em có con x2-00 mất nguồn .em chạy phần mềm bằng usb thì nó báo ntn
Processing Image File :
rm618__08.35.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 511
Entry Point: 0x01E5
Page Format : -1
MAX PAGE : 0x0000E000
rm618__08.35.ppm_v
CMT Type : BB5
Number of Blocks : 128
Entry Point: 0x0100
Page Format : -1
rm618__08.35.image_v_0595285
CMT Type : BB5
Number of Blocks : 384
Entry Point: 0x0134
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 6 (0x06)
1 SYSTEM_ASIC_ID 01
Block Length : 17 (11)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000000
ID DWORD 1 : 00000000
ID DWORD 2 : 22000509
ID DWORD 3 : 200C0000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00005361
3 PUBLIC_ID 12
Block Length : 21 (15)
ID DWORD 1 : 00C8772E
ID DWORD 2 : 3D315065
ID DWORD 3 : 5E6B072C
ID DWORD 4 : 991A65DA
4 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
5 ROOT_KEY_HASH 14
Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
6 ROM_ID 15
Block Length : 9 (09)
CRC 0 : DE56D582
CRC 1 : BDDE7A3A
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_u sb2nd.fg
Secondary Loader Sent....
MessageID : C1
SubBlocks : 06
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0020 ->
Device ID : 0030 -> Type not in database
Revision ID : 0131
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> Type not in database
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Revision ID : 0131
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data :
Flash Descriptor
Device ID : 0030
Revision ID : 0000
Size : 08000000 (128 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_X SR16_usbalg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
START READING RPL DATA
IMEI: 359317046459892
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\359317046459892\3593170464598 92_104940.rpl
Pabub KEY Request
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
E9700989029D9E899915F781B1582048E042A738
ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-618\
ImageFilename: rm618__08.35.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 00020000
Partition 2
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 02900000
Partition 3
Start Address : 07540000
Partition 4
Start Address : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200020000024E000000000008000000010290000004C400 000000000A0000000107540000006000000000000B00000001 07B40000001800001D
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x90 (144)
ERASE Blocks : 0x03 (3)
0 ERASE_AREA_BB5 0x12
Block Length : 0x2B (43)
Device Index : 0x00
0 : 00000000-0001FFFF
1 : 00020000-000203FF
2 : 00060000-011BFFFF
3 : 011C0000-01CFFFFF
4 : 02500000-028FFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5005120B000300000000000001FFFF120B0003000002000000 0203FF120B00030000060000011BFFFF120B000300011C0000 01CFFFFF120B00030002500000028FFFFF69
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
Successfully Erased...
Total blocks to write : 511
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : ISA+DYNSW
>> CMT Rootkey Hash CERT : MCUSW
>> CMT Rootkey Hash CERT : MCUSW1
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : UPDAPP
ImageFilename: rm618__08.35.ppm_v
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01D00000-024FFFFF
ERASE_REQUEST_BB5 : 5001120B00030001D00000024FFFFFBE
Total blocks to write : 128
ImageFilename: rm618__08.35.image_v_0595285
StartErase_DCT5...
BlockLength : 0x3F (63)
ERASE Blocks : 0x02 (2)
Device Index : 0x00
0 : 02900000-0753FFFF
Device Index : 0x00
Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5001120B000300029000000753FFFFF4
FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E
Total blocks to write : 384
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000000
Additional Bad : 00000000
Correctable ECC : 00000000
FlashInfo.RestartMode : 2
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:11
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
cứ chạy đến đấy là nó cứ chạy thôi .chờ mãi mà nó ko song
bác nào gặp qua giúp em với
