Kết quả 1 tới 2 của 2
    V.I.P ĐƠ_NGUYỄN's Avatar
    Mặc định c3-00 flash không đồng bộ
    máy đang xài bình thường , rồi bị trắng treo , chạy fw cao nhất = , bestool , phoneix , mx , atf chạy ok nhưng ko đồng bộ dc , máy vẫn y tình trạng củ , ae gặp qua xin , tks
    log flash =mx
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0855D93
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100E867
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: NMWCD, ver: 7.1.32.84
    Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
    Processing MCU file: rm614__08.71.mcusw
    [BB5,XSR 1.6] size: 27.92 MB
    Supported Ids: 2200050920030000, 22000509200C0000
    CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
    CMT EM0 ID: 00005361
    CMT PUBLIC ID: 00000000002539FE8AC573F27A3AA246846645FD
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
    CMT ROM ID: DE56D582BDDE7A3A
    Loading CMT secondary boot code
    SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
    Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
    Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Loading CMT update server data
    Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
    Update server code loaded.
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 20CC1644
    FUR: Adding Asic CMT as client OK.
    Reading CMT NPC (0x190 bytes).
    Reading CMT VARIANT (0x0 bytes).
    Reading CMT CCC (0x178 bytes).
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Reading CMT MDM_KEYS (0x0 bytes).
    Reading CMT PARTNERC (0x0 bytes).
    RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35376004634174_CE RT.rpl).
    CMT PAPUBKEYS HASH: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
    Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 33.88 MB
    CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
    CMT FLASH,MuxOneNAND area [00020000-000203FF]
    CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
    CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
    CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
    Formating partition ...
    Flash programming ...
    CMT KEYS block sent
    CMT ADA block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 697F7477 [RAP Certificate v1 232] sent
    CMT UPDAPP block sent
    CMT MCUSW block sent
    CMT MCUSW1 block sent
    CMT GENIO_INIT block sent
    CMT ISA+DYNSW block sent
    Programming completed in 9.297 s
    Processing PPM file: rm614__08.71.ppm_v
    [BB5,XSR 1.6] size: 6.80 MB
    Erase size: 8 MB
    CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
    Programming completed in 2.125 s
    Processing CNT file: rm614__08.71.image_v_059G6Z2
    [BB5,XSR 1.6] size: 13 MB
    Erase size: 75.31 MB
    CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
    Programming completed in 4.437 s
    Total time for flashing process(boot+erase+write) was 30.203 s
    Waiting for device boot up ...
    Warning: Phone did not reboot to normal mode.
    [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
    đóng lại nguồn đã done
