CMT HASH for SBIF_CONF
Sending CMT HASH for PASUBTOC
Sending CMT HASH for PRIMAPP
Sending CMT HASH for UPDAPP
Sending CMT HASH for MCUSW
Rebooting...
Restarting CMT...
Pooling phone...
MCUSW: V 06.00
28-11-07
RM-198
(c) Nokia.
APESW: (null)
VariantSW: (null)
Prodcode: 0540310
Done!
 LinkBack URL About LinkBacks
