Kết quả 11 tới 20 của 20
    Thành viên kỳ cựu HQDuan_GSM's Avatar
    Jul 2008
    cần phải như thế lắm
    Lấy không làm có, vượt khó đi lên DT: 0912.868.911
    Thành viên tích cực duyquan's Avatar
    Jan 2008
    này thì cho em oánh dấu cái
    :p Để tiền trong túi làm chi .....? :p
    :DMua liều thuốc chuột , phòng khi chán đời :(
    Jun 2008
    Hà Nội & Sài Gòn
    Samsung Network/Sim Unlock Code Generator/Patcher
    Hello fellows!
    Today we present a unified/streamlined and simple as (some words here) SIMLOCK/NetworkLock unlock code generator by stock+ team!
    Mytool generates ORIGINAL unlock code without modyfying any files!(like most of unlocker program does)
    or PATCHES The file directly, removing simlock without code!
    Feel free to read README.NOW file and post your comments / infos here!
    Download Version (1.3-GPU/Patch) With UI (as on screenshot)
    Version History:
    – 1.3
    * Added direct patch method for Galaxy S 3 devices.
    * Code optimization.
    * More GFX card support added to hash cracking module.
    – 1.2
    * Added direct patch method for Galaxy S 2 devices (if you your code cant be generated or you dont have proper GPU, use this method – Read README.TXT before)
    * Patching method confirmed working on HV 1.4+ version !
    – 1.1
    * Added GPU supported/not supported message
    – 1.0
    * Requires Windows .NET Framework v4
    * Support for Galaxy S II Added
    * Nice UI added
    * ATI RV 7X0 card or nVidia ‘CUDA’ one (G80+) required to decrypt pass in this release. Next version will not use GPU but it will be slower. For these who dont have supported GPU, please wait.
    * Warning: if generated code will not work for a first time when you are sure you typed it correctly, report it to us and stop trying, your phone will lock out after 3 unsuccessful unlock tries.
    HOW TO RE-LOCK SAMSUNG GALAXY S (GT-I9000) (FOR WARRANTY PURPOSES ONLY)
    After you get the Unlock code using our tool, enter: *7465625*638*#
    Pop-up box will show up. Complete the first field (MCC/MNC) with the network you want your phone locked to (for example 260 03 where 226 = Poland; 03 = orange etc.) and the second field (Control Key) with the Generated Unlock Code.
    After pressing OK, your phone should relock.
    đây là chích dẫn từ forum xda-developers.com
  4. ( Hai_GSM_Pro ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    GSM_Body (29-09-2012)
    Thành viên mới GSM_Body's Avatar
    Aug 2012
    cũng sợ , nhưng vẫn đánh dấu
    Jun 2008
    Hà Nội & Sài Gòn
    cứ 1 bên 15t 1 bên máy là không phải sợ Bài ca " Chết thì đền , chết lại đền là ok "
    Thành viên tích cực do dinh hoang's Avatar
    Dec 2012
    mật khấu là gì bạn
  8. #7
    Dec 2012
    mật khấu là gì vậy
  9. #8
    Thành viên danh dự NgocTin_Apple's Avatar
    saigon
    cám ơn anh đã chia sẻ!
  10. #9
    Thành viên chính thức quangngocbk's Avatar
    Jun 2011
    thanks có dịp múc mạnh
    học thầy không tày học ban/////////
    yahoo; motbuocgianghoqn89 gmai; quangngocbk.com
  11. #10
    Thành viên kỳ cựu dinhhieu444's Avatar
    ĐỒNG NAI
    chờ kèo thơm múc thử thaks a chia sẻ(a sent file cho em với yahoo dinhieumobile444)
    DINHHIEUMOBILE444 _ WELLCOM SỬA CHỮA ALL MOBILE
    444 TRẢNG BOM-ĐỒNG NAI : 0909613891
  1. All rom và tool galaxy
    By ThanhHai_GSM in forum Samsung Android
    Trả lời: 35
    Bài viết cuối: 29-04-2015, 14:45
  2. xin tool galaxy s2 i9100
    By qngoc in forum Phần mềm Samsung
    Bài viết cuối: 18-08-2013, 13:35
  3. Chia sẻ Galaxy note II N7100 có thể unlock bằng tool
    By Lính Khang in forum Samsung Android
    Bài viết cuối: 09-02-2013, 02:52
  4. Trả lời: 0
    Bài viết cuối: 11-08-2012, 16:50
  5. Xin giúp Galaxy M110s up nhầm fw 2.3.6 của Galaxy S i9000 không unlock mạng !
    By gh0st8x in forum Các loại máy khác của Samsung
    Bài viết cuối: 20-07-2012, 08:20
