MCU File: e1100tdbic3.cla CRC32: BC2F4D91
TFS File: e1100tdbic3.tfs CRC32: EF0B8B3F
CFG File: e1100tdbic3.cfg 4154 byte(s)
Connect Cable to Switched Off Mobile (with battery)
Preloader Ok 54, 115200 Baud
Flashloader Ok
FLASH Id: SEC, K5N6433ATM
Erase Done, 56 sector(s), Time: 00:19
File CRC: 0xBC2F4D91
Loaded Locale: AR by Almoudamer "GsclTeam"
MCU Write Done, 5039892 byte(s), Time: 07:56
File CRC: 0xEF0B8B3F
TFS Version : TFS4.0_CORONA_01
Directories : 16
Max_Files : 52
Directory : /customer
Directory : /customer/nvmgr
Directory : /images
Directory : /images/idle
Directory : /images/LargeClock
Directory : /images/menu
Directory : /images/org
Directory : /images/power
Directory : /images/UCS
Directory : /images/UCS/Default
Directory : /images/UCS/Default/cfg
Directory : /memo
Directory : /sms
Directory : /sounds
Directory : /sounds/default
Directory : /test
Files_Count: 52/52
File: /customer/nvmgr/NvData.dat, Size: 8875
File: /customer/nvmgr/NvInit.dat, Size: 8875
File: /customer/nvmgr/nvSize.dbg, Size: 293
File: /customer/nvmgr/VariantVersion.dat, Size: 2
File: /images/idle/idle_011.ifg, Size: 11086
File: /images/idle/idle_021.ifg, Size: 13138
File: /images/idle/idle_031.ifg, Size: 11772
File: /images/idle/idle_041.ifg, Size: 11966
File: /images/idle/idle_051.ifg, Size: 14950
File: /images/LargeClock/icon.ifg, Size: 324
File: /images/LargeClock/idle_large_clock_lock.ifg, Size: 142
File: /images/LargeClock/num.ifg, Size: 3056
File: /images/menu/00_mainmenu_block_bg.ifg, Size: 2014
File: /images/menu/00_mainmenu_block_menu01_ani04.ifg, Size: 230
File: /images/menu/00_mainmenu_block_menu02_ani04.ifg, Size: 236
File: /images/menu/00_mainmenu_block_menu03_ani04.ifg, Size: 330
File: /images/menu/00_mainmenu_block_menu04_ani04.ifg, Size: 334
File: /images/menu/00_mainmenu_block_menu05_ani04.ifg, Size: 330
File: /images/menu/00_mainmenu_block_menu06_ani04.ifg, Size: 276
File: /images/menu/00_mainmenu_block_menu07_ani04.ifg, Size: 308
File: /images/menu/00_mainmenu_block_menu08_ani04.ifg, Size: 236
File: /images/menu/00_mainmenu_block_menu09_ani04.ifg, Size: 510
File: /images/org/01_thai_sympopup_bg1.ifg, Size: 780
File: /images/org/01_thai_sympopup_focus_011.ifg, Size: 696
File: /images/org/01_thai_sympopup_focus_021.ifg, Size: 698
File: /images/power/pwron01.ifg, Size: 2850
File: /images/UCS/Default/cfg/Default-1.thm, Size: 324
File: /images/UCS/Default/cfg/Default-2.thm, Size: 324
File: /images/UCS/Default/cfg/Default-3.thm, Size: 324
File: /images/UCS/Default/cfg/Default-4.thm, Size: 324
File: /images/UCS/Default/cfg/Default-5.thm, Size: 324
File: /images/greeting_01.ifg, Size: 3616
File: /memo/memo_list_file.dat, Size: 804
File: /sounds/default/Baroque.mid, Size: 2227
File: /sounds/default/Basic_tone.mid, Size: 1367
File: /sounds/default/Before sunset.mid, Size: 10870
File: /sounds/default/Butterfly kiss.mid, Size: 4021
File: /sounds/default/Chiming tone.mid, Size: 1583
File: /sounds/default/Classic bell.mp3, Size: 69632
File: /sounds/default/Dewy Leaves.mid, Size: 13024
File: /sounds/default/Focus on it.mid, Size: 4749
File: /sounds/default/Forgotten Promise.mid, Size: 8434
File: /sounds/default/Funky Marionette.mid, Size: 5563
File: /sounds/default/Good morning.mid, Size: 4084
File: /sounds/default/Nightless city.mid, Size: 5250
File: /sounds/default/Rainbow bridge.mid, Size: 7769
File: /sounds/default/Samsung tune.mp3, Size: 321536
File: /sounds/default/Tripping.mid, Size: 799
File: /sounds/default/Voyage.mid, Size: 7115
File: /sounds/default/Watercolor painting.mid, Size: 13998
File: /sounds/default/Wind tone.mp3, Size: 14336
File: /test/cfg.txt, Size: 4101
Files Closed
TFS Unmounted
TFS Write Done, 600805 byte(s), Time: 01:20
em chậy bang HWK
