blackberry FREE Unlocking codes Request:
post your imei and mep & wait for your unlocking code
Instructions for Unlocking BlackBerry (All Models)
Always the Best way to Unlock Your Phone is by using the MEP2 code or Unlock code.
After u got the code follow the instructions below......
BlackBerry Unlock Instructions (9800)
* Insert a foreign SIM Card
* Power on the phone
* When prompted, enter your unlock code
BlackBerry Unlock Instructions (83xx/85xx/88xx/8900/9000/9300/96xx/97xx)
* Ensure a SIM Card is inserted
* Go to 'Manage Connections'
* Click on 'Turn All Connections Off'
* Go to 'Options'
* Click on 'Advanced Options'
* Click on 'SIM Card'
* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)
* Type 'MEP2' (user will be prompted to enter MEP code)
* Enter the MEP2 code (CONFIRM you get "Code Accepted" message)
o *If you also have a MEP4 code, type 'MEP4' (you will be prompted to enter MEP code)
o Enter the MEP4 code (CONFIRM you get "Code Accepted" message)
* Reboot device
* Click on 'Restore Connections'
* Device is now unlocked
BlackBerry Unlock Instructions (95xx)
* Go to 'Options'
* Tilt the phone horizontally, click the BlackBerry button and Show keyboard
o *If MEPD doesn't work, try MEPPD
o *If MEP2 doesn't work, try MEPP2
* Reboot device
Blackberry Instructions (81xx/82xx/9100)
* Go to 'Options'
* Type 'MEPPD' (letters will not appear on-screen but a menu will pop up.)
* Type 'MEPP2' (*Note- for Telus, use MEPP4. You will be prompted to enter MEP code)
* Enter the unlock code (CONFIRM you get "Code Accepted" message)
* Reboot device
Old School BlackBerry Instructions (87xx & Older)
* Go to 'Options'
* Hold ALT key and type 'MEPE' (user will be prompted to enter MEP code)
* Reboot device
			 hướng dẫn nhập code cho blac-berry khi đã tính code bằng mxkey
