Kết quả 1 tới 2 của 2
    Thành viên mới khanhlanmobile's Avatar
    Unhappy 1650 xin giup Ae oi !!!
    máy chạy tiếng việt. chạy xong lên NOKIA rùi đen luôn. mình đã chạy các ver, hiện là ver 6.0 Using device: POTATO BOX, FW ver: 01.B1
    Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
    ASIC ID: 0x2292 [UPPCosto ver: 1.3]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
    FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
    UEM ID: 00436B13A3BDA66
    ASIC type: 11
    UEM Imei: 35291102825146
    Processing file: rm305_06.00mg as MCU
    [DCT4,DCT4 ALGORITHM] size: 3.52 MB
    Supported Ids: 2292
    UEM ID: 00436B13:2984DA60
    Area [01240000-0125FFFF] erased in 0.562 s
    Area [01260000-0175FFFF] erased in 26.578 s
    Flash programming ...
    Programming completed in 1 min 35.516 s
    File Processed in 2 min 18.860 s
    Processing file: rm3050_nai6.00mg as CNT
    [DCT4,DCT4 ALGORITHM] size: 180.34 KB
    Supported Ids: 2292
    Area [01760000-0179FFFF] erased in 1.203 s
    Programming completed in 5.406 s
    Content extract fail, continue anyway ...
    File Processed in 1 min 15.656 s
    Processing file: rm305_06.000 as PPM
    [DCT4,DCT4 ALGORITHM] size: 2.33 MB
    Supported Ids: 2292
    Area [01000000-0100FFFF] erased in 0.688 s
    Area [01010000-0179FFFF] erased in 39.719 s
    Area [017A0000-017EFFFF] erased in 2.235 s
    Area [01F00000-01FDFFFF] erased in 6.015 s
    Programming completed in 1 min 7.937 s
    File Processed in 2 min 13.813 s
    Flashing completed in 6 min 39.422 s
    Phone Type: RM-305
    SW Version: V 6.00 30-09-09 RM-305 (c) NMP
    Imei plain: 35291102825146-2
    Cellular System: GSM
    ASIC ID: 0x2292, type: 11
    Ppm Id: ’ÆŽ
    Language Pack:
    - not available.
    Imei net: 35291102825146
    Version: SIMLOCK SERVER
    Provider: ALL Operator, Country: -
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 0000000000010002
    BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    Total time to process is 7 min 42.812 s
    n. ae nào có cao kiến xin giúp mình nha. Còn đây là log của nó.
    V.I.P UNLOCKDTDD's Avatar
    Feb 2009
    mang qua jaf múc đi you
    xóa flash --> nạp fw 5.80 --> writer pm unlock ---> factory ok chuc thành cong
    Yahoo :quynhmy93 , dt: 0917143611
    unlock _ nạp tiếng việt _ nâng cấp phần mềm ---> các loại mobile
  1. 1650 can giup
    By tuananh65 in forum DCT4 - WD2
    Bài viết cuối: 09-11-2010, 15:24
  2. 1650 can giup
    By myfone in forum DCT4 - WD2
    Bài viết cuối: 12-09-2009, 21:44
  3. 1650 mat den can giup do
    By Vip_xinhzai in forum DCT4 - WD2
    Bài viết cuối: 26-05-2009, 14:39
  4. 1650 cân anh em giup do
    By honny in forum DCT4 - WD2
    Bài viết cuối: 25-07-2008, 08:23
