em chậy băng hwk ko boot được em cứ chậy giờ nó têo rồi
MCU File: e1100tdbic3.cla CRC32: BC2F4D91
TFS File: e1100tdbic3.tfs CRC32: EF0B8B3F
CFG File: e1100tdbic3.cfg 4154 byte(s)
Conneem chậy băng hwk ko boot được em cứ chậy giờ nó têo rồi
Connect Cable to Switched Off Mobile (with battery)
Preloader Ok 54, 115200 Baud
Flashloader Ok
FLASH Id: SEC, K5N6433ATM
Erase Done, 56 sector(s), Time: 00:19
File CRC: 0xBC2F4D91
Loaded Locale: AR by Almoudamer "GsclTeam"
MCU Write Done, 5039892 byte(s), Time: 07:56
File CRC: 0xEF0B8ct Cable to Switched Off Mobile (with battery)
Flashloader Ok
File CRC: 0xEF0B8B3F
TFS Version : TFS4.0_CORONA_01
Directories : 16
Max_Files : 52
Directory : /customer
Directory : /customer/nvmgr
Directory : /images
Directory : /images/idle
Directory : /images/LargeClock
Directory : /images/menu
Directory : /images/org
Directory : /images/power
Directory : /images/UCS
Directory : /images/UCS/Default
Directory : /images/UCS/Default/cfg
Directory : /memo
Directory : /sms
Directory : /sounds
Directory : /sounds/default
Directory : /test
Files_Count: 52/52
File: /customer/nvmgr/NvData.dat, Size: 8875
File: /customer/nvmgr/NvInit.dat, Size: 8875
File: /customer/nvmgr/nvSize.dbg, Size: 293
File: /customer/nvmgr/VariantVersion.dat, Size: 2
File: /images/idle/idle_011.ifg, Size: 11086
File: /images/idle/idle_021.ifg, Size: 13138
File: /images/idle/idle_031.ifg, Size: 11772
File: /images/idle/idle_041.ifg, Size: 11966
File: /images/idle/idle_051.ifg, Size: 14950
File: /images/LargeClock/icon.ifg, Size: 324
File: /images/LargeClock/idle_large_clock_lock.ifg, Size: 142
File: /images/LargeClock/num.ifg, Size: 3056
File: /images/menu/00_mainmenu_block_bg.ifg, Size: 2014
File: /images/menu/00_mainmenu_block_menu01_ani04.ifg, Size: 230
File: /images/menu/00_mainmenu_block_menu02_ani04.ifg, Size: 236
File: /images/menu/00_mainmenu_block_menu03_ani04.ifg, Size: 330
File: /images/menu/00_mainmenu_block_menu04_ani04.ifg, Size: 334
File: /images/menu/00_mainmenu_block_menu05_ani04.ifg, Size: 330
File: /images/menu/00_mainmenu_block_menu06_ani04.ifg, Size: 276
File: /images/menu/00_mainmenu_block_menu07_ani04.ifg, Size: 308
File: /images/menu/00_mainmenu_block_menu08_ani04.ifg, Size: 236
File: /images/menu/00_mainmenu_block_menu09_ani04.ifg, Size: 510
File: /images/org/01_thai_sympopup_bg1.ifg, Size: 780
File: /images/org/01_thai_sympopup_focus_011.ifg, Size: 696
File: /images/org/01_thai_sympopup_focus_021.ifg, Size: 698
File: /images/power/pwron01.ifg, Size: 2850
File: /images/UCS/Default/cfg/Default-1.thm, Size: 324
File: /images/UCS/Default/cfg/Default-2.thm, Size: 324
File: /images/UCS/Default/cfg/Default-3.thm, Size: 324
File: /images/UCS/Default/cfg/Default-4.thm, Size: 324
File: /images/UCS/Default/cfg/Default-5.thm, Size: 324
File: /images/greeting_01.ifg, Size: 3616
File: /memo/memo_list_file.dat, Size: 804
File: /sounds/default/Baroque.mid, Size: 2227
File: /sounds/default/Basic_tone.mid, Size: 1367
File: /sounds/default/Before sunset.mid, Size: 10870
File: /sounds/default/Butterfly kiss.mid, Size: 4021
File: /sounds/default/Chiming tone.mid, Size: 1583
File: /sounds/default/Classic bell.mp3, Size: 69632
File: /sounds/default/Dewy Leaves.mid, Size: 13024
File: /sounds/default/Focus on it.mid, Size: 4749
File: /sounds/default/Forgotten Promise.mid, Size: 8434
File: /sounds/default/Funky Marionette.mid, Size: 5563
File: /sounds/default/Good morning.mid, Size: 4084
File: /sounds/default/Nightless city.mid, Size: 5250
File: /sounds/default/Rainbow bridge.mid, Size: 7769
File: /sounds/default/Samsung tune.mp3, Size: 321536
File: /sounds/default/Tripping.mid, Size: 799
File: /sounds/default/Voyage.mid, Size: 7115
File: /sounds/default/Watercolor painting.mid, Size: 13998
File: /sounds/default/Wind tone.mp3, Size: 14336
File: /test/cfg.txt, Size: 4101
Files Closed
TFS Unmounted
TFS Write Done, 600805 byte(s), Time
