Getting MCU ID
MCU ID: 0x3168
FLASH ID0: 2C7E0001 <=> SPANSION -> 72NS128N Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 07.04a
26-08-08
RH-86
(c) Nokia.
HW version: 1000
PCI version:
UEM version: 1328
UPP version: 12648
RFIC version: 0500
DSP version: P05w45.v49
LCD version: ELBE
PPM version: V 07.11
05-11-08
RH-86_87
(c) Nokia.
V
Content Pack version: Content: att
22-09-08
RH-87
(c) Nokia.
Production serial number: DMJ191887
Product code: 0533407
Module code: 0202930
Basic production code: 0530409
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 011684000934792
IMEI spare to net: 0A 11 86 04 00 39 74 09
IMEI SV to net: 03 11 86 04 00 39 74 69 F1
Master Code: 4014152717
Phone type: RH-86, Software version: 07.04a, Language Pack: V
User code: 12345
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-86.ini
Setting local mode...
Reading product code...
Product Code: 0533407
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-86\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-86\
anh em coi thu hjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
