Như Tiêu Đề Máy Bị Contast siever
Number of Image Files: 2
Processing Image File :
rm872__04.51.ppm_s3
rm872__04.51.image_s3_059Q8F1
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Unique Data: 1210041692152821
Original Product Code: 059Q8F1
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\354125052612246\3541250526122 46_124235.rpl
Certificate Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\354125052612246\3541250526122 46_CERTIFICATE_07F5B162.bin
PM Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\354125052612246\3541250526122 46_PMM_PROT_3300BC91.bin
Security Code: 12345
Data Sections : 01
Current File : rm872__04.51.ppm_s3
Compile Name: package_s3.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 6179584 Bytes
Sending Certificate Block
PPM Certificate Block Sent Successfully...
Processing Section 01
PPM Erase Block: 0x41A80000~0x420FFFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 6176240 bytes
Data Checksum: 6FA5
Uploading Data Blocks to phone...
Block Write Successful...
PPM Data Blocks uploaded to phone...
Data Verification Successful...
Data Sections : 01
Current File : rm872__04.51.image_s3_059Q8F1
Compile Name: package_s3_059Q8F1.image.fls
Image Type : CONTENT Package
Data Size : 17042704 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42100000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 17039360 bytes
Data Checksum: 34AA
CONTENT Data Blocks uploaded to phone...
Processing Section 02
CONTENT Erase Block: 0x43E60000~0x43F3FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:04:40
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
Basic Phone Information
MCU Version: V 04.51 31-05-13 RM-872 (c) Nokia
IMEI Plain : 354125052612246
IMEI Spare : A354125052612240
IMEI SV : 33541250526122410F
IMEI (2nd) : 354125052612253
IMEI Spare : A354125052612250
IMEI SV : 33541250526122510F
Phone Model: K 206
Category : Entry
Phone Type : RM-872
Extended Phone Information
Product Serial Number: DFFEF41AH
Product Code : 059Q477
Module Code : 0205283
Basic Production Code: 059P6H1
Long Production SN : 0
PPM SW Version : V 04.51 31-05-13 RM-872 (c) Nokia S3
BT MCM Version : 19b5-22012
MCU SW Version : V 04.51 31-05-13 RM-872 (c) Nokia
HW Version : 1600
RFIC Version : 68
LCD Version : TPO
Content Pack Version : Content: s3_059Q8F1 V 04.51 31-05-13 RM-872 (c) Nokia
Bluetooth ID : 54:79:75:F7:8B:60
CS Type : GSM900, GSM1800
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 800000000004000B
ASIC : 11
PROVIDER : Default Test Operator
LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : FAILED
> Try SX4 "PM AUTH"
> Then Write PM 1 and 309
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : 01029704
DCC Ver: 008013
Status : OK
Selected VPL File:
RM872_059Q8F1_04.51_021.vpl
Variant Details : RM-872 APAC_S3_MAGENTA_STROKE_VN
Software Version : 04.51
Product Type : RM-872
Product Code : 059Q8F1
Variant Version : 021
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
Life timer data is not yet used...
Life timer: ----:--
Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\Backup\358279042220416\3582790422204 16_RM-763_0-400_21314.pm
Start Uploading PM...
MCU: V 04.51 31-05-13 RM-872 (c) Nokia
IMEI: 354125052612246
Model : Kq 206
HW Version : 1600
RFIC Version : 68
LCD Version : TPO
ASIC : 11
ST_SIMLOCK_TEST : PASSED
ST_LCD_TEST : PASSED
MASTER_CODE : 1337177701
PHONE_MODE : TEST
DCC ID : 01029704
DCC Ver: 008013
Status : OK
Field : 1 Sub : 0 Byte(s): 12 - Ok
Field : 1 Sub : 1 Byte(s): 96 - Ok
Field : 1 Sub : 2 Byte(s): 112 - Ok
Field : 1 Sub : 4 Byte(s): 12 - Ok
Field : 1 Sub : 5 Byte(s): 48 - Ok
Field : 1 Sub : 6 Byte(s): 112 - Ok
Field : 1 Sub : 7 Byte(s): 452 - Ok
Field : 1 Sub : 8 Byte(s): 12 - Ok
Field : 1 Sub : 13 Byte(s): 112 - Ok
Field : 1 Sub : 15 Byte(s): 32 - Ok
Field : 1 Sub : 16 Byte(s): 32 - Ok
Field : 1 Sub : 17 Byte(s): 32 - Ok
Field : 1 Sub : 18 Byte(s): 32 - Ok
Field : 1 Sub : 19 Byte(s): 32 - Ok
Field : 1 Sub : 22 Byte(s): 24 - Ok
Field : 2 Sub : 0 Byte(s): 2240 - Failed
Field : 4 Sub : 3 Byte(s): 12 - Ok
Field : 4 Sub : 4 Byte(s): 8 - Ok
Field : 4 Sub : 5 Byte(s): 8 - Ok
Field : 4 Sub : 6 Byte(s): 8 - Ok
Field : 4 Sub : 9 Byte(s): 8 - Ok
Field : 8 Sub : 0 Byte(s): 4 - Ok
Field : 8 Sub : 1 Byte(s): 16 - Ok
Field : 8 Sub : 2 Byte(s): 16 - Ok
Field : 8 Sub : 3 Byte(s): 128 - Ok
Field : 8 Sub : 4 Byte(s): 128 - Ok
Field : 8 Sub : 7 Byte(s): 4 - Ok
Field : 8 Sub : 8 Byte(s): 8 - Ok
Field : 8 Sub : 9 Byte(s): 8 - Ok
Field : 8 Sub : 10 Byte(s): 32 - Ok
Field : 8 Sub : 11 Byte(s): 4 - Ok
Field : 8 Sub : 12 Byte(s): 4 - Ok
Field : 11 Sub : 0 Byte(s): 4 - Ok
Field : 11 Sub : 1 Byte(s): 4 - Ok
Field : 11 Sub : 2 Byte(s): 4 - Ok
Field : 11 Sub : 3 Byte(s): 4 - Ok
Field : 11 Sub : 4 Byte(s): 244 - Ok
Field : 12 Sub : 0 Byte(s): 8 - Failed
Field : 13 Sub : 0 Byte(s): 4 - Ok
Field : 13 Sub : 1 Byte(s): 4 - Ok
Field : 13 Sub : 2 Byte(s): 4 - Ok
Field : 13 Sub : 3 Byte(s): 4 - Ok
Field : 13 Sub : 4 Byte(s): 4 - Ok
Field : 13 Sub : 5 Byte(s): 4 - Ok
Field : 13 Sub : 6 Byte(s): 4 - Ok
Field : 13 Sub : 7 Byte(s): 4 - Ok
Field : 13 Sub : 8 Byte(s): 4 - Ok
Field : 13 Sub : 9 Byte(s): 4 - Ok
Field : 13 Sub : 10 Byte(s): 4 - Ok
Field : 13 Sub : 11 Byte(s): 48 - Ok
Field : 13 Sub : 12 Byte(s): 4 - Ok
Field : 13 Sub : 13 Byte(s): 4 - Ok
Field : 13 Sub : 14 Byte(s): 4 - Ok
Field : 13 Sub : 15 Byte(s): 888 - Ok
Field : 13 Sub : 16 Byte(s): 4 - Ok
Field : 13 Sub : 17 Byte(s): 4 - Ok
Field : 13 Sub : 18 Byte(s): 4 - Ok
Field : 13 Sub : 19 Byte(s): 8 - Ok
Field : 13 Sub : 20 Byte(s): 4 - Ok
Field : 13 Sub : 21 Byte(s): 4 - Ok
Field : 13 Sub : 22 Byte(s): 4 - Ok
Field : 13 Sub : 23 Byte(s): 4 - Ok
Field : 13 Sub : 24 Byte(s): 4 - Ok
Field : 13 Sub : 25 Byte(s): 4 - Ok
Field : 13 Sub : 26 Byte(s): 4 - Ok
Field : 13 Sub : 27 Byte(s): 4 - Ok
Field : 13 Sub : 28 Byte(s): 4 - Ok
Field : 13 Sub : 29 Byte(s): 4 - Ok
Field : 13 Sub : 30 Byte(s): 4 - Ok
Field : 13 Sub : 31 Byte(s): 4 - Ok
Field : 13 Sub : 32 Byte(s): 4 - Ok
Field : 13 Sub : 33 Byte(s): 4 - Ok
Field : 13 Sub : 34 Byte(s): 4 - Ok
Field : 13 Sub : 35 Byte(s): 4 - Ok
Field : 13 Sub : 36 Byte(s): 4 - Ok
Field : 13 Sub : 37 Byte(s): 4 - Ok
Field : 13 Sub : 38 Byte(s): 4 - Ok
Field : 13 Sub : 39 Byte(s): 4 - Ok
Field : 13 Sub : 40 Byte(s): 4 - Ok
Field : 13 Sub : 41 Byte(s): 4 - Ok
Field : 13 Sub : 42 Byte(s): 4 - Ok
Field : 13 Sub : 43 Byte(s): 4 - Ok
Field : 13 Sub : 44 Byte(s): 4 - Ok
Field : 13 Sub : 45 Byte(s): 4 - Ok
Field : 13 Sub : 46 Byte(s): 4 - Ok
Field : 13 Sub : 47 Byte(s): 4 - Ok
Field : 13 Sub : 48 Byte(s): 4 - Ok
Field : 13 Sub : 49 Byte(s): 4 - Ok
Field : 13 Sub : 50 Byte(s): 4 - Ok
Field : 13 Sub : 51 Byte(s): 4 - Ok
Field : 13 Sub : 52 Byte(s): 4 - Ok
Field : 13 Sub : 53 Byte(s): 4 - Ok
Field : 13 Sub : 54 Byte(s): 4 - Ok
Field : 13 Sub : 55 Byte(s): 4 - Ok
Field : 13 Sub : 56 Byte(s): 4 - Ok
Field : 13 Sub : 57 Byte(s): 4 - Ok
Field : 13 Sub : 58 Byte(s): 4 - Ok
Field : 13 Sub : 59 Byte(s): 4 - Ok
Field : 13 Sub : 60 Byte(s): 4 - Ok
Field : 13 Sub : 61 Byte(s): 4 - Ok
Field : 13 Sub : 62 Byte(s): 4 - Ok
Field : 13 Sub : 63 Byte(s): 4 - Ok
Field : 13 Sub : 64 Byte(s): 4 - Ok
Field : 13 Sub : 65 Byte(s): 4 - Ok
Field : 13 Sub : 66 Byte(s): 4 - Ok
Field : 13 Sub : 67 Byte(s): 4 - Ok
Field : 13 Sub : 68 Byte(s): 4 - Ok
Field : 13 Sub : 69 Byte(s): 4 - Ok
Field : 13 Sub : 70 Byte(s): 4 - Ok
Field : 13 Sub : 71 Byte(s): 4 - Ok
Field : 13 Sub : 72 Byte(s): 4 - Ok
Field : 13 Sub : 73 Byte(s): 4 - Ok
Field : 13 Sub : 74 Byte(s): 4 - Ok
Field : 13 Sub : 75 Byte(s): 4 - Ok
Field : 13 Sub : 76 Byte(s): 4 - Ok
Field : 13 Sub : 77 Byte(s): 4 - Ok
Field : 13 Sub : 78 Byte(s): 4 - Ok
Field : 13 Sub : 79 Byte(s): 4 - Ok
Field : 13 Sub : 80 Byte(s): 4 - Ok
Field : 13 Sub : 81 Byte(s): 4 - Ok
Field : 13 Sub : 82 Byte(s): 4 - Ok
Field : 13 Sub : 83 Byte(s): 4 - Ok
Field : 13 Sub : 84 Byte(s): 4 - Ok
Field : 13 Sub : 85 Byte(s): 4 - Ok
Field : 13 Sub : 86 Byte(s): 4 - Ok
Field : 13 Sub : 87 Byte(s): 4 - Ok
Field : 13 Sub : 88 Byte(s): 4 - Ok
Field : 13 Sub : 89 Byte(s): 4 - Ok
Field : 13 Sub : 90 Byte(s): 4 - Ok
Field : 13 Sub : 91 Byte(s): 4 - Ok
Field : 13 Sub : 92 Byte(s): 4 - Ok
Field : 13 Sub : 93 Byte(s): 4 - Ok
Field : 13 Sub : 94 Byte(s): 4 - Ok
Field : 13 Sub : 95 Byte(s): 4 - Ok
Field : 13 Sub : 96 Byte(s): 4 - Ok
Field : 13 Sub : 97 Byte(s): 4 - Ok
Field : 13 Sub : 98 Byte(s): 4 - Ok
Field : 13 Sub : 99 Byte(s): 4 - Ok
Field : 13 Sub : 100 Byte(s): 4 - Ok
Field : 13 Sub : 101 Byte(s): 4 - Ok
Field : 13 Sub : 102 Byte(s): 4 - Ok
Field : 13 Sub : 103 Byte(s): 4 - Ok
Field : 13 Sub : 104 Byte(s): 4 - Ok
Field : 13 Sub : 105 Byte(s): 4 - Ok
Field : 13 Sub : 106 Byte(s): 4 - Ok
Field : 13 Sub : 107 Byte(s): 4 - Ok
Field : 13 Sub : 108 Byte(s): 4 - Ok
Field : 13 Sub : 109 Byte(s): 4 - Ok
Field : 13 Sub : 110 Byte(s): 4 - Ok
Field : 13 Sub : 111 Byte(s): 4 - Ok
Field : 13 Sub : 112 Byte(s): 4 - Ok
Field : 13 Sub : 113 Byte(s): 4 - Ok
Field : 13 Sub : 114 Byte(s): 4 - Ok
Field : 13 Sub : 115 Byte(s): 4 - Ok
Field : 13 Sub : 116 Byte(s): 4 - Ok
Field : 13 Sub : 117 Byte(s): 4 - Ok
Field : 13 Sub : 118 Byte(s): 4 - Ok
Field : 13 Sub : 119 Byte(s): 4 - Ok
Field : 13 Sub : 120 Byte(s): 4 - Ok
Field : 13 Sub : 121 Byte(s): 4 - Ok
Field : 13 Sub : 122 Byte(s): 4 - Ok
Field : 13 Sub : 123 Byte(s): 8 - Ok
Field : 13 Sub : 124 Byte(s): 4 - Ok
Field : 13 Sub : 125 Byte(s): 4 - Ok
Field : 13 Sub : 126 Byte(s): 4 - Ok
Field : 13 Sub : 127 Byte(s): 4 - Ok
Field : 13 Sub : 128 Byte(s): 4 - Ok
Field : 13 Sub : 129 Byte(s): 4 - Ok
Field : 13 Sub : 130 Byte(s): 4 - Ok
Field : 13 Sub : 131 Byte(s): 4 - Ok
Field : 13 Sub : 132 Byte(s): 4 - Ok
Field : 13 Sub : 133 Byte(s): 4 - Ok
Field : 13 Sub : 134 Byte(s): 4 - Ok
Field : 13 Sub : 135 Byte(s): 4 - Ok
Field : 13 Sub : 136 Byte(s): 4 - Ok
Field : 13 Sub : 137 Byte(s): 4 - Ok
Field : 13 Sub : 138 Byte(s): 4 - Ok
Field : 13 Sub : 139 Byte(s): 4 - Ok
Field : 13 Sub : 140 Byte(s): 4 - Ok
Field : 13 Sub : 141 Byte(s): 4 - Ok
Field : 13 Sub : 142 Byte(s): 4 - Ok
Field : 13 Sub : 143 Byte(s): 4 - Ok
Field : 13 Sub : 144 Byte(s): 4 - Ok
Field : 13 Sub : 145 Byte(s): 8 - Ok
Field : 13 Sub : 146 Byte(s): 4 - Ok
Field : 13 Sub : 147 Byte(s): 4 - Ok
Field : 13 Sub : 148 Byte(s): 4 - Ok
Field : 13 Sub : 149 Byte(s): 4 - Ok
Field : 13 Sub : 150 Byte(s): 4 - Ok
Field : 13 Sub : 151 Byte(s): 4 - Ok
Field : 13 Sub : 152 Byte(s): 4 - Ok
Field : 13 Sub : 153 Byte(s): 4 - Ok
Field : 13 Sub : 154 Byte(s): 4 - Ok
Field : 13 Sub : 155 Byte(s): 4 - Ok
Field : 13 Sub : 156 Byte(s): 4 - Ok
Field : 13 Sub : 157 Byte(s): 4 - Ok
Field : 13 Sub : 158 Byte(s): 4 - Ok
Field : 13 Sub : 159 Byte(s): 4 - Ok
Field : 13 Sub : 160 Byte(s): 4 - Ok
Field : 13 Sub : 161 Byte(s): 4 - Ok
Field : 13 Sub : 162 Byte(s): 4 - Ok
Field : 13 Sub : 163 Byte(s): 4 - Ok
Field : 13 Sub : 164 Byte(s): 4 - Ok
Field : 13 Sub : 165 Byte(s): 4 - Ok
Field : 13 Sub : 166 Byte(s): 4 - Ok
Field : 31 Sub : 4 Byte(s): 16 - Ok
Field : 42 Sub : 0 Byte(s): 4 - Ok
Field : 42 Sub : 1 Byte(s): 12 - Ok
Field : 42 Sub : 2 Byte(s): 36 - Ok
Field : 42 Sub : 3 Byte(s): 36 - Ok
Field : 42 Sub : 4 Byte(s): 36 - Ok
Field : 42 Sub : 5 Byte(s): 36 - Ok
Field : 42 Sub : 6 Byte(s): 36 - Ok
Field : 42 Sub : 7 Byte(s): 40 - Ok
Field : 42 Sub : 8 Byte(s): 40 - Ok
Field : 42 Sub : 9 Byte(s): 40 - Ok
Field : 42 Sub : 10 Byte(s): 40 - Ok
Field : 42 Sub : 11 Byte(s): 40 - Ok
Field : 42 Sub : 12 Byte(s): 40 - Ok
Field : 42 Sub : 13 Byte(s): 40 - Ok
Field : 42 Sub : 14 Byte(s): 40 - Ok
Field : 42 Sub : 15 Byte(s): 40 - Ok
Field : 42 Sub : 16 Byte(s): 40 - Ok
Field : 42 Sub : 17 Byte(s): 40 - Ok
Field : 42 Sub : 18 Byte(s): 40 - Ok
Field : 42 Sub : 19 Byte(s): 40 - Ok
Field : 42 Sub : 20 Byte(s): 40 - Ok
Field : 42 Sub : 21 Byte(s): 40 - Ok
Field : 42 Sub : 22 Byte(s): 40 - Ok
Field : 42 Sub : 23 Byte(s): 40 - Ok
Field : 42 Sub : 24 Byte(s): 40 - Ok
Field : 42 Sub : 25 Byte(s): 40 - Ok
Field : 42 Sub : 26 Byte(s): 40 - Ok
Field : 44 Sub : 0 Byte(s): 4 - Ok
Field : 50 Sub : 0 Byte(s): 4 - Failed
Field : 50 Sub : 1 Byte(s): 4 - Failed
Field : 54 Sub : 0 Byte(s): 4 - Ok
Field : 88 Sub : 0 Byte(s): 60 - Failed
Field : 96 Sub : 0 Byte(s): 4 - Ok
Field : 96 Sub : 1 Byte(s): 20 - Ok
Field : 107 Sub : 0 Byte(s): 24 - Ok
Field : 107 Sub : 1 Byte(s): 92 - Ok
Field : 107 Sub : 2 Byte(s): 72 - Ok
Field : 107 Sub : 3 Byte(s): 72 - Ok
Field : 116 Sub : 0 Byte(s): 4 - Ok
Field : 116 Sub : 1 Byte(s): 12 - Ok
Field : 116 Sub : 2 Byte(s): 36 - Ok
Field : 116 Sub : 3 Byte(s): 36 - Ok
Field : 116 Sub : 4 Byte(s): 36 - Ok
Field : 116 Sub : 5 Byte(s): 36 - Ok
Field : 116 Sub : 6 Byte(s): 36 - Ok
Field : 116 Sub : 7 Byte(s): 40 - Ok
Field : 116 Sub : 8 Byte(s): 40 - Ok
Field : 116 Sub : 9 Byte(s): 40 - Ok
Field : 116 Sub : 10 Byte(s): 40 - Ok
Field : 116 Sub : 11 Byte(s): 40 - Ok
Field : 116 Sub : 12 Byte(s): 40 - Ok
Field : 116 Sub : 13 Byte(s): 40 - Ok
Field : 116 Sub : 14 Byte(s): 40 - Ok
Field : 116 Sub : 15 Byte(s): 40 - Ok
Field : 116 Sub : 16 Byte(s): 40 - Ok
Field : 120 Sub : 0 Byte(s): 944 - Ok
Field : 120 Sub : 1 Byte(s): 160 - Ok
Field : 120 Sub : 2 Byte(s): 132 - Ok
Field : 120 Sub : 3 Byte(s): 112 - Ok
Field : 193 Sub : 2 Byte(s): 8 - Ok
Field : 193 Sub : 3 Byte(s): 32 - Ok
Field : 193 Sub : 4 Byte(s): 32 - Ok
Field : 193 Sub : 9 Byte(s): 64 - Ok
Field : 218 Sub : 0 Byte(s): 4 - Ok
Field : 238 Sub : 1 Byte(s): 4 - Ok
Field : 296 Sub : 0 Byte(s): 4 - Failed
Field : 296 Sub : 1 Byte(s): 4 - Failed
Field : 296 Sub : 2 Byte(s): 24 - Failed
Field : 296 Sub : 3 Byte(s): 8 - Failed
Field : 301 Sub : 0 Byte(s): 4 - Ok
Field : 301 Sub : 1 Byte(s): 12 - Ok
Field : 301 Sub : 2 Byte(s): 36 - Ok
Field : 301 Sub : 3 Byte(s): 36 - Ok
Field : 301 Sub : 4 Byte(s): 36 - Ok
Field : 301 Sub : 5 Byte(s): 36 - Ok
Field : 301 Sub : 6 Byte(s): 36 - Ok
Field : 301 Sub : 7 Byte(s): 40 - Ok
Field : 301 Sub : 8 Byte(s): 40 - Ok
Field : 301 Sub : 9 Byte(s): 40 - Ok
Field : 301 Sub : 10 Byte(s): 40 - Ok
Field : 301 Sub : 11 Byte(s): 40 - Ok
Field : 301 Sub : 12 Byte(s): 40 - Ok
Field : 301 Sub : 13 Byte(s): 40 - Ok
Field : 301 Sub : 14 Byte(s): 40 - Ok
Field : 301 Sub : 15 Byte(s): 40 - Ok
Field : 301 Sub : 16 Byte(s): 40 - Ok
Field : 308 Sub : 0 Byte(s): 4 - Ok
Field : 308 Sub : 1 Byte(s): 8192 - Ok
Field : 308 Sub : 3 Byte(s): 4 - Ok
Field : 308 Sub : 4 Byte(s): 4 - Ok
Field : 308 Sub : 5 Byte(s): 12 - Ok
Field : 308 Sub : 6 Byte(s): 4 - Ok
Field : 308 Sub : 7 Byte(s): 4 - Ok
Field : 308 Sub : 8 Byte(s): 4 - Ok
Field : 308 Sub : 9 Byte(s): 40 - Ok
Field : 309 Sub : 0 Byte(s): 4 - Ok
Field : 309 Sub : 1 Byte(s): 4 - Ok
Field : 309 Sub : 2 Byte(s): 12 - Ok
Field : 309 Sub : 3 Byte(s): 36 - Ok
Field : 309 Sub : 4 Byte(s): 12 - Ok
Field : 309 Sub : 7 Byte(s): 12 - Ok
Field : 313 Sub : 0 Byte(s): 192 - Failed
Field : 322 Sub : 0 Byte(s): 4 - Ok
Field : 334 Sub : 0 Byte(s): 4 - Failed
Field : 339 Sub : 0 Byte(s): 512 - Ok
Field : 339 Sub : 1 Byte(s): 512 - Ok
Field : 341 Sub : 0 Byte(s): 4 - Ok
Field : 341 Sub : 3 Byte(s): 4 - Ok
Field : 341 Sub : 4 Byte(s): 4392 - Ok
Field : 341 Sub : 5 Byte(s): 4 - Ok
Field : 341 Sub : 6 Byte(s): 2380 - Ok
Field : 354 Sub : 0 Byte(s): 28 - Ok
Field : 355 Sub : 0 Byte(s): 9480 - Ok
Field : 356 Sub : 0 Byte(s): 4 - Failed
Field : 356 Sub : 1 Byte(s): 8 - Failed
Field : 364 Sub : 0 Byte(s): 4 - Ok
Field : 364 Sub : 1 Byte(s): 12 - Ok
Field : 364 Sub : 2 Byte(s): 36 - Ok
Field : 364 Sub : 3 Byte(s): 36 - Ok
Field : 364 Sub : 4 Byte(s): 36 - Ok
Field : 364 Sub : 5 Byte(s): 36 - Ok
Field : 364 Sub : 6 Byte(s): 36 - Ok
Field : 364 Sub : 7 Byte(s): 40 - Ok
Field : 364 Sub : 8 Byte(s): 40 - Ok
Field : 364 Sub : 9 Byte(s): 40 - Ok
Field : 364 Sub : 10 Byte(s): 40 - Ok
Field : 364 Sub : 11 Byte(s): 40 - Ok
Field : 364 Sub : 12 Byte(s): 40 - Ok
Field : 364 Sub : 13 Byte(s): 40 - Ok
Field : 364 Sub : 14 Byte(s): 40 - Ok
Field : 364 Sub : 15 Byte(s): 40 - Ok
Field : 364 Sub : 16 Byte(s): 40 - Ok
Field : 364 Sub : 17 Byte(s): 40 - Ok
Field : 364 Sub : 18 Byte(s): 40 - Ok
Field : 364 Sub : 19 Byte(s): 40 - Ok
Field : 364 Sub : 20 Byte(s): 40 - Ok
Field : 364 Sub : 21 Byte(s): 40 - Ok
Field : 364 Sub : 22 Byte(s): 40 - Ok
Field : 364 Sub : 23 Byte(s): 40 - Ok
Field : 364 Sub : 24 Byte(s): 40 - Ok
Field : 364 Sub : 25 Byte(s): 40 - Ok
Field : 364 Sub : 26 Byte(s): 40 - Ok
Field : 365 Sub : 0 Byte(s): 4 - Ok
Field : 365 Sub : 1 Byte(s): 12 - Ok
Field : 365 Sub : 2 Byte(s): 36 - Ok
Field : 365 Sub : 3 Byte(s): 36 - Ok
Field : 365 Sub : 4 Byte(s): 36 - Ok
Field : 365 Sub : 5 Byte(s): 36 - Ok
Field : 365 Sub : 6 Byte(s): 36 - Ok
Field : 365 Sub : 7 Byte(s): 40 - Ok
Field : 365 Sub : 8 Byte(s): 40 - Ok
Field : 365 Sub : 9 Byte(s): 40 - Ok
Field : 365 Sub : 10 Byte(s): 40 - Ok
Field : 365 Sub : 11 Byte(s): 40 - Ok
Field : 365 Sub : 12 Byte(s): 40 - Ok
Field : 365 Sub : 13 Byte(s): 40 - Ok
Field : 365 Sub : 14 Byte(s): 40 - Ok
Field : 365 Sub : 15 Byte(s): 40 - Ok
Field : 365 Sub : 16 Byte(s): 40 - Ok
Field : 369 Sub : 0 Byte(s): 40 - Failed
Field : 373 Sub : 0 Byte(s): 44 - Ok
Field : 374 Sub : 0 Byte(s): 4 - Ok
PM Upload Done!...
